-Given: 833
-Receive: 4320
« on: March 23, 2024, 12:54:17 12:54 » |
-Given: 553
« Reply #1 on: March 23, 2024, 06:43:59 18:43 » |
Looks nice easy to sue, I would have to look at changing my utc1000 controller: which one would you recommend to use or build ?
-Given: 833
-Receive: 4320
« Reply #2 on: March 23, 2024, 06:53:28 18:53 » |
Looks nice easy to use, I would have to look at changing my utc1000 controller: which one would you recommend to use or build ?
It was developed for use with Chinese cnc machines. full list here. https://drufelcnc.com/?c=controllersthis is popular choice. https://www.ebay.co.uk/itm/234921585921?
« Last Edit: March 23, 2024, 07:06:55 19:06 by pickit2 »
-Given: 553
« Reply #3 on: March 23, 2024, 11:52:03 23:52 » |
My cnc is an old Chinese 6040 but ended up doing some upgrades and used 3 CW5045 Microstepping Drivers with the USB MOTION CONTROLLER uc100 and Mach 3, but sometimes it gets a glitch and freezes. The one in the link you posted would I still need to use the stepper drivers ?
-Given: 833
-Receive: 4320
« Reply #4 on: March 24, 2024, 01:23:29 01:23 » |
Yes you need the drivers, for the board above, as it only had step & direction outputs. is this the same controller as you have? if so it was on the list of boards that are supported https://www.amazon.co.uk/Interface-Motion-Control-Engraving-Machine/dp/B0CBNTYXRR
« Last Edit: March 24, 2024, 01:47:17 01:47 by pickit2 »
-Given: 553
« Reply #5 on: March 24, 2024, 09:20:44 09:20 » |
No this is the motion controller I have https://www.cnc4you.co.uk/Motion-Control/UC100-USB-Motion-ControllerAnd this is the kit I have https://www.cnc4you.co.uk/CNC-Kits/Stepper-Motor-Kits/2.2Nm-3-AxisWonder if the motion controller in the link posted work with the CP0-10V Breakout Board from that kit ? Guess for the cost of that motion controller I could get one to try
sfiga69
-Given: 199
-Receive: 159
« Reply #6 on: March 24, 2024, 11:09:01 11:09 » |
-Given: 553
« Reply #7 on: March 24, 2024, 11:24:12 11:24 » |
I'm updating my self-built cnc with assembled electronics, now with parallel breakout board and dm556 drivers are similar to yours, with this usb:
I just ordered it, I'll update as soon as it arrives.
Is this one to use with software uploaded here or with mach3 ?
-Given: 833
-Receive: 4320
« Reply #8 on: March 24, 2024, 02:32:14 14:32 » |
I think it can be used with both software. the one posted here is supplied by most China CNC Machines. developed to use usb port, in place of the 25pin printer port used by the mach software . Posted on: March 24, 2024, 03:21:23 15:21 - Automerged
the board posted replaces this board, it is as near identical with the added controller on the pcb.
sfiga69
-Given: 199
-Receive: 159
« Reply #9 on: March 24, 2024, 05:23:14 17:23 » |
on the buildyourcnc site at the indicated link, there is the driver and instructions step by step for using the breakboard with mach3 the driver is called RnRMotion.dll in the instructions it is indicated how to load and configure it.
-Given: 553
« Reply #10 on: April 01, 2024, 09:11:34 21:11 » |
Which is the better controller out of the 2 shown on here ? Or any recommended descent usb controller that does not have to convert to parallel port (has these don’t exist anymore) Also I know you really or possible to say which is the better software out of these two, I know Mach 3 is really good but it’s so old now and not moved forward in years. I’ve seen Mach4 but not seen a cracked version may be I can try the demo of it and would have to look into which controller is supported
-Given: 833
-Receive: 4320
« Reply #11 on: April 02, 2024, 11:38:48 11:38 » |
https://www.youtube.com/watch?v=BBoTkRH2E_I have a look at this vid, this board will work with both Mach 3 and DrufelCNCx64 software. can be had for as little as £15 - you do need motor drivers . you can use the ones you have. but again you can get them cheap. Posted on: April 02, 2024, 12:35:37 12:35 - Automerged
As to the Software I think DrufelCNCx64 is easier to use than Mach3.
Checksum8
-Given: 124
-Receive: 102
« Reply #12 on: April 02, 2024, 05:13:07 17:13 » |
I was going to order one of the Red - Eagle boards. On ebay some come with a CD. Does anyone know which program is on this cd?
Add: I can answer my own question. I received my board its the red one suggested above, it is compact and well built. The dvd that came in the box has a 2018 version of USB Mach3 which I assume has a fixed license. There are a bunch other files that are in Chinese.
« Last Edit: April 08, 2024, 08:31:04 20:31 by Checksum8 »
-Given: 833
-Receive: 4320
« Reply #13 on: May 31, 2024, 02:11:17 14:11 » |
https://drufelcnc.com/ has a lot of information on setting the board up and how to calibrate it. Have you tried it yet?
Checksum8
-Given: 124
-Receive: 102
« Reply #14 on: May 31, 2024, 05:12:35 17:12 » |
No, I have not had the time.
