April 03, 2025, 06:38:00 18:38
Top
HI-TECH Universal RSA Keygen
* HI-TECH Universal RSA Keygen generates real RSA signed activation data.
* Replaces HI-TECH RSA public key with self-generated RSA key - different every time!
* Generates permanent PRO key - no expiry date!
* Tested with:
  • HI-TECH C Compiler for PIC10-12-16 MCUs
  • HI-TECH C PRO for the PIC18 MCU Family
  • HI-TECH C PRO for the PIC32 MCU Family
  • HI-TECH for dsPIC-PIC24
  • HI-TECH C PRO for the Silicon Labs 8051 MCU Family
  • HI-TECH C PRO for the PSoC Mixed-Signal Array
  • HI-TECH C for Holtek MCU
  • HI-TECH PICC-18 STD
* New in version 2.2
* New in version 2.3
HI-TECH Universal RSA Keygen (v2.0)
http://depositfiles.com/files/kj9mws7yh
HI-TECH Universal RSA Keygen (v2.1)
http://depositfiles.com/files/oy699bhti
HI-TECH Universal RSA Keygen (v2.2)
http://depositfiles.com/files/2mhscdmb4
HI-TECH Universal RSA Keygen (v2.3)
http://depositfiles.com/files/v6vup2azq
You can find 50caliber post here, the older sticky:
http://www.sonsivri.com/forum/index.php?topic=935.msg69111#msg69111
« Last Edit: June 24, 2010, 01:52:07 13:52 by Top »
Pages: 1 ... 7 8 9 10 11 12 13 [14] 15 16 17 18 19
Author Topic: Hi-Tech PIC Compiler latest versions  (Read 590327 times)
microtech
-Receive: 16
« Reply #325 on: April 03, 2010, 02:10:09 14:10 »
Hi All,
 Is there any working files for this software
1- HCPIC-pro-9.70
2-HI-TECH PICC PRO 9.70 Patcher
Thanks..
greybeard
« Reply #326 on: April 04, 2010, 11:08:48 11:08 »
hi
has anyone else used the z80 7.80pl2 compiler?
I've tried running it and get an 'compiler not installed properly' error.
have tried altering the creation date of the hidden files under the /lib directory but haven't been succesful.
gb
Sepiroth
« Reply #327 on: April 06, 2010, 09:24:07 09:24 »
Hi all,
I've read that PICC18 Pro 9.63 PL3 has many bugs, which version of C18 Pro is better to use?
-sepiroth >_>
bunion
-Receive: 4122
« Reply #328 on: April 07, 2010, 01:03:49 01:03 »
Hi Caliber,
HI-TECH PICC PRO 9.70.rar (5.53 MB)   http://www.multiupload.com/AE7BMBILM7
is this realy working?, I have installed this using the patch, but it's show only lite mode. nor PRO.
Please help if anybody try this software. thanks.
hi
gb
will check both and report back
bunion
greybeard
« Reply #329 on: April 07, 2010, 01:09:44 01:09 »
bunion
I've since been in contact with aplank and the original z80 package works ok. From what I can see the original package modifies the install program and you do an install rather than copying the installed packages. HTH
bunion
-Receive: 4122
« Reply #330 on: April 09, 2010, 11:41:27 23:41 »
so ur sorted then?...or do u want the patched installer that installs without pass...you got that or will i get it 4 u?
bunion
greybeard
« Reply #331 on: April 09, 2010, 11:49:30 23:49 »
bunion
I've got what I need thanks.
However I believe that the package for the z80 compiler that has been released as part of the platinum package has issues and isn't working. Someone else trying to use it could have the same problem. I don't have a 100% understanding of how the installation checks for a correct install but I'd suspect that there is something either machine specific and/or time specific that hasn't been bypassed.
Top
-Given: 52
-Receive: 1719
« Reply #332 on: April 17, 2010, 04:04:05 16:04 »
* Tested with:
« Last Edit: June 24, 2010, 01:52:07 13:52 by Top » Logged
mitsos
-Given: 3158
-Receive: 4778
« Reply #333 on: April 18, 2010, 04:42:57 16:42 »
hi
is that possible to add, in the last rsa keygen, support for picc18 std v9.51pl2 compiler?
mitsos
Top
-Given: 52
-Receive: 1719
« Reply #334 on: April 18, 2010, 07:46:03 19:46 »
HI-TECH Universal RSA Keygen v2.1 now works with this compiler!
