November 25, 2024, 10:36:21 22:36
Author Topic: MCLR in 16f88  (Read 3884 times)
picstart
« on: January 21, 2006, 08:47:09 08:47 »
If the MCLR is internally tied to Vdd by changing CONFIG1 bit 5 ( MCLRE) , then is there still a need to pull up the MCLR to 5v ?
« Last Edit: January 21, 2006, 11:50:50 11:50 by picstart » Logged
max
-Given: 1661
-Receive: 52
« Reply #1 on: January 21, 2006, 11:19:34 23:19 »
Since the pin is input only either MCLRE or port pin, you should use a pullup
if the pin is driven by an open-collector type output, for pushpull type output
there is no need to use a pullup.
stevetwc
« Reply #2 on: January 22, 2006, 12:22:27 00:22 »
Hi picstart, if you configure the MCLR to be used as an input pin instead of a reset pin, you can left it unconnected.
Regards.
-Given: 405
-Receive: 545
« Reply #3 on: January 22, 2006, 06:00:19 18:00 »
never leave pins floating,always change to input tied to ground or +5
