MicroMaster
-Given: 92
-Receive: 87
« on: December 01, 2007, 05:11:00 05:11 » |
Hello Here is the C30 full from Microcohip. No need to crack. Just install and work. http://rapidshare.com/files/72340023/MPLABC30fullWithDoc.rarThanks a lot. I have uploaded Microchip Masters CD ROM also .please see e books section MM
« Last Edit: August 31, 2008, 01:08:44 13:08 by pickit2 »
MicroMaster
"Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats." Howard Aiken.
mris99
-Receive: 16
« Reply #1 on: December 07, 2007, 08:54:52 20:54 » |
It asks for serial number. What is it?
50caliber
-Given: 174
-Receive: 863
« Reply #2 on: December 08, 2007, 12:10:55 00:10 » |
Look in the License.txt file.
mbandala
-Given: 130
-Receive: 305
« Reply #3 on: March 14, 2008, 11:11:23 23:11 » |
sevesa
« Reply #4 on: March 14, 2008, 11:30:04 23:30 » |
2funpars
-Given: 46
« Reply #5 on: March 19, 2008, 10:55:03 10:55 » |
it asks for serial??
mbandala
-Given: 130
-Receive: 305
« Reply #6 on: March 19, 2008, 02:06:43 14:06 » |
Try MTI074042127
2funpars
-Given: 46
« Reply #7 on: March 22, 2008, 04:36:51 16:36 » |
is this C30 compiler add-on? it doesnt contain a file to launch..
Robi
-Given: 54
« Reply #8 on: March 23, 2008, 03:30:16 15:30 » |
Files to run are in the BIN folder. C30 is a command line suite which you can call from MPLAB IDE. Open the project wizard, select a 16 bit device, select Microchip C30 toolsuite in the language toolsuite and create a new project file.
heatcon
« Reply #9 on: March 31, 2008, 04:19:45 04:19 » |
i m looking for the c-complier for 16series pic mcu.kindly tell us where can i get the crake version.
tavioman
« Reply #10 on: April 07, 2008, 06:52:29 06:52 » |
Microchip does not make a C compiler for PIC16 series.
- Brain juice -
RADS
« Reply #11 on: August 01, 2008, 10:25:35 22:25 » |
I have downloaded MPLAB C30 version 3_02 compiler as mentioned in the above link.
The compiler is installed successfully. But during compiling the following message appears :
"The current system date is invalid. Options have been disabled due to invalid licence."
It would be great if anyone can suggest how to resolve the above issue.
Wannabe
-Given: 228
-Receive: 285
« Reply #12 on: August 01, 2008, 10:45:22 22:45 » |
Four years ago I disassembled C30 and came to this conclusion regarding serial numbers: Use included license manager (pic30-lm.exe) with the following switches: -ix=DDMMYYYY : make demo last to date MM/DD-YYYY -iu=XXX : make demo last XXX days or finally make it full version -uMTIxxyy4zzzz (where xx=01-04, yy=01-53, zzzz=0001-9999) (example: -uMTI035248989 is a valid licensenumber) According to these findings MTI074042127 would be an invalid serial. There were some date checks, but if I recall correctly I chose xx=01-04 to be on the safe side. Try using the example above and see if it works better. The latest version as of today available to download is: http://ww1.microchip.com/downloads/en/DeviceDoc/MPLAB_C_ComboFull_v3_11.exeTried making the examplefiles using serial MTI074042127 and they failed. Using serial MTI035248989 everything was ok. Regards Wannabe
« Last Edit: August 01, 2008, 11:28:29 23:28 by Wannabe »
RADS
« Reply #13 on: August 02, 2008, 11:00:35 11:00 » |
Version 3_02 works fine with the example license number. It builds/makes without any limitation.
But the same is not possible with version 3_11.
Is a different license number required ? Could you give any suggestions ?
Regards.
Wannabe
-Given: 228
-Receive: 285
« Reply #14 on: August 02, 2008, 12:01:28 12:01 » |
What is not possible with 3.11? Did you try MTI035248989 ?
RADS
« Reply #15 on: August 02, 2008, 07:54:41 19:54 » |
I tried the following: 1) During MPLAB MPLAB_C_ComboFull_v3_11 Installation -In the "Get Registration Window", entered MTI035248989 in serial number entry.The Installation completes successfully but during making/building project, output window indicates the following : "Microchip MPLAB C30 License Manager Version v3_11 (Build Date Jul 16 2008). Copyright (c) 2008 Microchip Technology Inc. All rights reserved. The MPLAB C30 license manager command-line is invalid. pic30-coff-cc1.exe: error: License manager failure, please contact your support representative or http://support.microchip.com" 2) After Installing MPLAB MPLAB_C_ComboFull_v3_11 - Run pic30-lm.exe -uMTI035248989 from DOS prompt .Following message appears next : "Microchip MPLAB C30 License Manager Version v3_11 (Build Date Jul 16 2008). Copyright (c) 2008 Microchip Technology Inc. All rights reserved. Adding License MTI035248989." Then also, building/making project in MPLAB 8.1 gives the same error as stated in point 1 above. I request for any other suggestion.
Wannabe
-Given: 228
-Receive: 285
« Reply #16 on: August 02, 2008, 11:55:55 23:55 » |
Very strange, I have no problems with my installation Is your computer date set correctly? Try using other serials, according to my earlier posted formula. Others having the same problems?
RADS
« Reply #17 on: August 03, 2008, 03:40:53 15:40 » |
As you mentioned, I checked the system date & corrected it. Its working now !
piotrsus
« Reply #18 on: August 03, 2008, 11:45:11 23:45 » |
I have exactly the same problem as RADS. Please explain how to set the system date?
Wannabe
-Given: 228
-Receive: 285
« Reply #19 on: August 04, 2008, 01:15:06 01:15 » |
Go to Control Panel / Date & Time Properties... If your CMOS battery is dead, you could experience loss of current date every time you turn off/hibernate your computer.
« Last Edit: August 04, 2008, 01:17:37 01:17 by Wannabe »
micropar
-Given: 44
« Reply #20 on: August 04, 2008, 03:25:43 03:25 » |
Hi all,
Can any one post direct download link to Full C30 3v11 version similar to version 3v02 posted above?
Is student version is same as full version?
Thanks in advance with regards, --micropar--
« Last Edit: August 04, 2008, 03:27:51 03:27 by micropar »
Wannabe
-Given: 228
-Receive: 285
« Reply #21 on: August 04, 2008, 12:22:11 12:22 » |
mbandala
-Given: 130
-Receive: 305
« Reply #22 on: August 04, 2008, 12:51:05 12:51 » |
Hi all,
You can also see Microchip's C30 info in order to see how different the full and the student versions are... http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010065
puta
-Given: 364
-Receive: 29
« Reply #23 on: August 31, 2008, 12:18:31 00:18 » |
Wannabe,
Do you mean to back-date the PC system current date to 8 Apri 2004 to use the License MTI035248989 ? or, change the date only while the license is applied ? ...
I am not clear about it, and could you plese explain it again
Ta
Wannabe
-Given: 228
-Receive: 285
« Reply #24 on: August 31, 2008, 01:00:57 01:00 » |
Sorry, the picture was just an example of how Setting system date dialog should look like. If everything is ok you should not have to mess with dates, just use the MTI035248989 serial. At least it works nice for me.
