November 22, 2024, 12:07:44 12:07
Pages: [1] 2  All
Author Topic: REQ: Small sinewave inverter  (Read 12501 times)
« on: July 06, 2014, 09:11:42 21:11 »
I need a small 12VDC to 220VAC 50 Hz sine wave inverter, 25 watt max is enough. Simple and low cost will be the priority, also there is dimension restriction of 40x40x80 mm max. The sine wave do not need to be pure, just close to is enough.
One dilemma is between iron core vs ferrite core transformer (low vs high frequency converter). With iron core the circuit is simple but the transformer is big and bulky also more expensive, whilst with ferrite core the circuit becoming complex as the conversion done in several steps.
Two i found on the web:
http://www.m0ukd.com/electronics/modified_sine_wave_inverter/ - seems too simple and not "sine wave enough" (?).
http://www.edaboard.com/thread248198-11.html#post1351486 - i am not sure the transformer used, seems iron core (?).
Any though?
Also, can i use three 10VA iron core transformer in parallel to get 30VA ? This is about dimension restriction.
titi
-Given: 3802
-Receive: 834
« Reply #1 on: July 06, 2014, 11:03:23 23:03 »
Hi Ichan,
may be this simple inverter is good enough ?
http://www.sonsivri.to/forum/index.php?topic=31698.msg102602#msg102602
Best regards.
-Receive: 904
« Reply #2 on: July 07, 2014, 09:25:44 09:25 »
No word on efficiency?
If you don't care, how about a class D audio power amplifier feeding the transformers and the sign wave generation is your choice? http://www.st.com/web/en/catalog/sense_power/FM1934/SC1762?sc=tuner
DreamCat
-Given: 223
-Receive: 116
« Reply #3 on: July 07, 2014, 11:50:49 11:50 »
Hi Ichan,
why not try to do it with the SPWM technoligy. It's not very hard to do it now.
such as some type of mcu with four channel pwm output of stm8 family, or other family's mcu with enough pwm output and ADC.
oh~~I saw the topic on edaboard which you past here. it is a SPWM. frequancy is 31250Hz. ferrite core transformer.  Smiley
« Reply #4 on: July 08, 2014, 09:44:01 21:44 »
Thanks, seems it is similar with my first link but the web has some more info on this.
I have no idea using class D amplifier, the efficiency specified is not very high - 0.7 or more.
Yes, i am interested with this SPWM thing - do you have any other references?
Are you sure about ferrite core transformer? The author mostly talk about 50 Hz transformer, and the photo also shows an iron core transformer (at the bottom of the photo above). I do really hope a ferrite transformer can be used as it will solve the dimension restriction.
DreamCat
-Given: 223
-Receive: 116
« Reply #5 on: July 11, 2014, 10:33:08 10:33 »
sorry, since GREAT FIRE WALL, It is very hard to access foreign these days.
In that link, there is a image:
the mcu output four channel PWM(SPWM) singal to drive MOSFET, the high-side through the 6N137.
you may noticed, there is no transformer, only a big inductor(5mH), use as PFC with a 0.22uF capitor. the thing in the image which in your last post is a inductor, not a transformer, It only have two wire(black and blue).
I don't know what size ferrite core is need to make a 5mH inductor. but I think it will be very large and expansive. LOL
Posted on: July 11, 2014, 11:29:37 11:29 - Automerged
I decide to simulat the whole circuit except the mcu part.
but, where is the 330V comes from?
« Last Edit: July 11, 2014, 10:42:12 10:42 by DreamCat » Logged
-Given: 833
-Receive: 4320
« Reply #6 on: July 11, 2014, 10:45:21 10:45 »
A note in the circuit says it is from a PC Power Supply, so it will be free to most people..
« Reply #7 on: July 11, 2014, 12:33:36 12:33 »
Hi DreamCat,
The schematic you refer to is the 300 VDC input version, my interest is on 12 VDC input.
It is on post#204 with tiny13 or post#193 with stm8.
DreamCat
-Given: 223
-Receive: 116
« Reply #8 on: July 21, 2014, 02:00:12 14:00 »
Hi Ichan,
I saw both post, all of them are SMPS, but I am confused too. for the PWM signal that modulated by sine wave, which is the main component? 50Hz sine wave or 30kHz PWM(I only rememberd a few Fourier transformation)?
So I searched a lot of schematic about SPWM inverter, and I noticed most of them use iron core transformer, a few of them has no transformer or hase ferrite core transformer. Since you wish it is not very bulky, I recommand you choice the no transformer(transless) structure.
sam_des
-Given: 128
-Receive: 151
« Reply #9 on: July 21, 2014, 05:54:10 17:54 »
Hi Ichan,
  • If you want to use Ferrite Core Transformers, there is only one way,
12V-->DC-DC Converter (Output=+/-150VDC or +300VDC)-->Half Bridge/Full Bridge Inverter-->50 Hz Filter-->230VAC
    You need regulation at DC-DC stage as well as at inverter stage. Obviously circuit will neither be simple nor low cost.
