December 21, 2024, 04:33:34 16:33
Author Topic: 16f1937 mikroC problem  (Read 4601 times)
ahmed
-Given: 101
-Receive: 601
« on: October 17, 2021, 09:23:54 09:23 »
Hello , I want to interface a keypad and LCD with pic16f1937.
Everything is working fine over 16f877a but with controller it is not working at all.
Project folder and Proteus simulation file is attached , any help would be appreciated.
zuisti
-Given: 242
-Receive: 780
« Reply #1 on: October 17, 2021, 12:10:09 12:10 »
Hi Ahmed;
First, set ANSELA to zero so that you can use the PORTA bits as digital I/O.
Second, to avoid RMW problems use LATAx bits to define the LCD module connections (instead of the RAx bits).
Study the datasheet!
Greets: zuisti
« Last Edit: October 17, 2021, 12:23:03 12:23 by zuisti » Logged
ahmed
-Given: 101
-Receive: 601
« Reply #2 on: October 17, 2021, 12:57:15 12:57 »
Hi Ahmed;
Greets: zuisti
I am bit confused with these datasheet variables , studying about mikroc (newbie)
Can you give me any good example please?
or modify the code , if possible.
Edit:
By the ANSELA=0; solved the problem Smiley
« Last Edit: October 17, 2021, 01:00:58 13:00 by ahmed » Logged
jack12345
-Given: 57
-Receive: 134
Happy diy
« Reply #3 on: October 19, 2021, 04:07:25 16:07 »
I took the time to take a look!!
pic16f1937 portA output I/O
Execution can be displayed!!
jack12345
-Given: 57
-Receive: 134
Happy diy
« Reply #4 on: October 22, 2021, 12:52:28 00:52 »
This website has some examples of mikroC Projects pic18F!!
But there is no pic16f1937 chip!!
https://simple-circuit.com/mikroc-projects/
