November 26, 2024, 04:45:44 16:45
Author Topic: Battery chargers  (Read 5758 times)
bird777
« on: December 18, 2007, 01:39:28 13:39 »
Acid charger:
   http://rapidshare.com/files/77411353/Acid_Charger.jpg.html
Posted on: December 18, 2007, 02:37:26 14:37 - Automerged
Solar charger:
   http://rapidshare.com/files/77411554/Solar-Charger.jpg.html
vjani
 Warned
« Reply #1 on: December 29, 2007, 11:37:15 11:37 »
Anybody have shematic of Nokia 6130 chargers?
AntiBG
-Given: 76
« Reply #2 on: December 30, 2007, 07:12:31 19:12 »
http://www.oshonsoft.com/picchargerlcd.html
efan
« Reply #3 on: December 31, 2007, 01:14:27 01:14 »
i ma interested at solar cell charger, anyone could give me more circuit about it?
AntiBG
-Given: 76
« Reply #4 on: December 31, 2007, 10:22:34 22:22 »
More info here:
http://solorb.com/elect/solarcirc/aacharge/index.html
tenir
« Reply #5 on: January 06, 2008, 12:36:03 12:36 »
is there anybody have a circuit for MPPT "maximum power point tracker" solar charger"
spl
-Given: 35
« Reply #6 on: January 10, 2008, 05:50:51 05:50 »
The single Chip UC3906 for lead acid charger
and MAX713 for NICad .
vhgod
« Reply #7 on: January 14, 2008, 08:39:50 08:39 »
 I want to install solar electrical system (250-300W), I use 200Ah battery, so the battery charger circuit??? What can I do?
Posted on: January 10, 2008, 07:32:12 07:32 - Automerged
Here
http://rapidshare.com/files/83669253/scc3c1.jpg.html
otakis
« Reply #8 on: March 14, 2008, 11:02:19 23:02 »
hi all,
are there schematics and infos for nicd and lipo solar chargers?
thanks!
tutatix
« Reply #9 on: March 18, 2008, 04:22:09 16:22 »
Another Battery charger for 12V:
http://www.neoteo.com/tabid/54/ID/2782/Title/Cargador_de_baterias_de_12V/Default.aspx
pino04062
« Reply #10 on: March 22, 2008, 07:12:54 19:12 »
follow this link on this free site you can find a versatile battery charger http://www.seven-segments.com/
Walkura
-Given: 56
-Receive: 82
« Reply #11 on: April 19, 2008, 11:18:13 11:18 »
Maybe its a strange question .
But did anyone of you build the Microchip charger ?
http://ww1.microchip.com/downloads/en/AppNotes/01015a.pdf
So far i always used custom written routines for charging .
(we used the st7 serie processors)
Right now i want to switch towards microchip & basic (Mikrobasic)
But has anyone of you experience with this charger ?
baltaji555
« Reply #12 on: April 20, 2008, 05:15:19 05:15 »
if you want to build a charger you need to know the usual routine for charging which are divided into three phases:
the first is for heavy discharged battaries in which the battary is charged with a percentage of it's rated current to avoid heating.
the second is to charge it with it's rated current.
the third is to charge it with a constant voltage to avoid discharging it after it is fully charged.
mavco
« Reply #13 on: April 25, 2008, 10:11:18 22:11 »
Hi, i would like know if the batteries of nimh suport the methode trickle charging, because i read many sheets but not found about this. The batteries of nicd support but the nimh i don't know.
