New version X-CUBE-TOUCHGFX Version 4.25.0
Changelog
Version 4.25.0
Release date: March 3rd, 2025
New TouchGFX Designer Features:
Introduced new setting for text bitmap compression cache size.
Redesigned importing of custom containers.
Added setting for disabling internet connection checks.
Support copying translations from unmapped storage to RAM.
Bugfixes in TouchGFX Designer:
Improved performance and reduced UI freezing.
Fixed erroneous Static- and DynamicGraph code generation when named 'graph'.
Fixed ToggleButton pressed and released images from presets being switched.
New TouchGFX Core Features:
Added new partial framebuffer strategy for LTDC-driven displays.
Added 4Bpp bitmap font compression.
Project updater support for STM32CubeMX CMake projects.
Added support for optimized single buffer mode in rotated display.
Added support for video playback in rotated display.
Added new libraries compatible with IAR9 Libcpp (C/C++17 runtime) projects.
Supporting text translations in unmapped external flash.
Supporting user configurable block dimension for partial framebuffer.
Added support for VectorRenderer::setStrokeMiterLimit(), VectorRenderer::setStrokeLineJoin() VectorRenderer::setStrokeLineCap() functionality on NemaP and NemaPVG platforms.
Added getText() to TextButtonStyle.
Added new method HAL::InvalidateTextureCache().
Added new hooks waitUntilTransmitEnd() and waitUntilCanTransferBlock(uint16_t bottom) to PartialFrameBufferManager.
Improved render performance on NemaP and NemaPVG platforms.
Bugfixes in TouchGFX Core:
Fixed invalidated areas in Wipe and Cover transition.
Fixed Wipe and Cover transition on GPU2D in rotate90.
Fixed LCD32bpp::fillBuffer when no alpha in background.
Fixed numeric fractions when writing RTL text.
Fixed SVG stroke in rotated display.
Fixed SVG gradient in rotated display.
Fixed bug in translation.rb to better handle extra columns.
Fixed warning in translation.rb related to document classifications.
Videoconvert.rb generated old assembly syntax to include video data for Cortex-M55 on Keil.
Fixed bug where ImageConverter would fail to generate assets if a Thumbs.db file is present in the asset folder.
Fixed compiler warnings in CWRUtil::toQ5() and CWRUtil::toQ10() functions.
Fixed bug where ImageConverter would compress RGB images in a wrong pixel format compared to framebuffer pixel format.
Fixed issue with unaligned access in GeneratedFont::getPixelData().
Fixed Vector Font render error.
Fixed issue where Texture Mappers on NemaP platforms could draw wrong pixels.
Fixed bug where Graph widget did not clear correctly.
