bunion
-Receive: 4122
« Reply #250 on: December 13, 2009, 08:29:35 20:29 » |
allpic maybe why your results are bigger is because your startup options differ from mines i think
yours
;Licensed for evaluation purposes only. ;This licence will expire on Sun, 31 Jan 2010
; Auto-generated runtime startup code for final link stage.
; ; Compiler options: ; ; -oSteperMotorDriver.cof -mSteperMotorDriver.map --summary=default \ ; --output=default delay.p1 main.p1 --chip=16F886 -P --runtime=default \ ; --opt=default -D__DEBUG=1 -g --asmlist \ ; --errformat=Error [%n] %f; %l.%c %s --msgformat=Advisory[%n] %s \ ; --warnformat=Warning [%n] %f; %l.%c %s ;
mines
;Serial no. HCPICP-35553
; ; Compiler options: ; ; -otry7.cof -mtry7.map --summary=default --output=default delay.p1 \ ; main.p1 --chip=16F886 -P --runtime=default \ ; --opt=default,+asm,-debug,-speed,+space,9 --warn=0 --addrqual=ignore \ ; -g --asmlist --errformat=Error [%n] %f; %l.%c %s \ ; --msgformat=Advisory[%n] %s --warnformat=Warning [%n] %f; %l.%c %s ; yours not showing "space,9" amongst others...9 is highest optimisation codewise
bunion
ALLPIC
-Receive: 72
« Reply #251 on: December 14, 2009, 03:01:26 03:01 » |
too good I made clean project rather than just changing compiler driver and now it is showing 18.9%  )
bunion
-Receive: 4122
« Reply #252 on: December 14, 2009, 04:14:54 04:14 » |
ok
HI-TECH PICC PRO 9.70 added to storage for testing puposes...no expiry
report back if its working corrrectly
bunion
Manuel
-Given: 703
-Receive: 194
« Reply #253 on: December 14, 2009, 10:01:30 10:01 » |
Bunion, Reg Missing?
M!
raham
« Reply #254 on: December 15, 2009, 02:05:47 02:05 » |
working in Lite mode,Missing Reg file. Raham
« Last Edit: December 15, 2009, 02:12:39 02:12 by raham »
bunion
-Receive: 4122
« Reply #255 on: December 15, 2009, 03:11:06 03:11 » |
yep sorry about that forgot to add regfile...sorry:(..ok added  bunion
bunion
-Receive: 4122
« Reply #256 on: December 16, 2009, 05:25:11 17:25 » |
noones come back and moaned about it not working so im GUESSing its working ok?
Remember folks i added it as a tester meaning u gotta come back and report if its working or not!
bunion
Manuel
-Given: 703
-Receive: 194
« Reply #257 on: December 16, 2009, 06:57:17 18:57 » |
it's ok, but generated code as advanced....is not so optimized....in both code and ram. (this is not your fault)
take care Bunion.
Manuel
robban
-Given: 34
-Receive: 38
Warrior
« Reply #258 on: December 17, 2009, 03:45:49 03:45 » |
bunion
I must say, bunion, that You have put in a lot of effort regarding C-compilers and other stuff. I take my imaginary hat off for You, and I think it goes for the rest of this community. Keep on truckin' Regards robban
Code Warrior
DrSurfer
-Given: 27
« Reply #259 on: December 17, 2009, 01:03:01 13:03 » |
here the result of my first test, very same sources, compiler and link settings. compiler 9.65PL1: Program: 1225 words (59.8%) Data: 77 words (60.2%) compiler 9.70PL0: Program: 1179 words (57.6%)  Data: 76 words (59.4%) My program works as expected and, as an additional bonus, with 9.70 I can remove my workaround for "(s)printf-in-files-different-from-the-one-with-main()" bug  DrS
Mr. Spock
-Given: 475
-Receive: 827
« Reply #260 on: December 17, 2009, 08:03:29 20:03 » |
Hi Bunion
Do you have the patch for the latest version of PIC32 compiler ?
REgards
ALLPIC
-Receive: 72
« Reply #261 on: December 20, 2009, 04:06:42 16:06 » |
Things also working for me now. Good thanks very thanks
ppa88
-Given: 49
-Receive: 131
« Reply #262 on: December 28, 2009, 05:15:47 05:15 » |
I apologize with all my heart for having got carried away in an effort to help someone. I promise to be extra careful in future.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #263 on: December 29, 2009, 01:09:48 01:09 » |
I don't know where You reside, maybe on desolation row, come on, let's have a gas, it's almost New Year, and we can all celebrate. Soon it will be a new year and then we will all get back to normal(whatever that will be).Cheers from robban...
