Tom1234
Online
« on: September 17, 2024, 09:56:43 09:56 » |
I am looking for information and resources about use LORA to transmit video from drone to ground.
Is anyone that have experience on this ?
Wilksey
-Given: 161
-Receive: 2549
« Reply #1 on: September 17, 2024, 10:09:08 10:09 » |
Erm, LoRa is designed for short packets of data if you try and transmit video it will probably end up killing the signal, and you certainly won't get long range.
I've designed and built several LoRa products for various industries, and it's not the right technology for large volumes of data, it is usually linked to sensors and such that send a short data packet every now and then.
Tom1234
Online
« Reply #2 on: September 17, 2024, 11:25:03 11:25 » |
I mentioned LORA because of this : https://www.youtube.com/watch?v=4J2ihHOnlD4 This is not LORA? If LORA is not the solution what option exist ?
Tom1234
Online
« Reply #4 on: September 17, 2024, 01:11:54 13:11 » |
When you said " the range will be reduced" what is range to send an average or a good quality of a video ?
except of LORA can you suggest anything else ?
an007_rld
-Given: 33
-Receive: 55
« Reply #5 on: September 17, 2024, 04:21:43 16:21 » |
Wilksey
-Given: 161
-Receive: 2549
« Reply #6 on: September 17, 2024, 05:13:33 17:13 » |
It all depends on your setup, antenna's weather conditions, anything in the line of sight, anything else on the same frequency etc etc, it is a very much test it and see, different directions gave me different ranges, with omni directional antennas, but your application might be better with directional, we as designed a power amplifier to give us extra power, as long as you stay within your county's radio emission rules. For one test on paper it should have reached approximately 1000m but it was very intermittent we only got a "stable" test at 300m.
Posted on: September 17, 2024, 05:08:10 17:08 - Automerged
How far are you trying to transmit the video? I would have a look at the devices they use on drones, quick google will give you some results, they can be expensive though.
Tom1234
Online
« Reply #7 on: September 17, 2024, 08:59:09 20:59 » |
Honestly i don't know where to start, i was looking for any project exist at internet with out success I was looking the specs from a drone : https://enterprise.dji.com/matrice-350-rtk/specs
Wilksey
-Given: 161
-Receive: 2549
« Reply #8 on: September 18, 2024, 10:53:35 10:53 » |
