April 27, 2025, 12:17:57 00:17
Author Topic: C Structure (Keil Compiler)  (Read 5208 times)
Help
-Given: 33
« on: January 05, 2008, 03:13:03 03:13 »
 * DECLARE your own open(), close(), addr(), and byte() routines here.
static int open1(), close1(), addr1(), byte1();
static int open2(), close2(), addr2(), byte2();
static int open3(), close3(), addr3(), byte3();
static int open4(), close4(), addr4(), byte4();
 * ADD an entry to this table to register your
 * output format routines. Give your object format
 * a name to be specified with the -F option.
static int format;
static struct {
   char *name;
   int (*e_open)();
   int (*e_close)();
   int (*e_addr)();
   int (*e_byte)();
} formtab[] = {
   { "tdr",   open1, close1, addr1, byte1 },
   { "byte",  open2, close2, addr2, byte2 },
   { "od",    open3, close3, addr3, byte3 },
   { "srec2", open4, close4, addr4, byte4 },
   { "srec3", open4, close4, addr4, byte4 },
   { "srec4", open4, close4, addr4, byte4 }
#define FORMTABSIZE   (sizeof(formtab)/sizeof(formtab[0]))
Above the structure declared the function in structure. This sample code is picked from other sample project code. This sample project i took from net is not completed source and some of the .h and .c file is not included.
The call functions:
(*formtab[format].e_open)(file,ftype,arg);
(*formtab[format].e_close)();
(*formtab[format].e_addr)(a);
(*formtab[format].e_byte)(b);
The compiler show:-> error C267: 'function': requires ANSI-style prototype
How to declare the function? I already included initial define function prototype. I think my function prototype is wrong.
The attached file is the code. Please help me...
Thank you.
