casebsantos
« on: December 22, 2007, 09:29:35 21:29 » |
I am testing some commands AT between a PIC and one siemens c65. How I make for I read the content of a received message?  Since Already, thanks.
-Given: 405
-Receive: 545
« Reply #1 on: December 22, 2007, 10:57:43 22:57 » |
try searching the forum
Rute
-Given: 102
-Receive: 179
« Reply #2 on: December 22, 2007, 11:06:49 23:06 » |
Read the SIM (First set the phone to store sms in sim) If delete 1-st place in sim for SMS after reading,you will find new sms there.
casebsantos
« Reply #3 on: December 24, 2007, 06:20:26 06:20 » |
I need a code sample that will read the received text message. Somebody can help me?
salej
« Reply #4 on: December 24, 2007, 10:44:04 10:44 » |
hello i am new here, you need to use at+cmgread command
Posted on: December 24, 2007, 05:41:40 05:41 - Automerged
you can work with any mobile phone, the at commands are the same with some variations
zaliko
« Reply #6 on: January 12, 2008, 09:25:06 21:25 » |
hi, 1. ATE0 CR LF - turn off echo from the mobile device 2. AT+CPMS="SM","SM","SM" CR LF - set preffered message storage for mobile device (sim card in our case) 3. AT+CMGF=0 CR LF - trun sms PDU format on 4. AT+CNMI=1,1,0,0,1 CR LF- indicates new incoming sms. when, new sms arrived mobile device generate message like this: +CMTI: <mem>,<index>. where indexis the index of the incoming sms in the sotrage <mem>. in our case mem is SIM card(see command 2). you can catch this this if you enable RX interrupt in MCU. after you got +CMTI: <mem>,<index> you can easy read the incoming sms with command: AT+CMGR=<index>CR LF. you will got answer: +CMGR: bla bla CR LF <pdu> where <pdu> is the sms text in PDU mode. decode it and do anything you want. hope this helps. p.s. CR = 0x0D LF=0x0A
glenjoy
« Reply #7 on: January 17, 2008, 07:27:09 07:27 » |
You need to study the AT commands required for the phone to function properly.
kiashee
-Given: 80
« Reply #8 on: January 23, 2008, 08:48:24 08:48 » |
you may also wish to visit www.etsi.org for some GSM standards, like PDU and at-commands.
Kafao
« Reply #9 on: January 26, 2008, 02:50:02 02:50 » |
Hello. Anyone has made something for PDU to Normal mode for SMS?
klivi1
« Reply #10 on: January 29, 2008, 03:11:52 15:11 » |
you need to connect to mobile phone via RS232. When it works you can send/receive AT commands to phone. A good way to test them using PC and a terminal program. When it works you can implement into MCU. Concerning PDU I suggest you to use normal SMS mode (if your phone can accept) The PDU is a hard game :-(
strat
-Given: 11
« Reply #11 on: February 26, 2008, 08:25:54 20:25 » |
Some important common AT commands : AT+CMGF=1 -->turn on Text mode AT+CMGL="REC UNREAD" --> Read new messages AT+CMGS=Tel No + message --> Send message AT+CMGD= message text -->Delete message
After all succeeded commands Pic will wait 'OK' sign.
« Last Edit: February 26, 2008, 08:31:06 20:31 by strat »
free
-Given: 71
« Reply #12 on: February 28, 2008, 04:35:39 04:35 » |
If you want to detect every incoming sms, use AT+CNMI command. You will get the index from +CMTI as respond and write AT+CMGR = <index> to get the all data message. From the message you can check the sender phone number, message etc.
Hope it helps you
Some dream to escape reality, some to change it forever. - Soichiro Honda -
sohel
-Given: 169
-Receive: 149
« Reply #13 on: March 10, 2008, 05:29:21 05:29 » |
any conveter for pdu to text and show on lcd?
microcom-ecuador
« Reply #14 on: March 22, 2008, 10:59:19 10:59 » |
Is most easy work with text mode direct
Ret12_12
-Given: 104
-Receive: 32
« Reply #15 on: March 23, 2008, 05:34:43 05:34 » |
If we say CMGF = 1 ( i see above) on the nokia phone then it will accept AT Commands ? instead of the PDU ?