>picc18 --ver
HI-TECH PICC-18 STD COMPILER (Microchip PIC micro)  V9.51PL2
Copyright (C) 1984-2008 HI-TECH SOFTWARE
Serial number: HCPIC18-654321
mbandala
-Given: 130
-Receive: 305
« Reply #335 on: April 29, 2010, 04:36:05 16:36 »
>picc18 --ver
Will it work with the linux versions?
Top
-Given: 52
-Receive: 1719
« Reply #336 on: April 29, 2010, 07:48:21 19:48 »
No, only Windows!
bunion
-Receive: 4122
« Reply #337 on: May 01, 2010, 06:35:59 18:35 »
You cant beat the keygen approach , NICE JOB Smiley
microtech
-Receive: 16
« Reply #338 on: May 02, 2010, 01:36:36 01:36 »
* Tested with:
* New v2.1 detection algorithm should work with even more compilers.
Hi, Please upload in rapidshare or other sites, cannot download from depositefiles.com. Thanks
Top
-Given: 52
-Receive: 1719
« Reply #339 on: May 11, 2010, 03:28:09 15:28 »
HI-TECH Universal RSA Keygen for LINUX
* Tested on Ubuntu Linux 9.04 with:
  • HI-TECH for dsPIC/PIC24
  • HI-TECH C Compiler for PIC10/12/16 MCUs
  • HI-TECH PICC-18 STD COMPILER
HI-TECH Universal RSA Keygen for LINUX (v1.0)
http://depositfiles.com/files/f25aamcnr
vovchik02
-Given: 43
« Reply #340 on: May 12, 2010, 06:29:29 06:29 »
mirror
http://rapidshare.com/files/386307332/HI-TECHv2.1.rar.html
MD5: 344683215A92E2C498B4040316A1C6C7
http://rapidshare.com/files/389420103/HI-TECHv2.2.rar.html
MD5: FD229A03C6F59202D303B6DDD9D83ACD
« Last Edit: May 20, 2010, 05:56:49 05:56 by vovchik02 » Logged
cjq_sh
« Reply #341 on: May 13, 2010, 04:01:34 16:01 »
Will it work with the win7(64bit) versions?
I tested it, still in lite mode?
Top
-Given: 52
-Receive: 1719
« Reply #342 on: May 13, 2010, 05:12:27 17:12 »
If you have 64-bit versions of the compilers then please upload them!
If you are having problems activating the 32-bit versions on a 64-bit OS then please post the output from the keygen. I've tested the keygen on Windows 7 (64-bit) and it worked without problem. You must start with a clean install of the compiler; if you have applied any other patches then re-install the compiler.
« Reply #343 on: May 13, 2010, 06:54:07 18:54 »
May be he has to run the keygen as an administrator, it writes the registry, and must be running as administrator.
Top
-Given: 52
-Receive: 1719
« Reply #344 on: May 13, 2010, 08:12:29 20:12 »
It shouldn't run without elevated priviledges; in the manifest "requireAdministrator".
cjq_sh
« Reply #345 on: May 15, 2010, 03:24:17 15:24 »
I re-tested it as you say, but ...
Top
-Given: 52
-Receive: 1719
« Reply #346 on: May 15, 2010, 04:37:56 16:37 »
Very strange; I tested on Windows 7 64-bit and results are below.
Maybe this is a language issue; you are not using english Windows 7?
Things to try:
1. Restart MPLAB; you need to restart MPLAB for changes in compilers to show.
2. Open a command prompt and type (maybe adjust for your language):
"C:\Program Files (x86)\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18" --ver
Post result.
3. Open registry and check
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HI-TECH Software\PICC-18\PRO\9.63
Do you see Activation and SerialNo keys?
cjq_sh
« Reply #347 on: May 17, 2010, 02:28:13 14:28 »
I tested it both in Chinese Language Windows XP&Win7(64bit).
It is Ok in XP, It is not in win7(64bit).
In win7(64bit), I tested Picc-v8.05PL2 and picc18-v8.35PL3, They works well.
cjq_sh
« Reply #348 on: May 18, 2010, 03:30:18 15:30 »
Thank you very much TOP.
I tested v2,2, it is still in lite mode.
DrSurfer
-Given: 27
« Reply #349 on: May 18, 2010, 07:22:03 19:22 »
I've tested 2.1 on a win7-64 italian and PICC 9.70PL0 and it worked perfectly, activated in pro mode.
BTW, where is the 2.2 version?
« Last Edit: May 19, 2010, 06:47:51 06:47 by DrSurfer » Logged