« Last Edit: December 29, 2009, 08:41:57 08:41 by Wizpic »
Code Warrior
-Given: 561
« Reply #264 on: December 29, 2009, 08:41:04 08:41 » |
You don't need to apologize for helping someone  I don't know where You reside, maybe on desolation row, come on, let's have a gas, it's almost New Year, and we can all celebrate. Soon it will be a new year and then we will all get back to normal(whatever that will be).Cheers from robban...  Did you miss reading the Rule about new year ? ALOS LET THIS BE A WARNING TO EVERYONE WE DONOT LIKE WARS HERE SO DON'T START ONE
picaboo
-Given: 11
« Reply #265 on: December 29, 2009, 12:19:55 12:19 » |
Guys, I am having hard luck installing PICC. First, I could not use v9.65 because my Symantec is saying that universal patcher has trojan. Now I tried to install v9.70. I am not seeing the application in the menu after installation. When I start the installation, the flash screen does not say it is PRO version. I hope it is fine.  Step 1 in Readme1st.txt says: INSTALL OFFLINE as PRO USING XXXXX. The selection screen says PRO/STD. So I do not know how to choose only PRO mode. I did this (I masked the serial number in the screenshot. I used the number from Readme1st.txt),  Hope the above is correct. In the next to next screen, the default installation path is shown as,  Note that the path does not contain "PRO" or "STD". It simply contains "PICC/9.70" In the next screen I selected the "Add to enc path" box. The files are copied by the installer. Then the last screen comes, where " Email Now" button is shown. I click on the " Finish" button. So far I have not applied the patch. This is clean " offline" installation. When I try to start the application, I do not see the application in the menu.  I thought that since the application has not been activated, it is not showing up in the start menu. Then I ran the patcher and chose the files (mentioned in the readme1st.txt) using the browse button. It reported success (23 bytes written for each file). Then I double clicked on the file mentioned in readme1st.txt. This also returned success. But I still do not see the application in the start menu.  Now if I click on the "Activate or trial PRO mode", the following screen appears.  Note that the serial number is different than what I entered. This serial number appears in registry. What did I do wrong?
-Given: 841
-Receive: 4365
« Reply #266 on: December 29, 2009, 01:26:49 13:26 » |
Yes your doing something wrong  try selecting right version to install
alien
-Given: 30
« Reply #267 on: December 29, 2009, 03:10:09 15:10 » |
Dear picaboo, Yes its obvious that you will not see any application listing/icon in menu becuse this is a command line compiler...you should first learn how to use command line tools or use some Integrated Development Enviornment(IDE) like Mplab IDE from microchip or Hitechs own HI-TIDE IDE...these IDEs will act as graphical interface for your hitech c compiler...as u have already mentioned that patch returned success message then your compiler is ready to use and its fully functional now,hope this all helps.
« Last Edit: December 29, 2009, 03:12:14 15:12 by alien »
pirvcb
-Given: 147
-Receive: 245
« Reply #268 on: December 29, 2009, 03:31:54 15:31 » |
Also you can set up Flowcode to use HI-TECH compiler instead BOOST C compiler bundled with it.
picaboo
-Given: 11
« Reply #269 on: December 30, 2009, 01:19:25 01:19 » |
Pickit, that was exactly my point. Your screenshot show the word "PRO" for v9.60. But my screenshot does not show that, though bunion's .rar file is named PICC PRO v9.70.
Posted on: December 30, 2009, 02:14:24 02:14 - Automerged
Alien,
Thanks a lot. I am used to MicroElectronika which has its own IDE. I was expecting PICC to be same. After reading your post I did some more reading online and now I think i understand how to do it with MPLAB. I will try this today.
bunion
-Receive: 4122
« Reply #270 on: December 31, 2009, 03:22:47 03:22 » |
See attachment for new storage details
...remember its private!!!
bunion
ALLPIC
-Receive: 72
« Reply #271 on: December 31, 2009, 04:31:47 04:31 » |
picaboo
I think you are useing Hi-tech first time. You will never see any application after installing Hi tech compiler. Hi-tech compiler is always linked with MPLAB. If you not like MPLAB then install HTIDE.
sittichoke
-Given: 8
« Reply #272 on: January 01, 2010, 02:58:00 02:58 » |
bunion
could you tell about password on another file?. thanks you
sittichoke
kiashee
-Given: 80
« Reply #273 on: January 02, 2010, 04:18:36 04:18 » |
bunion
sittichoke
Hi... were you able to look the inside of it? or my guess, you can't download it, right?
bunion
-Receive: 4122
« Reply #274 on: January 02, 2010, 09:35:19 21:35 » |
Theres no passes on any of the latest stuff so u must be using an older pacl like hitech enterprise pack..if so the passwords are all covered in this topic so take some time and look thru posts or use common sense and guess its either sonsivri , Sonsivri , Sonsivri.com or bunion
bunion
