aamir
-Given: 37
-Receive: 229
« Reply #176 on: March 27, 2009, 05:07:00 05:07 » |
Please upload SPLIT file <50 MB ON RAPIDSHARE
tavioman
« Reply #177 on: March 27, 2009, 08:17:16 08:17 » |
Hey Bunion! Can you please tell what is the difference between HI-TECH Universal Patcher.rar and HI-TECH Universal Patcher_CURRENT.rar? Thanks!!
- Brain juice -
Manuel
-Given: 703
-Receive: 194
« Reply #178 on: March 27, 2009, 08:21:40 08:21 » |
Big One!
pozzolano
« Reply #179 on: March 27, 2009, 12:17:04 12:17 » |
Hi! for the other files such as HI-TECH Enterprise Edition.rar is required password password: www.sonsivri.com is not correct
bunion
-Receive: 4122
« Reply #180 on: March 27, 2009, 02:39:21 14:39 » |
sorry tavioman meant to delete current when i upped new patcher... "current" pack doesnt have the new key for picc 9.65 <<will delete aamir what ones u need and ill email them with unipatcher? pozzolano pass=bunions_carboot < think  Note... Universal patcher.exe didnt need updated as its still doing its job so only a new regfile was added for picc v9.65 pro Remember for small version changes like pl1 > pl2 > pl3 etc etc you can edit the key.reg yourselves by opening in notepad and changing the "pl" bits to suit any minor updates from hitech Latest PICC PRO v9.65 was a MAJOR version update thats why a new key was needed  bunion ill add a note next time i redo patch pack ps aamir theres singles in the storage place in case you forgot that
« Last Edit: March 27, 2009, 02:44:35 14:44 by bunion »
mitsos
-Given: 3158
-Receive: 4778
« Reply #181 on: March 28, 2009, 12:52:50 12:52 » |
hi bunion
can you explain us, what does mean the message "can't find pattern. trying next one..." that patcher displays. of course the compiler is working.
regards mitsos
bunion
-Receive: 4122
« Reply #182 on: March 28, 2009, 06:23:17 18:23 » |
Hi mitsos Current patcher is universal meaning it patches more than 1 program at a time, so when its running it'll scan through the exe looking for individual code patterns and if sucessfull it'll do its thing ,if not itll report back saying "pattern not found" and then proceed to look for the next pattern in the list This patcher patches %99 of ALL available Hitech compilers  bunion
bliviudaniel
« Reply #183 on: April 02, 2009, 09:34:44 21:34 » |
UPDATE...HCPIC-pro-9.65 has been added to the storage and uni patch updated:) I've just downloaded htbun3.rar but I can't find the update related to HCPIC-pro-9.65. Maybe I missed something or it's not inside htbun3.rar...Can somebody help me to find this update, please.
BLD
50caliber
-Given: 174
-Receive: 863
« Reply #184 on: April 03, 2009, 06:00:39 06:00 » |
I need to update the uploads, but have been busy. Try: http://www.rapidspread.com/file.jsp?id=kzbhutd1nnpass = www.sonsivri.comThis one contains only HCPIC-pro-9.65 and the patcher. Post back if there are any problems.
bliviudaniel
« Reply #185 on: April 03, 2009, 09:50:36 21:50 » |
I installed picc 9.65, I compiled and I simulated in MPLABSIM a simple task scheduler and everything seems to be OK
BLD
ALLPIC
-Receive: 72
« Reply #186 on: April 21, 2009, 05:01:26 05:01 » |
Dear 50caliber & bunion Can you please have a look on this, http://www.sonsivri.com/forum/index.php?topic=22189.new#new Because I also faced same problem. if you need I can upload my test code for that and we all can check and see is there problem because of crack or that is Hitech problem
50caliber
-Given: 174
-Receive: 863
« Reply #187 on: April 23, 2009, 06:33:45 18:33 » |
ALLPIC - I haven't had much time to test Bunion's work, but it is not uncommon to have minor incompatibilities between code compiled with v8 and v9. I think best way to verify whether problems exist in Bunion's versions is to install a legitimate trial on a virgin VM running XPSP3. It is always possible for HT to implement a hidden reg check.
twonuts
-Given: 55
-Receive: 42
« Reply #188 on: May 07, 2009, 10:23:38 10:23 » |
Is there an alternative patcher program for the enterprise edition? Windows XP SP3 won't allow access to the existing one. I have tried with disabled firewall, antivirus, etc, and updated files from the archive file with these disabled. Same result. Telling Windows to run the patcher as administrator does not work either. The same result with all copies of patcher programs in the archive.