  • With 25W max output, I don't think iron-core transformer will be big. But no way it can fit within 40x40x80mm, may be just the control circuitry, without transformer.
  • Also its not possible to connect 3 x 10VA transformers to get 30VA without proper syncing. Much simple if you use single 30VA transformer.
  • For 50Hz output, LP filter at output is nearly always bulky, but that also depends on its power rating. With 25W(110mA) it won't be that big.
Do you really need sine wave ? What THD is acceptable ? Is push-pull inverter output (stepped sine wave/square wave) acceptable ?
sam_des
sohel
-Given: 167
-Receive: 149
« Reply #10 on: July 23, 2014, 07:04:26 19:04 »
Dear,
sample picture will help to understand. i think you need like that.
« Reply #11 on: July 24, 2014, 12:44:19 12:44 »
were you the one who made this?
sohel
-Given: 167
-Receive: 149
« Reply #12 on: July 24, 2014, 01:20:51 13:20 »
it was a prototype which design by me.
DreamCat
-Given: 223
-Receive: 116
« Reply #13 on: July 26, 2014, 06:54:01 06:54 »
Dear,
have two H bridge?
« Reply #14 on: August 03, 2014, 12:18:58 12:18 »
Thanks to all who give their words, but as the chance to get this project is getting smaller then i decide to put in on bottom stack of my priority for now  Wink.
Solutions buddy usually complaint if the OP did not tell the real application of the question, so here is some description.
It is a small UPS for 220VAC 18Watt TL LED lamp, the circuit and the battery (NiMH) need to be fit on the lamp housing - this kind of device required on standard safety of high rise buildings - all lamp on emergency exit path need to have a backup power. I do have a sample of commercial product on my hand, it is a "conventional" dual conversion type - too complicated and expensive for it's usage in my thought. But it is now on my bench drawer  Grin.
zac
-Given: 81
-Receive: 57
« Reply #15 on: August 11, 2014, 05:35:52 17:35 »
If you're providing backup power to an LED lamp, wouldn't it be simpler and more energy efficient to do the backup in DC mode and skip the inverter by using an LED lamp that can run from DC?
« Reply #16 on: August 13, 2014, 04:19:26 16:19 »
That is very true, the best place to put the backup power is on the led driver circuit itself. But on this project, that part (led + driver) already taken by the big player - what i can think of is to add a kind of add on module to their product without modifying it.
-ichan.
alien
-Given: 30
« Reply #17 on: August 18, 2014, 10:48:13 10:48 »
I think in your case you should use either a simple PWMed square wave inverter (iron Core transformer) or another simple solution could be a simple DC > DC step up converter (High Freq/Ferrite core transformer) as here you are feeding a LED driver which itself is a SMPS and will accept DC as input.
zac
-Given: 81
-Receive: 57
« Reply #18 on: August 20, 2014, 03:51:42 03:51 »
Keep in mind that the square wave can cause annoying buzzing sounds that may or may not be tolerable.  If it only occurs during emergency backup mode, it may be acceptable, but a constant buzzing would probably will not be.
alien
-Given: 30
« Reply #19 on: August 23, 2014, 08:03:03 08:03 »
I don't think that buzzing sound from a 50 Hertz square wave inverter will be too much given the transformer is tightly wound and its laminates are also clamped well... BUT still the best and cheap solution will be a step-up DC>DC converter and that too open loop ( transformer output voltages needs to carefully selected so that the output do not shoot too much high when battery is at its full potential) .Open loop output with some 2-3 % dead time will also help in reducing output capacitor ...... this could be the best and cheap solution.
« Reply #20 on: August 23, 2014, 09:51:07 21:51 »
Many commercial led driver these days are "Triac Dimmable", they monitor the sine wave of ac input and looking for the phase angle switching by triac for dimming the led. Square wave ac will fooled this kind of led driver.
DreamCat
-Given: 223
-Receive: 116
« Reply #21 on: October 02, 2014, 12:48:38 12:48 »
I found a cheap IC, EG8010, from egmicro. for Pure Sine Wave inverter. only 5 RMB/PCS.
they also selling  EG8010+IR2110 driver module, 25 RMB.  you can search it on alibaba.
« Reply #22 on: October 04, 2014, 04:21:50 16:21 »
That is interesting, thanks.
Is there documentation in english?
DreamCat
-Given: 223
-Receive: 116
« Reply #23 on: October 06, 2014, 02:16:47 14:16 »
sorry, there is only a Chinese PDF file can be download.
but if you realy need it, and you can wait a long time, I can do some translating work in this PDF file.
Signal
-Given: 113
-Receive: 81
« Reply #24 on: October 06, 2014, 03:42:43 15:42 »
It seems that there is still no official English version of EG8010 datasheet. I found one attempt to translate it to Russian and one to English using Google translator. For latter follow the link http://www.edaboard.com/thread279936.html.
I didn't check this file but MAXPAYNE probably did (though he was disappointed in one made by his own http://www.sonsivri.to/forum/index.php?topic=50784.0 ) .
Pages: [1] 2  All
