November 28, 2024, 05:47:15 17:47
Author Topic: Control temperature and light day/night mode of 25 terariums with Picbasic  (Read 5373 times)
kalpakchiev
-Given: 34
-Receive: 68
« on: December 30, 2007, 02:48:26 02:48 »
'*  Name    : Terarium
'*  Version : 1.0                                               *
'*  Notes   : PIC 16F648A                                       *
@ device intrc_osc, mclr_off, wdt_off, pwrt_on, lvp_off, protect_off, cpd_off, bod_off
DEFINE OSC 4        ' Default 4MHz
CMCON = 7
INTCON 0.7 = 0      ' Turn interrupts OFF
'T2CON = %00010100   ' Turn on Timer2, Prescale = 4
'T2CON = %00000100   ' Turn on Timer2, Prescale = 1         00010101
'CCP1CON = %00001100 ' Set CCP1 to PWM
'PR2 = 25           ' Set PR2 for 38.4kHz PWM [26uS period]
OPTION_REG 0.7 = 0  ' Turn ON PortB pullups
RprtTime con 5      'Âðåìå â ñåê. çà èçïðàùàíå äàííè êúì ÐÑ
Ser_Mode con 82
Ser_ModeRX Con 80
MaxRead  con 250
MaxB     con 80     'Ìàêñèìàëíà äúëæèíà íà Buffer
'INPUTS
RX      Var PortA.0
Button2 VAR PORTA.4
Button1 VAR PORTA.5
DQ      Var PortA.6  'Alias DS1820 data pin
DQ_Dir  Var TrisA.6
'OUTPUTS
TX      Var PortA.1
Rel1    var PortA.3
Rel2    Var PortA.2
LED     VAR PORTA.7
Lamp    var PortB.3
TrisA = %01110001
TrisB = %11110111
Buffer  Var Byte [MaxB]bank2
LenB    Var Buffer[0]
Addrr   Var byte [8]
Char    var Byte
Comm    Var Byte 'Âèä êîìóíèêàöèÿ çà OneWire
I       Var byte: I1  Var Byte
J       var byte: J1  Var Byte
K       Var Byte: K1  Var Byte
B1      Var Byte: B2  Var Byte: B3 Var Byte : B4 var Byte
W1      var WOrd: W2 var Word
H2A     Var byte
A2H     Var Byte
C2H     Var byte
CharL   var byte
CharH   var Byte
Seconds Var Byte
Counter Var Byte
TmpBit  Var bit
TmpWord Var Word
TmpByte Var Byte
Temp    var word    ' Storage for temperature
Stat    VAR bit         ' Count remaining
T_Count var Byte    ' Áðîé äàò÷èöè
Relays  Var Word    ' Âñåêè áèò ïîêàçâà ñúñòîÿíèåòî íà ñúîòâ. ðåëå
ForceR  Var Word    ' Âñåêè áèò ïîêàçâà ïðèíóä. âêë. ñúîòâ. ðåëå
Hist    Var byte    'Õèñòåðåçèñ ì/ó òåìï. çà âêë/èçêë
Night   var word[16]'Íàìàëÿâàíå ñ Night ãðàä. ïðåç íîùòà
Mode    Var Byte    '0-Äíåâåí ðåæèì, 1-Íîùåí ðåæèì, 3-Ìîíèòîðèíã
Lmp     Var Byte    'Ñúñòîÿíèå íà ëàìïàòà
Day     Var word[16]  'Ìàñèâ îò çàäàäåíè òåìïåðàòóðè
Data @0,0 'Mode
Data @1, 20   'Õèñòåðåçèñ â 1/10 îò ãðàäóñ
Data @2,0     'Ñúñòîÿíèå íà ëàìïàòà
Data @4,Word $0    'Ñúñòîÿíèå Ðåëåòà
Data @6,Word $0    'Forced Relays
Data @9,0 'Íåèçïîëçâàíî çàñåãà
'Data @10, $E0,$20,$AE,$01,$40,$00,$F8,$FA 'ROM Dalas 1
'Data ..............
