November 21, 2024, 09:54:05 09:54
Author Topic: MPLAB® Code Configurator (MCC) Melody  (Read 3323 times)
Catcatcat
-Given: 284
-Receive: 1644
« on: December 08, 2023, 12:20:44 12:20 »
Decided to switch to MPLAB® Code Configurator (MCC) Melody...
Everything got better in the beginning. everything is cool until the moment when I decided to open main.c, I get the message:
The file C:/Project/Project_MPLABX/2023/***/***/***.X/main.c cannot be safely opened with encoding UTF-8. Do you want to continue opening it? It maybe be associated with more than one open project. Please check the encoding in each of the projects.
!!! I think I didn’t understand, I’m creating a project in UTF-8 encoding!!!
I check all the files, and they are created in ANSI encoding.
But that's not all the problems. Once you exit the melody, then you enter, and the entire configuration disappears.
I'm creating a project in MPLAB® Code Configurator (MCC) Classic, is everything ok? everything works, but there are no opportunities that Melody provides. Sad
Has anyone encountered such a problem? Or is it just me? Maybe I need to learn some kind of “dance with a tambourine” and be sure to perform it before loading the Melody?
Or is this just another glitch and we need to wait for an update?
Any thoughts on this are welcome?
arslanweb
« Reply #1 on: December 21, 2023, 06:10:54 06:10 »
Sometime, that come from your java setup. mplabx is a java application. check the java setup.
