February 28, 2026, 10:43:27 22:43
Author Topic: Active assignment of mnemonic to pins  (Read 16533 times)
weazuul
« on: February 17, 2006, 12:37:51 12:37 »
I want to assign a name to 2 pins on a PIC 12F629. The problem is that I want to assign the same name to those pins (but not at the same time) and while the program is running. Here is some code to give you an idea - i know it isnt correct cuz it usses precompile directives but this explains the best what i mean cuz those pragmas can be used in the begining to assign a name to a certain pin. I use CC5X as a compiler but i dont think that other compilers give a solution to this (one that i know of) . I wanted to use pointers but you just cant have pointers to bit variables  Sad
bit test_bit;
void funtion(void)
    if(test_bit == 0)
      #pragma bit PIN1 @ GPIO.1
    else
      #pragma bit PIN1 @ GPIO.2
Ty for help
parallaxis
« Reply #1 on: February 17, 2006, 01:33:38 13:33 »
There is one big error...
#pragma is a pre-processor directive, i.e. PRAGMAs are evaluated BEFORE compiling. Everywhere and always.
So it's impossible to name pin this way in C language. You cannot assign COMPILER SYMBOLIC NAME during RUN TIME - it's possible in interpreted languages, not in compiled.
So remember: ALL directives begins with # in C are evaluated BEFORE compiling the main code (#include, #if, #endif, #pragma, #define, #ifdef etc.)
weazuul
« Reply #2 on: February 17, 2006, 03:33:36 15:33 »
I saied that is not correct, i just used tht so i can explain better what i need
I need to know how i can do that assignment within a program function, while the program is running. Or any tipe of refereance to those 2 pins with the same variable/pointer something like that
« Last Edit: February 17, 2006, 03:53:07 15:53 by weazuul » Logged
parallaxis
« Reply #3 on: February 18, 2006, 01:12:13 01:12 »
Sorry, my mistake... Sad
The best way is to use mask variable, like this:
 bit test_bit;
byte mask;
void funtion(void)
    if(test_bit == 0)
      mask=0b00000001;
    else
      mask=0b00000010;
and testing/setting values this way:
Set:
 GPIO |= mask;
Clear:
 GPIO &= ~mask;
Read value:
value=(GPIO & mask)?1:0;
or simplier - if (GPIO & mask) {...}
I don't know the CC compiler syntax, but in MCHP C I'm using constructions like "PORTB |= mask;" (or "LATC=PORTC|mask;" with C18)
If you need to use two different ports, you must use pointer to memory area where desired port is mapped...
I apologize for my mistake once more, hope this helps...
