You think I am funny guy huh?
April 03, 2025, 12:29:34 00:29
Author Topic: Electronic Load Circuit LM324 4 x 2 Mosfet PCB_Project  (Read 3983 times)
sphinx
-Given: 622
-Receive: 283
« on: December 16, 2024, 02:24:47 14:24 »
This is a design based on https://320volt.com/en/electronic-load-circuit-lm324-4-mosfet/, i did a dubble up to 8 MOSFET's
Depending mosfets used this circuit can handle quite some amperes, all done in ad25
I didnt make any manufacturing files since it depends on mosfets used and some changes will have to be made
PLEASE RECHECK FOR ANY ERRORS
have fun with the design.
P.S. I FORGOT TO SAY THAT MOSFETS ARE MOUNTED FROM THE BOTTOM SIDE!!! FEEL FREE TO MODIFY SIDE IF WANTED!
/s
« Last Edit: December 16, 2024, 03:48:09 15:48 by sphinx » Logged
sphinx
-Given: 622
-Receive: 283
« Reply #1 on: December 16, 2024, 09:00:04 21:00 »
I also read about diode protection of the mosfets
either a single diode or a bridge with enough amps and reverse voltage
also think of that quite a bit of amperes is going thruu the copper so choose/pick thick 2oz or higher or add more wires and heavier duty connection
« Last Edit: December 17, 2024, 01:20:02 01:20 by sphinx » Logged
