embromation
-Given: 50
-Receive: 478
« on: December 15, 2007, 12:17:03 00:17 » |
Microcontroller Programming Post an Programmer here too! PIC-Brenner8 [USB] [for all PIC series] Features:- all most devices supporteds
- USB programming
Downloads:Get circuit, layout (EAGLE Files) and firmware in website: http://www.sprut.de/electronic/pic/projekte/brenner8/index.htm#b8pPIC-PG2 (know as PICBurner or JDM Extreme!) [SERIAL] [for all PIC series] Features:- easy to make
- low cost
- serial programming
- work with prograns: winpicpgm, WinPic800, icprog, etc...
Downloads:Eagle files (layout + circuit): http://rapidshare.com/files/135310415/Eagle_files.rarManual: http://rapidshare.com/files/135310729/JDM_Extreme_MANUAL.rarThis project is result of projects:JDM Programmer: http://www.jdm.homepage.dkPic-pg2: http://www.olimex.com/dev/pic-pg2.htmlHVProg [SERIAL] [for AVR] Features:- Compatible with AvrStudio
- Supports all AVR Controllers
- Parallel and serial High-Voltage-Programming
- Small and easy layout with only a few parts
- STK500 protocol
Downloads:Get circuit, layout (EAGLE Files) and firmware in website: Website: http://www.der-hammer.info/hvprog/index_en.htmUSBASP(AVR DUDE) [USB] [for Atmel AVR] Downloads:Get circuit, layout (EAGLE Files) and firmware in website: Website: http://www.fischl.de/usbaspAVR ISP 2 clone [SERIAL] [for AVR] http://www.embedded-projects.net/usbprog
« Last Edit: August 06, 2008, 11:10:40 23:10 by embromation »
Share your knowledge!
MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« Reply #1 on: December 16, 2007, 04:36:11 04:36 » |
Hi embromation, What's the change from uor previous ultra pic programmer in this extreme!....?
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #2 on: December 16, 2007, 08:15:43 20:15 » |
Nice programmer. which software support for programming?
yugal
Warned
-Given: 919
-Receive: 73
« Reply #3 on: December 24, 2007, 03:44:04 15:44 » |
Hi, Embromation, how to programme 16F72. This device is not in your list Please replay. yugal
pama
-Receive: 28
« Reply #4 on: December 26, 2007, 08:06:10 08:06 » |
maybe it could help if you share here your work! tnx
faraz101
-Given: 185
-Receive: 1737
« Reply #5 on: December 26, 2007, 03:10:17 15:10 » |
i have build jdm2 programmer.i programmed pic16f84a,pic16f628 and 12f675 with it.it works fine but it supports very short icsp cable.only 3 inch.why? anyone?
drnewton
« Reply #7 on: December 27, 2007, 01:11:50 01:11 » |
Extreme programmer is working for me on my desktop. Of course my laptop which only makes 5v on RS-232 fails.
tango
-Given: 28
« Reply #8 on: January 07, 2008, 10:25:14 22:25 » |
All JDM variant\s is to simple and bad programmer's , that I meen... Epic Plus programmer is the best solution if you need simple and 100% good and extra low cost.
OK you may have your own meen and maybe for you JDM is good it's ok.
Best regards to you and all friend's.
mr_byte31
-Given: 75
-Receive: 144
« Reply #9 on: January 08, 2008, 06:50:16 18:50 » |
Epic Plus programmer!!!!!!!! plz send me the sechmatic plz
hodahel
-Given: 189
Catch me...
« Reply #10 on: July 24, 2008, 05:12:20 05:12 » |
how can we convert it to work with usb?
what's the newest update mates?
mrpicing
-Given: 133
-Receive: 33
« Reply #11 on: July 29, 2008, 06:36:22 06:36 » |
some guys complained that jdm is not working. I also tried this programmer but i depends on voltage available from serial port. some serial port can't supply exact 12 volt. it causes a problem. If voltage on serial port are stable and enough for vpp than it works fine.
ashan
-Given: 21
« Reply #12 on: July 30, 2008, 05:01:27 05:01 » |
Hi friends, What ever style of PCB JDM is a good programmer and is established among hobbiests. Now the things are changed! It is the laptops and new destops are not at all equipped with a serial port. we mostly depend on usb to rs232 converters but JDM voltage reqiurement point of view this can not be used. so I recomend GTP USB lite with winpic800 3.5 G or older version or try any PICKIT2 clone Still I amit the fact that we are all expertised with JDM - my tribute to the grand father!!
