November 21, 2024, 10:10:33 10:10
Author Topic: LinkCAD windows/linux  (Read 4888 times)
zelea2
-Given: 8
-Receive: 183
« on: December 01, 2021, 12:04:52 00:04 »
LinkCAD is a translator / viewer for various CAD formats.
  • Display the loaded drawings in the built-in CAD viewer, measure distances and highlight broken polylines.
  • Use several tools to merge overlapping polygons, join adjacent wires, auto-detect holes and perform many other operations.
  • Correct common design problems, such as open or self-intersecting polygons.
  • Convert several files without user intervention in batch mode.
  • Integrate LinkCAD in your workflow by running it from the command line and customizing the user interface.
  • Fix damaged files, which cannot be read by other software.
I've included the latest version (9.10.1) which runs on Windows/64bit. It also runs fine in linux under wine64.
You may also use two quite old versions for Windows/32bit and native Linux/32bit (they don't support the linux platform anymore).
Just install and run.
« Last Edit: December 01, 2021, 01:16:43 01:16 by zelea2 » Logged