Data @170,Word 200'Ò1 çà äàò÷èê 1 â 1/10 îò ãðàäóñ
Data @172,Word 250'Ò2 çà äàò÷èê 2 â 1/10 îò ãðàäóñ
Data @174,Word 300'Ò3 çà äàò÷èê 3 â 1/10 îò ãðàäóñ
Data @176,Word 320'Ò4 çà äàò÷èê 4 â 1/10 îò ãðàäóñ
Data @210,word 160      'Night1 â 1/10 îò ãðàäóñ
Data @212,word 185      'Night2 â 1/10 îò ãðàäóñ
Data @214,word 190      'Night3 â 1/10 îò ãðàäóñ
Data @216,word 200      'Night4 â 1/10 îò ãðàäóñ
'Data...............
INIT:
Rel1 = 0: Rel2 = 0: Lamp = 0: Led = 0: TX = 1
Pause 500
Clear
'Ïðîâåðêà çà èíèöèàëèçàöèÿ èëè ÷åòåíå íà àäðåñ íà OneWire ó-âî
 If Button1 = 0 Then
  Led = 1
  If Button2 = 0 Then 'Àêî ñà íàòèñíàòè Áóòîí 1 è Áóòîí 2
   For J=10 to 159:Write J,$FF:Next J
   End
  End If
  For I = 0 To 15 'Àêî å íàòèñíàò ñàìî Áóòîí 1
   Char = 0: J = (I + 1) * 10: Read J, Char
   If Char=$FF Then
    Led = 0
    GoSub Read_Adr: Pause 250
    GoSub WriteROM: Pause 250
    For J1 = 0 To 5: Toggle Led: Pause 200: Next J1
    Led = 1
    End
   End If
  Next I
 End If 'Button1=0
 If Button2 = 0 Then 'Íóëèðàíå íà Mîde, Lamp è ForceR
  Lamp = 0: Mode = 0: ForceR = 0
  GoSub Write_L: GoSub Write_M: GoSub Write_R
 End If
Init1820:          ' Initialize DS1820 and check for presence
  Low DQ           ' Set the data pin low to init
  Pauseus 500      ' Wait > 480us
   DQ_DIR = 1      ' Release data pin (set to input for high)
   Pauseus 100     ' Wait > 60us
   If DQ = 1 Then
Error: B1 = "E": B2 = 0: B3 = 0: B4 = 0: GoSub Report_ANY: Led = 1: End 'Íÿìà âúðçàíè óñòðîéñòâà OneWire
   End If
Check: 'Êîëêî óñòðîéñòâà ñà âúðçàíè?
 For I = 0 To 15
  Char = 0: Read (I + 1) * 10, Char
  If Char=$FF Then
   If I = 0 Then
    B1 = "E": B2 = 1: B3 = 0: B4 = 0: GoSub Report_ANY: Led = 1: End
    Else
    GoTo End_Check
   End If
   End If
 Next I
End_Check:
T_Count = I - 1
MAIN:
GoSub Read_Data:
'Èíèöèàëèçàöèÿ íà ëàìïà è ðåëåòa
Lamp = Lmp: GoSub ON_OFF_R: GoSub Report_S
Goto LOOP
OW_Comm: 'Comm - $44-Temperature measure, $BE-Read ROM, Addrr-address OneWire
    OWOut DQ, 1, [$55]
    For J = 0 To 7: OWOut DQ, 0, [Addrr[J]]: Next J
    OWOut DQ, 0, [Comm]
Return
Report_ANY:
 H2A = B2: GoSub Hex2ASC: B2 = H2A
 C2H = B3: GoSub Char2Hex: W1.HighByte = CharH: W1.LowByte = CharL
 C2H = B4: GoSub Char2Hex: W2.HighByte = CharH: W2.LowByte = CharL
 Serout2 TX, Ser_Mode, [B1,B2," ",W1.highbyte,W1.Lowbyte,W2.HighByte,W2.LowByte,13,10]
Return
Report_S: 'Ïîêàçâà Ñúñòîÿíèåòî íà âñè÷êî
 GoSub Report_M
 GoSub Report_L
 GoSub Report_H
 For I = 0 To T_Count
