November 21, 2024, 09:34:10 09:34
Author Topic: Autodesk Inventor pro + Autodesk InventorCAM - All Versions  (Read 6706 times)
w41k0v3r
« on: February 17, 2021, 12:58:10 12:58 »
It is not from me but I looked for a Solidworks alternative and I found Inventor pro and all tools needed.
You need to download Inventor with the link provided in the attached file and install it.
The trick is to uninstall v.10 and install v.9  Autodesk Licensing Service
Open your file explorer , paste this in address bar :
C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\
and run uninstall.exe
Wait few minutes till all files disappears, and just to be sure remove AdskLicensing and ADLM folders in C:\Program Files (x86)\Common Files\Autodesk Shared
Install Adsk in ver.9, wait till the process end. Disable network adapter, run 2020 keygen and activate your 2021
You have to run the keygen in admin mode.
Hope it helps  Smiley
« Last Edit: November 07, 2021, 11:44:20 23:44 by pickit2 » Logged
Catcatcat
-Given: 284
-Receive: 1644
« Reply #1 on: February 17, 2021, 04:18:12 16:18 »
Support and recommend, this year I started working on it, is very easy to understand, I use it to create cases and docking for printed circuit boards Cheesy  downloaded from rutracker link Autodesk Inventor Professional 2021.1.2
kiltro
« Reply #2 on: November 04, 2021, 10:37:55 10:37 »
Does someone has Feature Recognition for Inventor?
bobcat1
-Given: 4273
-Receive: 94
« Reply #3 on: November 07, 2021, 06:51:55 06:51 »
HI all
those Inventor can be compared to solidworks in any way?
All the best
Bobi
Catcatcat
-Given: 284
-Receive: 1644
« Reply #4 on: November 07, 2021, 08:07:21 08:07 »
Of the mechanics I know, who own the work in both the inventor and the solidworks, the preference is given to the inventor.
Molo
-Given: 69
« Reply #5 on: November 02, 2022, 06:55:11 18:55 »
I tried to DL both KG and LIC Service where not active anymore..
Is there any change, to get new DL links.
Thank you in advance.
Cyberrat
-Given: 567
-Receive: 128
« Reply #6 on: January 04, 2024, 10:13:04 22:13 »
Can someone upload this again plase?
-Given: 833
-Receive: 4319
« Reply #7 on: January 06, 2024, 02:42:56 14:42 »
There is a good rutracker for 2004
Size is 8.7 GB    plus (70 seeds)
« Last Edit: January 06, 2024, 02:48:19 14:48 by pickit2 » Logged
