November 25, 2024, 05:17:32 05:17
Author Topic: CCS RTOS  (Read 11914 times)
TirthankarMukherjee
« on: December 28, 2007, 02:29:17 14:29 »
Can any one give me some idea how to implement the code for RTOS with CCS ( in biult functions of RTOS). I went through their manual and examples but still confused...I need to drive 2 stepper motors, scan 6 sensors(IR) give output in the LDC(16x2).
  What the algorithm must be ... I need to detect objects in the front of the bot. How the RTOS functions needs to be called ? Thanks in advance from a newbie, hope all the experienced guy gives me some tips.
localcrack
-Receive: 21
« Reply #1 on: December 28, 2007, 08:33:29 20:33 »
Please check in examples folder there is a total 9- examples are given
graywolf
-Receive: 19
« Reply #2 on: December 29, 2007, 03:13:52 03:13 »
It would be nice to be able to download the CCS complier, I do belvie that it is embedded into the complier. Have you read hte manual? It is simple to use.
TirthankarMukherjee
« Reply #3 on: December 29, 2007, 05:50:26 17:50 »
yes I have gone through the manual .. and the examples as well, but a full working project would have been more helpful, if any one of you have done some work with rtos, please email/pm [tirthankar.tirtha[at]gmail] me, thanks for your reply.
future
-Given: 11
« Reply #4 on: December 29, 2007, 11:36:39 23:36 »
I don't recommend this rtos, you will be better with your own state machine.
I have used it with version 3.249 which is the most stable version I know and only simple code works. When you start writing real applications, the rtos start to show its weakness.
graywolf
-Receive: 19
« Reply #5 on: December 30, 2007, 08:11:13 20:11 »
Have you tried using mplab and pumpkin rtos? I do belive they are both on the forums here somewhere. I acutally designed and wrote my own rtos but for htsoft.
localcrack
-Receive: 21
« Reply #6 on: July 03, 2008, 08:43:57 20:43 »
Hello graywolf, do you please give me your own rtos code.
ORIONIX
-Given: 57
« Reply #7 on: July 03, 2008, 11:48:38 23:48 »
Here you can download a document in SPANISH about RTOS CCS,with  some examples, and explain code About RTOS CCS :
http://rapidshare.com/files/126912862/sistema_operativo_microcontroladores_pic_rtos.pdf.html
Bye
PIC_rookie
-Given: 23
« Reply #8 on: July 17, 2008, 07:01:22 19:01 »
hello all
i need use RTOS on PIC
please upload ebook
thank you
Marineland
-Receive: 124
« Reply #9 on: July 18, 2008, 10:33:49 10:33 »
Bye
Here a direct link for this article  Wink
http://www.ucontrol.com.ar/Articulos/sistemas_operativos_microcontroladores/sistema_operativo_microcontroladores_pic_rtos.htm
Marineland
BTW: There are useful informations about PIC Micro on this Website (Go to: http://www.ucontrol.com.ar/wiki/index.php/Revista_ucontrol) and it's Free!
okk
-Given: 369
-Receive: 39
« Reply #10 on: July 18, 2008, 12:51:04 12:51 »
The book Advanced PIC Microcontroller Projects in C has an explanation and some simple RTOS projects in CCS C, this would be a good start. I believe that it may be found within these pages.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #11 on: July 18, 2008, 02:11:24 14:11 »
Yeah, I would really like to see a decent RTOS. Most of them makes me stumble just by setting them up...
Code Warrior
etm503
« Reply #12 on: July 19, 2008, 11:46:59 11:46 »
I have coverted a fairly large project that use 95% Rom on 18F242 to use ccs rtos.
Its working fine so far.
What I discovered is that you must be very liberal with your "rtos_yield" statements.
This is because the RTOS does not necesarily share execution time between the tasks equally. This means that if you are not careful, some tasks may actually never run, or run for an unpredictable time.
One challenge is when you process an interupt request, call subroutines or functions from within a task.
I found that I could not execute a rtos_yied from the called routine.
I ended up converting some of the functions/ subroutines to tasks.
Otherwise I am happy with the rtos perfomance( at least as of now ! )
