April 01, 2025, 11:08:25 23:08
Author Topic: PCB Microscope  (Read 4364 times)
-Given: 561
« on: May 27, 2024, 08:55:17 20:55 »
Hi all,
I’m looking for recommendations for a good microscope with screen or with output for monitor.
I’ve got one of those cheap ones but it’s not very good
sphinx
-Given: 622
-Receive: 283
« Reply #1 on: May 27, 2024, 09:03:41 21:03 »
is it for repair or inspection
for repair its is ok with 10x and below 5-7x will be ok
if it is for inspection you can go higher
i suspect you are talking about stereo microscopes
there you get depth vision
you can check l rossmans repairs i remember that he talked about the most preferrable magnification when doing repairs
i cant remember when it was but it was some time ago
get one where you can adjust its magnification lets say 1-10x
also the focus length is also of importance movement to and away from the lens where it stays focused
« Last Edit: May 27, 2024, 09:14:16 21:14 by sphinx » Logged
-Given: 561
« Reply #2 on: May 27, 2024, 09:33:16 21:33 »
It’s mainly for repair really, I’ve also heard you can use and heat seeking camera to aid detect faulty components ?
I might be getting involved in repairs on circuit boards for someone and just weighing up the pros and cons
Xwing
-Given: 595
-Receive: 1530
« Reply #3 on: May 27, 2024, 11:07:06 23:07 »
I use an Andonstar AD249S, both for inspection and for assembly, I find it excellent and has an affordable cost.
sphinx
-Given: 622
-Receive: 283
« Reply #4 on: May 28, 2024, 12:37:19 00:37 »
heat camera is excellent addition for servive surely much better than finger sensory
a zoom between 1 to 10 would suffice the higher you go the shorter th focal length will be
you will mostly be using 4 to 7 depending on component size qnd your eyes
microstick
-Given: 123
-Receive: 12
« Reply #5 on: May 28, 2024, 08:01:40 08:01 »
Try This one
https://www.amazon.de/-/en/gp/product/B0C5MJFX1X/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I have it and very satisfied. High enough so can solder below it,
The minus is that magnification is too high, and some times you need smaller one, but can not change. However it is perfect for my use (semi professional) and very low cost and very good quality. Can make video, shoots, working with internal batter, connection to USB as  also to PC.
-Given: 231
-Receive: 990
« Reply #6 on: May 28, 2024, 09:24:01 09:24 »
Here are some videos to give you some ideas. Not meant as a product endorsement. This guy sell rebranded AMSCOPE products, or at least get things from the same manufacturer just saying
https://www.youtube.com/watch?app=desktop&v=NfkXitg5R4I
https://www.youtube.com/watch?v=NtBiFHq2Qwc
https://amscope.com/products/led-6w
Edit: The camera look like a Lapsun 1080P 60FPS SONY IMX385 V2 according to this video
https://www.youtube.com/watch?app=desktop&v=5upKluG-qi8
looking more into it you can find all the products here https://lapsun.aliexpress.com/store/612308? spm=a2g0o.detail.0.0.7c9aJ6lAJ6lAGV (here they offer power adapters with the correct wall socket for your country)
or here http://lapsun.com/
« Last Edit: May 28, 2024, 09:27:54 09:27 by Sideshow Bob » Logged
-Given: 561
« Reply #7 on: May 28, 2024, 08:04:53 20:04 »
Thanks guys that’s give me some food for thoughts
CortexM0Inside
-Receive: 36
« Reply #8 on: May 29, 2024, 11:27:49 11:27 »
Why I prefer HDMI Microscope and not Binocular Stereoscope. What is a Barlow lens and comparison
https://www.youtube.com/watch?v=NfkXitg5R4I
https://northridgefix.com/product/microscope-camera-bundle-1080-60fps-180x-lens-ring-adapter-2-barlow-lenses-0-5x-0-75x/
pushycat
-Given: 228
-Receive: 1448
« Reply #9 on: June 24, 2024, 09:15:04 09:15 »
My personal experience says that if you always handle small devices like mobiles etc, there are lot good ones. But if you are also handling SMD devices with through hole too, just as in the case like Alex from Northridgefix, consider to try microscopes with detachable lenses, and those which are supplied with lens with longer focal length, say more than minimum 6 inches from the board to the lens and maximum focal of 12 inches work excellent. Or the silliest problem you will face is working on the board with a soldering iron / multi meter probes, and these will touch the lens. This case will make you concentrate on taking care of your lens rather seeing / working on the board. I had personally faced this and fortunately found a mobile repair shop guy who was interested in it.
