Can some one help me!!!!!
simple code in ht-tech picc 9.60 pl6
#include <pic.h>
#include <stdio.h>
#include <stdlib.h>
char str[10];
void main(void)
float a=1.1234;
sprintf(str,"%0.1f",a);
gating error
HI-TECH C PRO for the PIC10/12/16 MCU family candidate build 4070 V9.60PL6
Copyright (C) 1984-2009 HI-TECH SOFTWARE
Serial number: HCPICP-36668
this licence will expire on Wed, 12 Dec 2029
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\doprnt.c; 1217. fixup overflow storing 0x14F in 1 byte at 0x16BC (VAF.obj 171/0x1E)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\doprnt.c; 1217. fixup overflow storing 0x14E in 1 byte at 0x16BE (VAF.obj 171/0x20)
Error [1268] VAF.obj; 188. fixup overflow storing 0x12D in 1 byte at 0x1828 (VAF.obj 188/0x24)
Error [1268] VAF.obj; 188. fixup overflow storing 0x12C in 1 byte at 0x182A (VAF.obj 188/0x26)
Error [1268] VAF.obj; 232. fixup overflow storing 0x11D in 1 byte at 0x1BBC (VAF.obj 232/0x1E)
Error [1268] VAF.obj; 232. fixup overflow storing 0x11C in 1 byte at 0x1BBE (VAF.obj 232/0x20)
Error [1268] VAF.obj; 265. fixup overflow storing 0x11D in 1 byte at 0x1E6C (VAF.obj 265/0x2)
Error [1268] VAF.obj; 265. fixup overflow storing 0x11C in 1 byte at 0x1E6E (VAF.obj 265/0x4)
Error [1268] VAF.obj; 265. fixup overflow storing 0x11D in 1 byte at 0x1E88 (VAF.obj 265/0x1E)
Error [1268] VAF.obj; 265. fixup overflow storing 0x11C in 1 byte at 0x1E8A (VAF.obj 265/0x20)
Error [1268] VAF.obj; 271. fixup overflow storing 0x121 in 1 byte at 0x1EF4 (VAF.obj 271/0x4)
Error [1268] VAF.obj; 271. fixup overflow storing 0x120 in 1 byte at 0x1EF6 (VAF.obj 271/0x6)
Error [1268] VAF.obj; 278. fixup overflow storing 0x121 in 1 byte at 0x1F8C (VAF.obj 278/0x1A)
Error [1268] VAF.obj; 278. fixup overflow storing 0x120 in 1 byte at 0x1F8E (VAF.obj 278/0x1C)
Error [1268] VAF.obj; 280. fixup overflow storing 0x121 in 1 byte at 0x1FAC (VAF.obj 280/0x4)
Error [1268] VAF.obj; 280. fixup overflow storing 0x120 in 1 byte at 0x1FAE (VAF.obj 280/0x6)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 434. fixup overflow storing 0x151 in 1 byte at 0x938 (VAF.obj 311/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 434. fixup overflow storing 0x150 in 1 byte at 0x93A (VAF.obj 311/0x2)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 437. fixup overflow storing 0x151 in 1 byte at 0x9B2 (VAF.obj 316/0x1C)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\lib\doprnt.c; 437. fixup overflow storing 0x150 in 1 byte at 0x9B4 (VAF.obj 316/0x1E)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x14F in 1 byte at 0xE00 (VAF.rlf 3609/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x14E in 1 byte at 0xE00 (VAF.rlf 3613/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x12D in 1 byte at 0xE00 (VAF.rlf 4244/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x12C in 1 byte at 0xE00 (VAF.rlf 4248/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 5886/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 5890/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 7074/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 7078/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11D in 1 byte at 0xE00 (VAF.rlf 7120/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x11C in 1 byte at 0xE00 (VAF.rlf 7124/0x0)
Error [1268] C:\Program Files\HI-TECH Software\PICC\PRO\9.60\sources\float.c; 55. fixup overflow storing 0x121 in 1 byte at 0xE00 (VAF.rlf 7324/0x0)
Advisory[1] too many errors (31)
what can be a problem
same thing happn in demo mode also even I downloaded new picc 9.65 the same errors I am gatting. As I can't ask hitech regarding this
can some one help me
