April 20, 2026, 06:53:59 06:53
Author Topic: RTOS CCS Error... help  (Read 5290 times)
TirthankarMukherjee
« on: December 30, 2007, 08:38:16 08:38 »
#include "G:\program PIC\16f877A\real_rtos1.h"
#use rtos(timer=0,minor_cycle=500ms)
#task(rate=500ms,max=100ms)
void read_IR( )
  printf("hello world");
#task(rate=1000ms,max=100ms)
void read_IR1( )
  int i;
  printf("hello USA !");
 // delay_ms(50);
  for(i=0;i<50;i++)
  printf("CCS Rocks !!");
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   setup_port_a( ALL_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   set_tris_b(0xf0);
   rtos_run();
#include <16F877A.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
Error
USE parameter value is out of range :: Minor cycle too short for this timer
Cant compile my first RTOS in CCS 4.058.. [lease help me to detect the problem.... Basically I want to do object detection with IR and run my stepper motor... so want to implement RTOS functions... but I got stuck while compiling....
A newbie is waiting for answers....
Thanks in Advance...
future
-Given: 11
« Reply #1 on: December 31, 2007, 10:10:46 22:10 »
where are your processor definitions?
the rtos uses the clock speed to make some decisions.
