November 24, 2024, 10:38:28 10:38
Author Topic: [request] : ft232 project  (Read 5022 times)
omidsht
-Given: 60
-Receive: 16
« on: December 21, 2007, 04:37:35 16:37 »
hi again ,
i need a project that convrts uart of micro to usb using ft232 IC , have any body built  it and tested it ? if yes please share it .
thanks
omid
EDSONCT
-Given: 72
« Reply #1 on: December 21, 2007, 04:56:55 16:56 »
I use a application in ftdi site and work well.
Edson
pedja
« Reply #2 on: December 22, 2007, 01:34:12 01:34 »
you have shematic in datasheet Wink
omidsht
-Given: 60
-Receive: 16
« Reply #3 on: December 22, 2007, 07:00:08 07:00 »
Edson
hi ,
please give me it's adddress .
thanks
omid
Branko
« Reply #4 on: December 22, 2007, 08:35:57 08:35 »
http://www.ftdichip.com/Documents/Schematics.htm
Marineland
-Receive: 124
« Reply #5 on: December 22, 2007, 09:02:24 09:02 »
Here a breakout (Eagle format) for FT232R from Sparkfun (www.sparkfun.com):
http://www.sparkfun.com/tutorial/BeginningEmbedded/FT232-Breakout-v10.pdf
http://www.sparkfun.com/tutorial/BeginningEmbedded/FT232-Breakout-v10.zip
Alternate schematic:
http://www.compsys1.com/support/docs/usbp3.pdf
omidsht
-Given: 60
-Receive: 16
« Reply #6 on: December 22, 2007, 03:43:09 15:43 »
thanks guys , branko and marineland ,
okay , when we installed the driver , then which software should we use to monitor received data and to send data out of pc ?
omid Wink
Marineland
-Receive: 124
« Reply #7 on: December 22, 2007, 05:06:15 17:06 »
Hi omidsht,
From Host side (PC), there is two types of driver:
  • Virtual COM Port (VCP) drivers
  • direct (D2XX) drivers
The VCP driver emulates a standard PC serial port such that the USB device may be communicated with as a standard RS232 device.  The D2XX driver allows direct access to a USB device via a DLL interface.
When you'll plug the FT232R breakout, the windows asks you to install a driver (one of both).
If it is your first experiment with the components ftdi, I advise you initially mode VCP... Wink
Marineland
stemli
« Reply #8 on: December 22, 2007, 09:45:12 21:45 »
hi
diy usb pic programmer has ft232bm chip. ft232 chip is usb to comport converter. so you can use it with serial pic programmer for usb pic programmer.
good days
siwat2
« Reply #9 on: December 25, 2007, 03:27:40 15:27 »
Can I use any FT product to be USB host?
drnewton
« Reply #10 on: December 27, 2007, 01:14:10 01:14 »
The FT series cannot be USB hosts, but FTDI makes another chip, the Vinculum that will act as host. See: www.vinculum.com
lek05134
« Reply #11 on: January 10, 2008, 03:01:21 03:01 »
http://www.ianstedman.co.uk/Projects/PIC_USB_Interface/pic_usb_interface.html
memed500
« Reply #12 on: January 10, 2008, 12:05:07 12:05 »
http://www.eix.co.uk/Ethernet/USB/