  GoSub Report_R
  GoSub Report_F
  GoSub Report_N
  GoSub Report_D
 Next I
Return
Char2Hex: 'Ïðåâðúùà C2H â äâå HEX öèôðè CharL è CharH
 H2A=C2H&%00001111
 GoSub Hex2ASC
 CharL = H2A
 H2A=C2H&%11110000
 H2A=H2A>>4
 GoSub Hex2ASC
 CharH = H2A
Return
Hex2ASC:  'Ïðåâðúùà H2A îò ÷èñëî(0-15) â HEX öèôðà(0-F)
 If H2A < 10 Then
  H2A = H2A + 48
    Else
  H2A = H2A + 55
 End If
Return
ASC2Hex:  'Ïðåâðúùà A2H ot HEX öèôðà(0-F) â ÷èñëî(0-15)
 If A2H > 57 Then
   A2H = A2H - 55
     Else
   A2H = A2H - 48
 End If
Return
ReadROM: '×åòå àäðåñ íà äàò÷èê íîìåð I
 For J = 0 To 7
  J1=(I+1)*10+J:Read J1,Addrr[J]
 Next J
Return
WriteROM: 'Çàïèñâà àäðåñ íà äàò÷èê íîìåð I
 For J = 0 To 7
  J1=(I+1)*10+J:Write J1,Addrr[J]:Pause 10
 Next J
Return
Read_Adr: '×åòå îò OneWire óñòðîéñòâî àäðåñà
 OWOut DQ, 1, [$33]       ' Issue Read ROM command
 OWIn DQ, 0, [STR Addrr\8] ' Read 64-bit device data into the 8-byte array "ROM"
Return
Report_T: 'Ïîêàçâà òåìï. íà äàò÷èê íîìåð I
 B1 = "T": B2 = I: B3 = Temp.HighByte: B4 = Temp.LowByte
 GoSub Report_ANY
Return
Report_R: 'Ïîêàçâà ñúñòîÿíèåòî íà ðåëå íîìåð I
 B1="R":B2=I:B3=0:B4=Relays.0[I]
 GoSub Report_ANY
Return
Report_F: 'Ïîêàçâà ñúñòîÿíèåòî íà ðåëå íîìåð I
 B1="F":B2=I:B3=0:B4=ForceR.0[I]
 GoSub Report_ANY
Return
Report_M: 'Ïîêàçâà ðåæèìà íà ðàáîòà
 B1 = "M": B2 = Mode: B3 = 0: B4 = 0
 GoSub Report_ANY
Return
Report_L: 'Ïîêàçâà ðåæèìà íà ëàìïàòà
 B1 = "L": B2 = Lamp: B3 = 0: B4 = 0
 GoSub Report_ANY
Return
Report_H: 'Ïîêàçâà Õèñòåðåçèñà
 B1 = "H": B2 = 0: B3 = 0: B4 = Hist
 GoSub Report_ANY
Return
Report_N: 'Ïîêàçâà Night s Íîìåð I
 TmpWord=Night[i]
 B1 = "N": B2 = I: B3 = TmpWord.HighByte: B4 = TmpWord.LowByte
 GoSub Report_ANY
Return
Report_D: 'Ïîêàçâà Day ñ Íîìåð I
 TmpWord=Day[i]
 B1 = "D": B2 = I: B3 = TmpWord.HighByte: B4 = TmpWord.LowByte
 GoSub Report_ANY
Return
'Report_A: 'Ïîêàçâà àäðåñà íà äàò÷èê íîìåð I
' For I=1 to T_Count
'  Gosub Read_Adr
'  For K1=0 to 7
'   Serout2 TX,Ser_Mode,[Hex2 Addrr[K1]," "]
'  next K1
'   Serout2 TX,Ser_Mode,[13,10]
' next i
'Return
Read_Data:
 Read 0, Mode: Read 1, Hist: Read 2, Lmp
 'Read 4,Relays.LowByte:Read 5,Relays.HighByte
 Read 6, ForceR.LowByte: Read 7, ForceR.HighByte
 For k = 0 To 15 'T_Count
  Read 170 + k * 2, TmpWord.LowByte
  Read 171 + k * 2, TmpWord.HighByte
  Day [k] = TmpWord
  Read 210 + k * 2, TmpWord.LowByte
  Read 211 + k * 2, TmpWord.HighByte
  Night [k] = TmpWord
 Next k
Return
ON_OFF_R: 'Âêëþ÷âàíå/èçêëþ÷âàíå ðåëåòà
 For k = 0 To T_Count
