February 28, 2025, 07:55:39 07:55
Author Topic: Rapidshare Premium Link Generator Script  (Read 5101 times)
Leonardo
-Receive: 63
« on: December 26, 2007, 11:13:54 23:13 »
Hw to Install
1.Extract the archive files and upload to your server.
2.Create database and Run SQL Query Below:
   CREATE TABLE `accounts` (
  `id` int(10) NOT NULL auto_increment,
  `login` varchar(150) collate latin1_general_ci NOT NULL default '',
  `password` varchar(150) collate latin1_general_ci NOT NULL default '',
  PRIMARY KEY  (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 COLLATE=latin1_general_ci AUTO_INCREMENT=1 ;
CREATE TABLE `logs` (
  `fid` int(10) NOT NULL auto_increment,
  `filename` varchar(200) collate latin1_general_ci NOT NULL default '',
  `fdate` varchar(150) collate latin1_general_ci NOT NULL default '',
  `ip` varchar(150) collate latin1_general_ci NOT NULL default '',
  `furl` varchar(150) collate latin1_general_ci NOT NULL default '',
  `filesize` varchar(150) collate latin1_general_ci NOT NULL default '',
  PRIMARY KEY  (`f_id`)
3.Edit file config.php on your favourite editor,I prefer use notepad.
 <?php
$INFO
['sql_driver']     = 'mysql'
$INFO['sql_host']       = 'localhost'
$INFO['sql_database']   = 'your dbname'// db name
$INFO['sql_user']       = 'your dbuser''; // username db
$INFO['
sql_pass']       = 'your dbpasword';// passwsord db
$INFO['
base_url']       = 'http://www.yourdomain.com/index.php'; //The link to this script
$INFO['premium_act']    = '1'//You should change this number according to the account id number found it the database.
$INFO['serverload']     = '50'//Disable download when server load equal this value.
$INFO['dl_limit_perday']= '3'//How many link can a user download per day 0 = unlimited;
4.Save and upload config.php to your server.
6.Assuming you still on phpMyAdmin,run this SQL Query to insert your rapidshare premium account.
   INSERT INTO `accounts` ( `login` , `password` ) VALUES ( 'your rapidshare login account' , 'your rapidshare password account');
5.Point your url on browser and enjoy.
6.If you have time just make your template is more great.
[Works 100%]
http://w13.easy-share.com/1405981.html
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #1 on: December 27, 2007, 08:35:49 08:35 »
Can you please do more explication about creating database and Running SQL. and where should i create this database ??
tantino
-Given: 17
« Reply #2 on: January 25, 2008, 04:40:54 16:40 »
Ahmad_k if your on a linux host, have a look at phpMyAdmin, this makes executing mySQL statements easy.
