December 24, 2024, 04:23:59 16:23
Author Topic: Modbus Sniffing with PC  (Read 6372 times)
luca_l
« on: January 11, 2008, 09:23:30 21:23 »
hi
I'm studying about Modbus.
I would like to see on a PC the data from a pic
with Modbus (programmed with CCS)
I  tried with the file suggested by Trump:  Roll Eyes
http://rapidshare.com/files/77291978/Modbus.rar.html
and some other:
http://www.modbus.pl/MTester.htm
http://www.modbustools.com/
 Cry in all the cases I can't read the  data.  Cry
obviously the configuration's parameters are identical
on both devices, PC and Pic
thanks  for every help
Luca
ucanturk
-Given: 17
« Reply #1 on: January 12, 2008, 09:09:04 09:09 »
Luca,
Try with this master software for Modbus RTU.
http://mihd.net/ohfnyp
No need to install, just copy into a folder and use. Enjoy!
anhdt
-Given: 50
-Receive: 42
« Reply #2 on: January 14, 2008, 01:48:32 01:48 »
You can use DAQFactory to test your devices, DAQFactory (Modbus Scanner) is free, and very powerful, this is link:
http://www.azeotech.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=27&nav=0&gclid=CNSa563N9JACFRcjewodjCcNsA
luca_l
« Reply #3 on: January 15, 2008, 08:05:03 20:05 »
thank you very much for your help!
After various test done with all software, and using different firmware on pic
only http://mihd.net/ohfnyp  works correctly!  Roll Eyes
all configurations are identical
  Huh I don't understand the cause for that.  Huh
Luca
anhdt
-Given: 50
-Receive: 42
« Reply #4 on: January 16, 2008, 08:42:47 08:42 »
Maybe, you do something Wrong, DAQFactory is a very cool and Powerful for testing modbus devices, DAQ is industrial standard
luca_l
« Reply #5 on: January 17, 2008, 08:07:26 20:07 »
dear Anhdt
Probably you are  rightEmbarrassed
I think that all depends what says modbus.c
but my doubt:
  Huh Is it  possible to find various modbus dialects??  Huh
cheers
Luca
strolch
« Reply #6 on: January 29, 2008, 03:35:42 15:35 »
I think there are two Modbus-Dialects.
ASCII and RTU
Don't use ASCII
In the CSS-Forum Neutone has made a fine Modbus-Software
Michael
Posted on: January 29, 2008, 04:32:25 16:32 - Automerged
I use the Tools from modbustools.com. They are fine. You see everything with this software!
yangzy
« Reply #7 on: January 30, 2008, 12:23:35 00:23 »
On this site You can find modbus program  examples
