April 01, 2025, 11:06:20 23:06
Top
HI-TECH Universal RSA Keygen
* HI-TECH Universal RSA Keygen generates real RSA signed activation data.
* Replaces HI-TECH RSA public key with self-generated RSA key - different every time!
* Generates permanent PRO key - no expiry date!
* Tested with:
  • HI-TECH C Compiler for PIC10-12-16 MCUs
  • HI-TECH C PRO for the PIC18 MCU Family
  • HI-TECH C PRO for the PIC32 MCU Family
  • HI-TECH for dsPIC-PIC24
  • HI-TECH C PRO for the Silicon Labs 8051 MCU Family
  • HI-TECH C PRO for the PSoC Mixed-Signal Array
  • HI-TECH C for Holtek MCU
  • HI-TECH PICC-18 STD
* New in version 2.2
* New in version 2.3
HI-TECH Universal RSA Keygen (v2.0)
http://depositfiles.com/files/kj9mws7yh
HI-TECH Universal RSA Keygen (v2.1)
http://depositfiles.com/files/oy699bhti
HI-TECH Universal RSA Keygen (v2.2)
http://depositfiles.com/files/2mhscdmb4
HI-TECH Universal RSA Keygen (v2.3)
http://depositfiles.com/files/v6vup2azq
You can find 50caliber post here, the older sticky:
http://www.sonsivri.com/forum/index.php?topic=935.msg69111#msg69111
« Last Edit: June 24, 2010, 01:52:07 13:52 by Top »
Pages: 1 ... 12 13 14 15 16 17 18 [19]
Author Topic: Hi-Tech PIC Compiler latest versions  (Read 590135 times)
Okada
-Given: 29
-Receive: 188
« Reply #450 on: January 21, 2013, 03:18:41 03:18 »
I have attached the project file which creates wrong hex files when Preprocess assembler and Assembler is checked before compiling. See the comment in the .rar file.
Top
-Given: 52
-Receive: 1719
« Reply #451 on: January 21, 2013, 09:04:42 09:04 »
That code is working; please send the code that is not working.
Okada
-Given: 29
-Receive: 188
« Reply #452 on: January 21, 2013, 09:18:24 09:18 »
good hex
http://uppit.com/3q9shep1egc9/uart1_good_hex.rar
wrong hex
http://uppit.com/2s3abzydzc36/uart1_wrong_hex.rar
Top
-Given: 52
-Receive: 1719
« Reply #453 on: January 21, 2013, 10:21:46 10:21 »
Check the listings for your delay_lcd() function; the 'wrong hex' optimization settings have made it shorter so your ENABLE pulse is too fast for your display. Solution: Change your delay_lcd() function.
wolfienuke
« Reply #454 on: January 20, 2014, 02:58:53 02:58 »
Just for any other Mac users (I know there are a few out there) having issues with HT_Keygen, I compiled a quick binary patcher to apply the generated RSA key to any file that contains the old RSA key. This should work for any HI-Tech compilers that HT_Keygen supports. I decided to do this on a whim, when I found myself doing way too many find and replace searches manually.
This does a simple binary find and replace, and only does simple cursory checks to ensure that the RSA keys look valid.
I can post the source if anyone is interested, and I would definitely incorporate HT_Keygen if I could find the source for it.
Executable is compiled for Mac OS 10.6+ Universal, but I only tested on 10.9.
Instructions:
Download and unzip posted file.
Run "chmod +x" on executable if required
Run "./HI-TECH_Hacktivate /path/to/old/activate.dat /path/to/new/activate.dat /path/to/bin/folder/"
« Last Edit: January 20, 2014, 05:24:44 05:24 by wolfienuke » Logged
wolfienuke
« Reply #455 on: February 27, 2014, 10:19:15 22:19 »
A couple people have asked me to explain how to use the program I posted above...
1. Install the Hi-Tech compiler you wish to install. Take note of the install path and the serial number.
2. Open Terminal.
3. Run "HT_Keygen" and provide the serial number. This provides a new RSA encryption key.
4. Run "./HI-TECH_Hacktivate /path/to/old/activate.dat /path/to/new/activate.dat /path/to/bin/folder/". This performs a patch on all binary files to replace the old RSA key with the new one.
5. Replace activate.dat and keyfile.dat in bin folder with the ones created by HT_Keygen.
6. Change the current directory to the bin folder. Run "cd $/path/to/bin/folder/".
7. Run "activate --keyfile=keyfile.dat --serial=$YOUR_SERIAL_NUMBER"
8. Run "picc --ver" (or whichever pic compiler you are using). It should say "Pro" if you performed the above tasks correctly.
This works on all versions.
