November 21, 2024, 10:06:51 10:06
Author Topic: PIC C code for tft lcd ?  (Read 5595 times)
max
-Given: 1659
-Receive: 52
« on: November 02, 2021, 07:51:51 07:51 »
I want to interface the arduino uno tft lcd module 2.4" and 3.5" type
to pic uc, these modules use the parallel interface.
Is there any lib or c source available for pic?
mars01
-Given: 696
-Receive: 1774
« Reply #1 on: November 02, 2021, 01:17:27 13:17 »
Should not be that hard to port an Arduino lib to the PIC uC. All you need is to make sure that you have enough pins and enough RAM to fit the framebuffer into it + whatever you need for the processing.
Old_but_Alive
-Given: 744
-Receive: 120
« Reply #2 on: November 02, 2021, 01:54:49 13:54 »
try the CCS website, they have loads of code
http://www.ccsinfo.com/forum/viewforum.php?f=2
do search on tft
Also try the microchip forums.
best to search on the TFT controller number such as ILI9486, or  ST7783 or or  ILI9325 or SSD2119 etc
This link looks just what your after  http://www.ccsinfo.com/forum/viewtopic.php?t=50520&highlight=tft
« Last Edit: November 02, 2021, 03:19:47 15:19 by Old_but_Alive » Logged
max
-Given: 1659
-Receive: 52
« Reply #3 on: November 02, 2021, 06:45:46 18:45 »
Hi mars01
I have no experiance in c++, arduino libraries uses the c++ code,
is there any guidelines for converting the c++ code to c code.
Wilksey
-Given: 161
-Receive: 2549
« Reply #4 on: November 02, 2021, 07:56:17 19:56 »
Is it this TFT? https://create.arduino.cc/projecthub/electropeak/arduino-2-4-touch-screen-lcd-shield-tutorial-fe6f05 do you know what driver you particular TFT uses?
max
-Given: 1659
-Receive: 52
« Reply #5 on: November 03, 2021, 08:46:38 08:46 »
Hi Wilksey
Yes this is the lcd I have.
In arduino software to use the 2.4" lcd the ID is 0x9325
for 3.5" lcd the ID is 0x9481
using mcufriends n adafruit graphics lib
Old_but_Alive
-Given: 744
-Receive: 120
« Reply #6 on: November 03, 2021, 10:04:04 10:04 »
it looks like it uses the ILI9325 or the ILI9481
try searching on them
I found this on the CCS site, there are 3 hits.
http://www.ccsinfo.com/forum/viewtopic.php?t=50520&highlight=ili9325
As I said in an earlier reply, the microchip forums will have discussions also
Wilksey
-Given: 161
-Receive: 2549
« Reply #7 on: November 03, 2021, 12:00:05 12:00 »
This Microchip forum post might be of some use: https://www.microchip.com/forums/m542888.aspx?tree=true
