April 30, 2025, 10:42:44 10:42
Author Topic: 12 to 16 V converter  (Read 6025 times)
mrnitigon
« on: January 08, 2008, 05:20:34 05:20 »
hi
   who have 12 to 16 V 3A converter i want to use to charge my notebook by battery
Futterama
« Reply #1 on: January 08, 2008, 03:31:03 15:31 »
You can buy commercial 12V to 115V/230V converters. They are often called inverters. They will deliver the correct voltage for your notebook power supply. Also, you can use it for other things too - depending on why/what/where you want to recharge your notebook.
I'm sorry, I don't have a schematic for a DC voltage converter.
zawmintun1
-Given: 2169
-Receive: 26
« Reply #2 on: January 11, 2008, 03:44:24 15:44 »
Hi mrnitigon
Use MC34063
Next day I'll upload for u from EPE Mag 2002
tango
-Given: 28
« Reply #3 on: January 11, 2008, 08:59:17 20:59 »
Get from Internet LT1071 datasheet and make it.
I was make and it work 100% good.
I was get idea from one fabric supply 12 to 16V for toshiba laptop what i was service.
Simple I was clone it and after that I was download datasheet and from that moment
I only use it for connverters DC to DC.
You will have 3 amp without external power transistor !
EIB_Controller
« Reply #4 on: January 13, 2008, 09:53:07 09:53 »
This is one way to do it
http://www.elektor.com/magazines/2006/january/95-watt-laptop-psu-adaptor.58015.lynkx
borberk
-Given: 309
-Receive: 598
« Reply #5 on: January 13, 2008, 10:09:26 10:09 »
Here is the article for 12-19V/5A converter. It can be modified for lower output voltage.
http://rapidshare.com/files/83423173/12-19E.pdf
sam8240
« Reply #6 on: January 13, 2008, 01:35:13 13:35 »
how to make dual power supply from 12v battery
koky
-Given: 160
-Receive: 157
« Reply #7 on: January 13, 2008, 02:30:41 14:30 »
you can find it 12V input , with universal voltage out and universal connector at less than 2,00 € on ebay  (search for "notebook car adapter")
Devil_electric
« Reply #8 on: January 13, 2008, 10:49:15 22:49 »
TOPSwitch is easy to design
mrnitigon
« Reply #9 on: February 16, 2008, 03:26:10 03:26 »
hi all thank you for all help to me
jenya7
-Receive: 16
« Reply #10 on: February 23, 2008, 11:59:37 11:59 »
Try this circuit. Play with duty to get 16v under load.
You may add load resistor to avoid open circuit voltage jump.
« Last Edit: February 23, 2008, 12:03:22 12:03 by jenya7 » Logged
