April 02, 2025, 07:48:04 07:48
Author Topic: support for multisim  (Read 2606 times)
mr_byte31
-Given: 75
-Receive: 144
« on: July 03, 2024, 10:39:07 22:39 »
Hi Folks,
I designed this circuit on multisim and I wanted to connect GND to pin6 for compartor (max913). Multisim gave me error that it can't converge.
I also noticed that the Q output is moving from -4v to 1v
and Q\ is moving from -9v to -4v , i think the values are going crazy.
i attached the project.
« Last Edit: July 03, 2024, 10:49:38 22:49 by mr_byte31 » Logged
optikon
-Given: 1118
-Receive: 2007
« Reply #1 on: July 04, 2024, 04:00:54 04:00 »
I dont have multisim to look at your circuit. But I always suspect the subcircuits. They can often have models that are not convergence friendly.
If is a DC operating point failure or a time step failure.?
sometimes slewing sources on startup or adding R & C's to some nodes that change rapidly can help.
If you are convinced it is in the maxim model and cant resolve it, then perhaps you can just make a simpler version of it to test out your circuit.
Just some ideas.
mr_byte31
-Given: 75
-Receive: 144
« Reply #2 on: July 04, 2024, 09:41:45 21:41 »
That was the error :
« Last Edit: July 04, 2024, 09:44:12 21:44 by mr_byte31 » Logged