  If forcer.0[k]=1 then 'Âêëþ÷åíî å ïðèíóäèòåëíî
     If k = 0 Then high Rel1
     If k = 1 Then high Rel2
     Relays.0[K]=1      'Âêëþ÷âà ðåëå íîìåð Ê
   Else                 'Íå å âêëþ÷åíî ïðèíóäèòåëíî
     if k=0 Then Rel1=Relays.0[0]
     If K=1 Then Rel2=Relays.0[1]
  End If
 Next k
Return
Write_M: 'Çàïèñâà Mode
 Write 0,Mode
Return
Write_L: 'Çàïèñâà Lamp
 Write 2,Lamp
Return
Write_N: 'Çàïèñâà Night ñ Íîìåð I
 TmpWord=Night[I]
 Write 210+I*2,tmpWord.LowByte
 Write 211+I*2,TmpWord.HighByte
Return
Write_D: 'Çàïèñâà Temp ñ íîìåð I
 TmpWord=Day[i]
 Write 170+i*2,TmpWord.LowByte:
 Write 171+I*2,TmpWord.HighByte
Return
Write_H: 'Çàïèñâà õèñòåðåçèñ
 Write 1,HIst
Return
Write_R: 'Çàïèñâà ñúñòîÿíèåòî íà ðåëåòàòà è ForcedR
' Write 4,Relays.LowByte:Write 5,Relays.HighByte
 Write 6,ForceR.LowByte:Write 7,ForceR.HighByte
Return
Report_B: 'Èçïðàùà áóôåðà, ïðèåò ïî RS232
 Serout2 TX, Ser_Mode, ["W"]
 For K=1 to LENB
  Serout2 TX, Ser_Mode, [Buffer[K]]
 Next k
 Serout2 TX, Ser_Mode, [13,10]
Return
Loop:
 If Button1 = 0 Then 'Ñìÿíà Äåí/Íîù
  Pause 100
  If Button1 = 0 Then 'Debounce
   If Mode = 0 Then
     Mode = 1
    Else
     Mode = 0
   End If
   GoSub Report_M
   GoSub Write_M
  End If
 End If
 If Button2 = 0 Then 'Ïàëåíå/ãàñåíå íà ëàìïàòà
  Pause 100
  If Button2 = 0 Then 'Debounce
   If Lamp = 0 Then
     Lamp = 1
    Else
     Lamp = 0
   End If
   GoSub Report_L
   GoSub Write_L
  End If
 End If
 Char = 0: Serin2 RX, Ser_ModeRX, 125, Time, [WAIT("+"),Char]
 If Char <> 0 Then 'Èç÷èòàíå íà áóôåðà
    I=1:LenB=0
    While I < MaxB
     Serin2 RX, Ser_ModeRX, MaxRead, Clean_RX, [Char]
     Buffer [I] = Char: Toggle Led
     LenB=I
     I = I + 1
    Wend
Clean_RX:
    Serin2 RX, Ser_ModeRX, MaxRead, Buffer_OK, [Char]
    GoTo Clean_RX
Buffer_OK:
   Char=Buffer[1]
   If Char = "S" Then
     GoSub Report_B
     GoSub Report_S 'Èçïðàùàíå âñè÷êè íàñòðîéêè
     Goto LOOP
   End If
   A2H=Buffer[2]:Gosub ASC2Hex:I=A2H
   'Ïðåâðúùàíå â äåñåòè÷íî ÷èñëî íà ÕÕÕÕ îò áóôåðà
   A2H=Buffer[4]:Gosub ASC2Hex:TmpWord=4096*A2H
   A2H=Buffer[5]:Gosub ASC2Hex:TmpWord=TmpWord+256*A2H
   A2H=Buffer[6]:Gosub ASC2Hex:TmpWord=TmpWord+16*A2H
   A2H=Buffer[7]:Gosub ASC2Hex:TmpWord=TmpWord+A2H
   If Char = "L" Then
    Lamp = I: GoSub Report_L: GoSub Write_L ':Goto LOOP
   End If
   If Char = "M" Then
    Mode = I: GoSub Report_M: GoSub Write_M ':Goto LOOP
   End If
   If Char = "H" Then
    Hist = TmpWord: GoSub Report_H: GoSub Write_H ':Goto LOOP