AVG reports Gamer trojan in the patchers? False result?
bunion
-Receive: 4122
« Reply #189 on: May 07, 2009, 04:17:31 16:17 » |
twonuts pather was made using dup 2 which is old way for me now asany patches made with it r reported as viruses so ill make new patch using codefusion patcher 3 ok  ALLPIC , upload your test code and the results u get using valid demo AND results using patcher and we will sort it  BUT to be honest i think its working ok bro..any faults will be ur xp3 etc and not any protections in soft...xp3 is new yes? bunion
twonuts
-Given: 55
-Receive: 42
« Reply #190 on: May 07, 2009, 06:15:31 18:15 » |
twonuts pather was made using dup 2 which is old way for me now asany patches made with it r reported as viruses so ill make new patch using codefusion patcher 3 ok  ALLPIC , upload your test code and the results u get using valid demo AND results using patcher and we will sort it  BUT to be honest i think its working ok bro..any faults will be ur xp3 etc and not any protections in soft...xp3 is new yes? bunion Service pack 3 for Windows XP has been around for some time now. I have no idea why Windows won't allow the patcher program to run under any circumstances. Might be down to MicroSoft updates, possibly their malicious software program they insist on foisting onto me. I'll look forward to trying your updated one.
ALLPIC
-Receive: 72
« Reply #191 on: May 08, 2009, 05:17:25 05:17 » |
Dear bunion, I think crack is working fine, I tested with all version available with me. So there is problem with hitech not with the crack I am now sure on that. As I can't able to report this to hitech...
DrSurfer
-Given: 27
« Reply #192 on: May 08, 2009, 10:26:55 10:26 » |
A little addition as thank you for the excellent work: If you use a nationalized version of Windows the .REG files may need a little correction, adapting the InstDir key to the actual directory in your system. For example in Win2k ITA the right one is "C:\\Programmi\\....", and not "C:\\Program Files\\..." I discovered this in the hard way  DrSurfer
robban
-Given: 34
-Receive: 38
Warrior
« Reply #193 on: May 11, 2009, 01:10:57 13:10 » |
I downloaded several HI-TECH compilers and crack and got 7 Generic.dx trojans using Barts PE(DOS!!! Good work, I must say... To be honest, I donĀ“t give a rats ass about optimization. The MCU:s are so cheap so I don't have to worry about small code size, but it can be thought of as a code tutorial. I settle for my old compilers.
« Last Edit: May 11, 2009, 02:22:26 14:22 by robban »
Code Warrior
tavioman
« Reply #194 on: May 11, 2009, 02:34:10 14:34 » |
To be honest, I donĀ“t give a rats ass about optimization. The MCU:s are so cheap so I don't have to worry about small code size, but it can be thought of as a code tutorial. I settle for my old compilers.  I must disagree with you. It's not about the price! I have an application that uses 99.9 % from a PIC18F4620(64K). I will use some optimisation if it will be more available.  )
- Brain juice -
Thiru09
-Given: 398
-Receive: 1188
« Reply #195 on: May 12, 2009, 10:18:34 10:18 » |
I must disagree with you. It's not about the price! Absolutely. Speed of optimized code will be greater than the code that is not optimized. So, always try to use optimization.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #196 on: May 12, 2009, 11:15:21 11:15 » |
Absolutely.
Ever tried to debug a fully optimized code? A true nightmare...
Code Warrior
tavioman
« Reply #197 on: May 12, 2009, 12:23:57 12:23 » |
You are right, but sometimes you don't have any solutions left than to use optimizations. The largest memory PIC18 for TQFP44 packages is 96K. And for large programs I cannot use larger flash PIC18 due to IC package.
- Brain juice -
robban
-Given: 34
-Receive: 38
Warrior
« Reply #198 on: May 12, 2009, 02:30:42 14:30 » |
Well, IĀ“ve been trying to step up to ARM, but the cost for development boards are high. (Futurlec has quite cheap ones(ST32F103B with 128K RAM, but no support whatsoever). I bought a parallell port JTAG dongle from Olimex and sometimes it's working, sometimes not. It's like playing Texas hold 'em. The best compiler I tried is Keil (with GNU toolchain), but it needs a startup code which I can live without.
« Last Edit: May 12, 2009, 02:33:22 14:33 by robban »
Code Warrior
tavioman
« Reply #199 on: May 12, 2009, 03:27:12 15:27 » |
I want to step up to ARM also. I want to use Luminary Micro CORTEX-M3 devices.
- Brain juice -