Unhappy
-Given: 1006
-Receive: 101
« Reply #456 on: March 21, 2014, 09:23:21 21:23 »
@ Top
Kindly update the RSA keygen 2.3 download link
-Given: 841
-Receive: 4364
« Reply #457 on: March 21, 2014, 09:29:37 21:29 »
@ Top
Link in sticky is still working.
Unhappy
-Given: 1006
-Receive: 101
« Reply #458 on: March 21, 2014, 10:13:58 22:13 »
Maybe it is not working in my country, anyway shall try again in the morning, If someone can still provide other D/L will be appreciated
-Given: 841
-Receive: 4364
« Reply #459 on: March 21, 2014, 11:14:06 23:14 »
RSA keygen 2.3 http://ul.to/xgyr5mbn
ceedjay
« Reply #460 on: August 24, 2014, 09:18:52 09:18 »
Im trying to find a working link to the linux keygen but all links i have found so far are dead. Does anyone know where i can download the linux keygen 1.0 or newer?
« Last Edit: August 24, 2014, 09:47:04 09:47 by ceedjay » Logged
folkeu
-Given: 129
-Receive: 324
« Reply #461 on: January 13, 2018, 05:04:00 17:04 »
Where can I find the last HI-TECH C Compiler to download ?
mitsos
-Given: 3155
-Receive: 4778
« Reply #462 on: January 13, 2018, 05:07:58 17:07 »
hi
here:
http://ftp://Compilers-RO:C0mP[email protected]/
mitsos
Marcustv
-Given: 198
-Receive: 14
« Reply #463 on: June 16, 2019, 06:25:19 18:25 »
The link no work
Can you reupload ?
giappolo
-Given: 1710
-Receive: 620
« Reply #464 on: June 16, 2019, 06:47:11 18:47 »
Link is working,
delete "http://" from address
CHJAY
-Given: 506
-Receive: 169
« Reply #465 on: June 17, 2019, 07:24:46 07:24 »
This link used to work, but now this link is redirected to "http://ftp://ftp.microchip.com/" and there is no HITECH compilers on this site.
It seems like ID & PASSWORD is expired.
Go to HI-TEC archive page, and enter your ID and PASSWORD. If you don't have one, create a new one.
https://www.microchip.com/development-tools/pic-and-dspic-downloads-archive
« Last Edit: June 17, 2019, 07:34:14 07:34 by CHJAY » Logged
tavioman
« Reply #466 on: June 17, 2019, 08:42:21 08:42 »
The link no work
Can you reupload ?
The link works just fine.
- Brain juice -
Magnox
-Given: 990
-Receive: 285
Oink!
« Reply #467 on: June 17, 2019, 01:27:17 13:27 »
lol - the link works. But... copy it manually (highlight it all and click Copy, not Copy Link). Them remove the http part. Copying the link with Copy Link Location confuses the browser.
ron
-Given: 12
-Receive: 21
« Reply #468 on: June 26, 2020, 08:35:27 08:35 »
The reason for the confusion is because if you login from some countries like India it shows you only two folders with no real files.
It does not matter what password you use. Or what link format.
The solution is to use a VPN.
I was finally able to get in using the Opera Browser and an American VPN.
Using the same Userid and password and link provided. I can confirm the user id and password still work. As does the link. Just some countries have been blocked. And re-directed to a dummy folder.
« Last Edit: June 26, 2020, 10:50:23 10:50 by ron » Logged
zelea2
-Given: 8
-Receive: 184
« Reply #469 on: June 14, 2021, 07:23:06 19:23 »
This is a re-release of the latest version HiTechC Optimizing Compilers.
They have been discontinued after the company acquisition by Microchip.
I think they are still relevant today especially with a makefile and they
don't come bloated with the MPLAB X IDE.
The remote activation is not possible anymore because the servers for
this have been long gone. I've re-written the HiTechC-Activate program
which replaces the RSA key-pair and does the activation completely offline.
The installer will automatically patch and activate the compiler which will be
ready to use with all the optimizations enabled straight away.
danymogh
-Receive: 24
« Reply #470 on: June 15, 2021, 05:05:57 05:05 »
what is the advantage to the alread released RSA keygen v2.3? that one also activates it offline.
zelea2
-Given: 8
-Receive: 184
« Reply #471 on: June 15, 2021, 05:50:21 05:50 »
I don't know about that particular version, but the one that I had required servers and a complicated
activation, so I've written my own which does everything automatically.
Thiru09
-Given: 398
-Receive: 1188
« Reply #472 on: June 15, 2021, 01:25:41 13:25 »
danymogh is referring to the great work of TOP, details are in sticky post.
No matter what, your work is good and keep it up.
Thiru