regards ashan
ashan
-Given: 21
« Reply #13 on: July 31, 2008, 04:38:31 04:38 » |
dear friends, pls have a look at: http://www.sonsivri.com/forum/index.php?topic=4740.0I have cloned the pickit2 with all device support but the PCB is double sided with lots of additional components(it is first version) If anybody is intererested I will share the schematic which uses only freely available components anyway GTP USB lite and Winpic800 is best for starters pls use version 3.55g or older PICKIT2 Configuration and GUI is not friendly compared with Winpic800 goodluck ashan
chen
« Reply #14 on: August 04, 2008, 05:55:37 17:55 » |
Hi embromation...
is it possible to use one zif socket instead of 2 ic sockets by using extra switch or some other way ?
picelec
-Given: 15
-Receive: 32
« Reply #15 on: August 04, 2008, 08:45:13 20:45 » |
microcom-ecuador
« Reply #16 on: August 06, 2008, 04:40:01 04:40 » |
Hello, I have assembled a brenner8 usburn, work fine with pics like 16f877a,876a but i have problems with 16f628 and 16f819
microcom-ecuador
« Reply #17 on: August 12, 2008, 12:54:14 00:54 » |
Hello Embromation, yes i have the latest version of software and firmware. Wen i program the first time a pic16f628a works fine, but in the second time i have an error in the program memory, i tried with "erase" an "remove cp" buttons and then blank check and the pic is not in blank.
-Given: 496
« Reply #18 on: August 14, 2008, 12:34:12 00:34 » |
I found that the Microchip's PICKIT2 seems to be the best PIC programmer for Hobbyist. it support almost every flash chip Microchip made including their eeproms, it has an EEPROM in it so you can preprogram it and use it as a standalone programmer, it has capability to power the project under program, it is also a debugging ICD, and, how is this for an extra.. it is also a logic analyser!!
It is about $49 USD but if you want to built them yourself, there is enough info and firmware freely available from Microchip.
I think this one is a winner for PIC.
abd elwahab
« Reply #19 on: August 14, 2008, 04:45:47 16:45 » |
hi sonsivri usere I now share my work for the pic serial programmer to eagle useres also winpic is included in the archiev http://www.4shared.com/file/59032697/2a0029c1/pic_programmer_serial.html sorry for the long path iam a new in file sharing
« Last Edit: August 15, 2008, 04:40:02 16:40 by pickit2 »
microcom-ecuador
« Reply #20 on: August 27, 2008, 07:04:04 07:04 » |
Hello Embromation, I have a 8Pr5, I am using transistor 2N3904 and 2N3906 in substitution of BC338-25 and BC328-25 and I tested with a 2N3904 and a BC549 instead of BF959 transistor. It works fine with the following PICs: 16F876A, 16F877A, 16F819, 18F2550, 18F4550 and 18F452. But i Have problems to erase or reprogramm 16F628A and 18F1220, also I don`t know how to programm 12F675. I have a pc with XP SP2 firmware (on pic): b8_fw12.hexdriver driver (on pc): driver_2k_xp_vista I tryed mainly with PIC16F628A, the first is ok but the next time i Have error, i tried to erase pic but no is possible. There is an atachment with the information. Please help me with this. Posted on: August 27, 2008, 07:55:39 07:55 - Automerged http://rapidshare.com/files/140442946/usburn_problems.doc
ennio
-Receive: 15
« Reply #21 on: August 27, 2008, 09:06:15 09:06 » |
My Brenner is able to program PIC16F628A. I am using transistor 2N3904 and 2N3906 and coil 680uH. The calibration Procedure 1- Z voltaje(Read with multimeter) 2- U divider (typical 3.14 Resistors 1%) 3- Auto Adjust offset 4- Close Reopen .. Ready For 12F675 Place it on top of ZIF(pin 1 ZIF = pin 1 12F675) Regards
ennio
« Last Edit: August 27, 2008, 09:09:56 09:09 by ennio »
cooperharris
-Given: 72
-Receive: 22
« Reply #22 on: September 04, 2008, 02:48:26 14:48 » |
here is another programmer, this is the one that I use, I asure you that it works perfect http://rapidshare.de/files/40392500/Func_y_Uso_de_QuarkPro_2.pdf.htmlthe instructions are in spanish but there you can see the schematic,you will understand, It works with ic-prog perfectly, enjoy it!
microcom-ecuador
« Reply #23 on: September 05, 2008, 04:07:49 16:07 » |
This is anmother version of JDM programmer, maybe you will have problems because it uses PC voltage.
tuldok89
-Given: 21
-Receive: 12
« Reply #24 on: September 06, 2008, 10:56:39 10:56 » |
IMHO It is possible to use the JDM programmer in a laptop pc. My buddy modded his JDM programmer, so it can be supplied w/ 12volts from a DC adaptor.
I've used his modded JDM, and it works w/ my Laptop
