November 25, 2024, 11:49:52 11:49
Author Topic: "PIC_CCS_C_MMC_card" ( help )  (Read 15712 times)
arash
« on: January 25, 2006, 09:42:07 09:42 »
Hi all
I was download the "PIC_CCS_C_MMC_card" from http://www.microchipc.com but i cant compile it.
How can i do that?
arash
« Reply #1 on: January 27, 2006, 10:52:56 10:52 »
Come on:mad::mad::mad:
LazBoy
-Given: 78
-Receive: 25
« Reply #2 on: February 03, 2006, 04:28:56 04:28 »
I am beginner on CCS but that is just an include file.
You can not compile it. You can merge to main project file.
Another Example for MMC
« Last Edit: February 03, 2006, 04:32:32 04:32 by LazBoy » Logged
wh_hsn
« Reply #3 on: February 03, 2006, 02:02:40 14:02 »
You may also try this code, I've not tried it!
(please be kind and report your results)
« Last Edit: February 03, 2006, 02:09:37 14:09 by wh_hsn » Logged
parallaxis
« Reply #4 on: February 03, 2006, 05:56:08 17:56 »
You may find this document usefull:
http://web.archive.org/web/20041029000445/http://www.sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf
wh_hsn
« Reply #5 on: February 12, 2006, 06:23:36 06:23 »
Hi arash,
Did you check the code?
Did it work?
Would you report the outcome!
Thanks,
khai
« Reply #6 on: February 22, 2006, 06:17:47 06:17 »
Hi arash,
Do you test mmc_spi.c ccs driver?
wh_hsn
« Reply #7 on: February 23, 2006, 01:04:55 01:04 »
arash asked for help - noone answerd!
he got angry, very angry & yalled 'Come on'!!!
people answered & answered & answered -
arash didn't care to report to them his findings
thanks arash
arash
« Reply #8 on: February 24, 2006, 06:26:49 06:26 »
Sorry about that.
I have a problem about my university.
I'm so sorry.
tavioman
« Reply #9 on: March 31, 2006, 10:45:56 22:45 »
Arash, you can try PRLLC fat12/16 driver for MMC.
This is a comercial distribution so I think it will work.
I have this driver(unlocked) but I've never used'it.
They no longer support this product for PIC. Ony for AVR and Motorola MCU's.
But if you want it I can give it to you.
Best wishes.
- Brain juice -
arash
« Reply #10 on: April 04, 2006, 03:22:42 03:22 »
Thank you.
Pleas share it.
wh_hsn
« Reply #11 on: April 04, 2006, 08:17:02 08:17 »
Arash,
did you try the files given to you before??
Are you still on that project?
Why don't you tell us what you'be done with the drivers given to you so we can all benefit?!?!?!?!
tavioman
« Reply #12 on: April 04, 2006, 08:57:54 08:57 »
Here is unlocked FlashFile-SD-PIC.
Success! Smiley
Also, tell us if this is useful for you, and if you manage to make a project out of this.
Best wishes!
« Last Edit: April 04, 2006, 09:00:30 09:00 by tavioman » Logged
- Brain juice -
arash
« Reply #13 on: April 06, 2006, 04:02:57 04:02 »
Thsnks gus.These realy helped me.
wh_hsn
« Reply #14 on: April 06, 2006, 12:07:49 12:07 »
Did it work?HuhHuhHuhHuhHuhHuhHuhHuh
tavioman
« Reply #15 on: April 26, 2006, 08:20:12 20:20 »
I think it's working since it is a comercial product.
It seems that Arash it's not realy interested in sharing the results with us. Sad
- Brain juice -
arash
« Reply #16 on: April 28, 2006, 06:26:07 06:26 »
Wha'you taiking about guys:confused:
Youre knowledg realy helped me.What to share with you that you already know it.
ok?.
Guyes your'e my friends and i share with you all of my knowledg :rolleyes:
tavioman
« Reply #17 on: April 28, 2006, 02:06:46 14:06 »
We don't doubt that you are our friend.
We want to know if the Flash File it's working...
That's all Smiley)
- Brain juice -
diegonet
-Receive: 29
« Reply #18 on: April 29, 2006, 12:06:30 00:06 »
Hi to everyone!
I read many post's asking about the Flashfile and I wanna share my experience.
I buy the last version of Flashfile (2.1). YES i BUY it. Smiley
When I receive it , I build the examples circuits and tested the examples codes provided. They never worked. After looking in depth at the code, I found several pins hardcoded and pointing to diferent hardware pin's in the PIC. e.g. The CS pin was linked to B2 in one file, C2 in other and C4 in the last one.
After correct this, the init_card() start to work and I can read the directory of a SD card. But trying to write to the card alway's return an error.
After several e-mails (10 day's) to the technical support, we receive this:
"Sorry,
Still looking into it, not sure what's going on, it doesn't do that on the 4620 (currently the only test platform that we have which is why the CS was defined as it was)."
No, you DON'T READ IT WRONG: they only tested the libraries in ONE CHIP (PIC18F4620)
After another ten day's, we receive this:
"Sorry, but this is all I can really give you, I've updated some of the files with fixes that we have done for our AVR version, with the project compiled for my PIC18F4620. I've also recompiled it using the original PIC18F6720 settings that this was compiled for. I no longer have any of that hardware so I could not test it to see if it actually worked correctly."
THIS IS WAS I CALL: BLINDY PROGRAMMING Cheesy
This "new" version returns more errors than the previous one.
So after many day's of test and debug, I can't put this thing to work. I'm currently asking my money back.
I'm really need to read/write to an MMC/SD card, and I believe that many other's too.
My currently project (an automotive datalogger) use an SD to save all the data captured. This SD is read after in a PC running an analysis software.
I choose the SD because is the most economic, fast and reliable high capacity memory system of today. It also requires only 4 lines to work against the many needed by one CF.
So, I have a proposal to everyone. Let's go make and sale our own library. If this guy of Flashfile could sell it for 120 dollars, and testing it in only one chip, I'm really sure that we can develop a much better (working) product.
Also we would test it in multiple systems and this is quality factor.
We can make money for us and for supporting REGO. Shocked
I will wait for supporters!
Best Wishes,
Diego
« Last Edit: April 29, 2006, 12:09:38 00:09 by diegonet » Logged
Dembo
« Reply #19 on: April 30, 2006, 12:14:57 12:14 »
I didn't deal with SD, but as I wrote once, they CF version had a lot of bugs, especially in HW low-level.  See http://www.sonsivri.com/forum/showpost.php?p=2753&postcount=7
diegonet
-Receive: 29
« Reply #20 on: May 06, 2006, 11:39:40 23:39 »
Please Check My Post: Testers Need! Sd Card Fat16 Library
Rafet32
 Warned
-Given: 22
-Receive: 24
« Reply #21 on: May 08, 2006, 02:59:51 14:59 »
Quote from: tavioman
Success! Smiley
Best wishes!
Good share. Thanks....
lord_ex
« Reply #22 on: May 17, 2006, 01:18:06 13:18 »
Quote from: arash
Hi all
I was download the "PIC_CCS_C_MMC_card" from www.microchipc.com but i cant compile it.
How can i do that?
PIC_CCS_C_MMC_card.zip. I so, This file is mmc driver for css.
do you have a sample code? I need a sample. Thanks.
sslobodyan
« Reply #23 on: May 18, 2006, 09:00:21 09:00 »
http://www.mpic3.com has some examples about mmc and cf for ccs-c.
lord_ex
« Reply #24 on: May 18, 2006, 12:09:48 12:09 »
Quote from: sslobodyan
Thanks.
