Can, please, anyone send me a reference, little guide, whatever that help me in this mess?
as already mentioned, reference for NEMA17 is only the face plate, so center cylinder size, hole mount and that is it...
All electrical properties depends on the maker.
exactly, and if you are not geting some reputable brand but ordering from PRC the electrical properties they adverties are for reference only, they have nothing to do with real data.
but do not despare!!
there are only few important aspects of the stepper motor
- inductance
- holding torque
- running torque
- current
- rotor inertia
Inductance you can measure with any decent LCR meter. With inductance you can then calculate maximal speed without torque drop
Torque will depend on the length of the stepper and some other parameters, since you already have a motor, who cares, plug it in and see if it has enough torque or not, if it stalls it dont
.. of course you can measure the torque too you can find ton of videos online on how to do it
Rotor inertia - this is important if you have really high acceleration and often speed changes, I have no clue how to measure this but again since you can not change it on the motor you already have who cares
Current - this is the most important aspect you need to know to get most out of your motor. You drive motor with current, not voltage, so even when motors do have voltage rating that is completely useless info. You want to know maximum current you can pass through the motor. This is rather simple to get to - more current you pass through motor more motor will heat up. Max safe operating temperature for the motor is around 70C but for e.g. I target 50C to be on the safe side. Increase current your driver is driving your motor with untill your motor is running at around 50C and that is your max safe current for your motor.
I am using this technique for 10+ years building robots, 3d printers, cnc machines and it never failed me. You look at parameters when you are purchasing motors, and if you need to get motor with certain parameters just forget PRC and get decent ones from Germany or Sweden or Japan ... but if you already have some, it is rather easy to determine how to drive them as wrt max voltage the limit will be your driver and not the motor, current limit you get to by measuring temperature... everything else you can not change so who cares..
