February 28, 2026, 04:45:04 16:45
Author Topic: IDE for CCS compiler  (Read 6914 times)
Husanto
« on: November 27, 2007, 10:23:23 10:23 »
Hai,
   any body can give me IDE utility for CCS compiler???
Thanx
jorge7458
-Receive: 14
« Reply #1 on: November 27, 2007, 11:55:21 11:55 »
hello:
The compiler brings his own IDE
Jorge
vovchik02
-Given: 43
« Reply #2 on: November 28, 2007, 10:21:44 10:21 »
And MPLAB have interfase for this compiller. It's best IDE for pic! Cheesy
jorge7458
-Receive: 14
« Reply #3 on: November 28, 2007, 12:17:43 12:17 »
Hello
It is certain it of the ide MPLAB, but with the IDE of CCS the ICD of CCS can use and to make degub in C
Jorge
vovchik02
-Given: 43
« Reply #4 on: November 29, 2007, 05:39:41 05:39 »
But MPLAB-ICD2 can it's too from MPLAB-ICD + PICC(CCS). Can't compare with CCS ICD but good luck in you debug-bisnes!
ahmetBR
« Reply #5 on: December 04, 2007, 10:53:12 10:53 »
CCS compiler is pretty good but i can't say same thing for their debugger. i use their ICD-U40 and it locks so often preventing me from debugging.
MicroMaster
-Given: 92
-Receive: 87
« Reply #6 on: December 04, 2007, 11:12:39 11:12 »
In my opinion
CCS appear to user friendly with lot of built in functions,
but creates a lot of problems in some codes. some versions are reported to be very troublesome.
But many happy users for it.
I like and use Hi Tech.
MicroMaster
"Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats."
                           Howard Aiken.
tavioman
« Reply #7 on: December 04, 2007, 11:57:33 11:57 »
I always use Visual Studio as IDE for any compiler. It's the best IDE.
- Brain juice -
bliviudaniel
« Reply #8 on: December 05, 2007, 11:09:24 11:09 »
Hi tavioman.
Do you also compile/build from Visual Studio? Or you just used for editing your code?
BLD
tavioman
« Reply #9 on: December 05, 2007, 11:12:42 11:12 »
Yes, I work only in VS.
- Brain juice -
bliviudaniel
« Reply #10 on: December 05, 2007, 11:26:33 11:26 »
So you integrate the PIC compiler into Visual Studio IDE...Interesting idea Roll Eyes
BLD
tavioman
« Reply #11 on: December 05, 2007, 11:32:56 11:32 »
Yes, just use the Makefile Project project at New Project wizzard.
After that in project properties(NMAKE) use the command line:
picc.exe +STDOUT +FH +EW +DF +LN +T +A +ES +M -Z +Y=0 +EA main_file.c
Or use your own options...
- Brain juice -
bliviudaniel
« Reply #12 on: December 05, 2007, 05:42:41 17:42 »
Aha. Nice to be known Cheesy
BLD
mr_sri
-Given: 47
« Reply #13 on: December 16, 2007, 05:51:03 05:51 »
I use MPLAB IDE for CCS compiler. We can connect to icd2 for debuging and programming. Also we can connect to proteus vsm for simulating
petarp
-Receive: 51
« Reply #14 on: March 10, 2008, 03:28:35 15:28 »
CCS IDE from version 4.064 support plugin to debug with Microchip's ICD2.
http://ccsinfo.com/downloads.php
Best Regards
centiane
« Reply #15 on: March 10, 2008, 11:12:07 23:12 »
I am need implement the mplab-ccs.
What is the setting for programing in ccs into the mplab.
Thank very much.
Centiane
tuvoj
« Reply #16 on: March 14, 2008, 09:15:39 09:15 »
2 ways--
Either install MPLAB, THEN CCS (which will auto setup links) OR install CCS-MPLAB plugin, which will then setup linkages
Cheers-Tuvo