   End If
   If Char = "D" Then
    Day [I] = TmpWord: GoSub Report_D: GoSub Write_D ':Goto LOOP
   End If
   If Char = "N" Then
    Night [I] = TmpWord: GoSub Report_N: GoSub Write_N ':Goto LOOP
   End If
   If Char = "F" Then
    ForceR.0[I]=TmpWord:Relays.0[I]=TmpWord:Gosub ON_OFF_R:Gosub Report_R
    GoSub Report_F: GoSub Write_R ':Goto LOOP
   End If
   GoSub Report_B 'Àêî å ïðèåòî íåùî äà ãî âúðíå çà ïðîâåðêà
 End If 'Êðàé íà èç÷èòàíåòî
Time:   'Ïðîìÿíà âðåìå
  Counter = Counter + 1
  If Mode = 0 Then Toggle Led
  If Counter >= 8 Then
   Counter = 0: Seconds = Seconds + 1: Toggle Led
   If Seconds >= RprtTime Then
    Seconds = 0: GoTo ReadTemp
   End If
  End If
Goto LOOP
ReadTemp: '×åòåíå îò äàò÷èöè
 OWOut DQ, 1, [$CC,$44]: Pause 800
 For I = 0 To T_Count 'Îáõîæäàíå íà âñè÷êè äàò÷èöè
  GoSub ReadROM: '×åòåíå àäðåñ íà I-òèÿ äàò÷èê
  Comm=$BE:Gosub OW_Comm 'Ïîäãîòîâêà çà ÷åòåíå îò òîçè äàò÷èê
  OWIn DQ, 2, [Temp.lowByte,Temp.HighByte]
  Temp=(Temp>>1)*10 + Temp.0*5
       'DEBUG
        'serout2 TX,Ser_Mode,[#Temp,13,10]
        GoSub Report_T
  If Mode = 0 Then 'Äíåâåí ðåæèì
    If Temp<=(Day[I]-Hist) Then
      If Relays.0[I]=0 Then 'Àêî å èçêëþ÷åíî
        Relays.0[I]=1:Gosub ON_OFF_R:Gosub Report_R:
      End If
    End If 'Temp<=(Day[I]-Hist)
   If Temp >=(Day[I]) Then
     If Relays.0[I]=1 Then 'Àêî å âêëþ÷åíî
      Relays.0[I]=0:Gosub ON_OFF_R:Gosub Report_R:
     End If
   End If 'Temp >=(Day[I])
  End If ' Äíåâåí ðåæèì
  If Mode = 1 Then 'Íîùåí ðåæèì
    If Temp<=(Night[I]-Hist) Then
      End If
    End If 'Temp<=(Night[I]-Hist)
   If Temp >=(Night[I]) Then
     End If
   End If 'Temp >=(Night[I])
  End If ' Íîùåí ðåæèì
 Next I
Goto LOOP
« Last Edit: March 29, 2009, 02:26:51 14:26 by bbarney » Logged
FlvAnm
-Given: 29
« Reply #1 on: January 02, 2008, 08:24:21 20:24 »
Please post programs with comments in English.
I can't understand ...
sherm
« Reply #2 on: March 29, 2009, 01:42:12 01:42 »
Without a circuit diagram, this post is nothing more than spam. Do you have anything else to accompany the code, like a circuit, or notes in English to explain what is going on? I don't think anybody really wants to sift through this code to work out how to use it or what is of value.
oldvan
-Receive: 107
If the van is a Rockin'...
« Reply #3 on: March 29, 2009, 01:51:19 13:51 »
There is a CODE tag that programs go neatly inside.
if (PostingCode == 1)
     ShouldUse(CodeTag);
     Easier(To.Read);
     ThankYou();
