November 21, 2024, 09:35:04 09:35
Author Topic: QCAD/QCADCAM-v3.28.2 Windows/Linux  (Read 6178 times)
zelea2
-Given: 8
-Receive: 183
« on: May 05, 2021, 06:57:55 18:57 »
QCAD is a powerful 2D CAD system with an intuitive user interface.
Main Features:
  • Layer support
  • Blocks (grouping)
  • 35 CAD fonts included
  • Support for TrueType fonts
  • Metrical and Imperial units
  • DXF and DWG input and output (R11 to R32)
  • SVG import (only basic geometry is imported) and export
  • PDF export drawing as PDF (multiple pages)
  • Printing to scale
  • Printing on multiple pages
  • Over 40 construction tools
  • Over 20 modification tools
  • Construction and modification of points, lines, arcs, circles, ellipses, splines, polylines, texts, dimensions, hatches, fills, raster images
  • Various powerful entity selection tools
  • Object snaps
  • Measuring tools
  • Part library with over 4800 CAD parts
  • Powerful ECMAScript (JavaScript) scripting interface
  • Command line tools (dwg2pdf, dwg2svg, dwg2bmp, etc.)
  • QCAD/CAM: G-Code export, Nesting
Installation:
If you plan to use this software with a CNC machine and generate NC code
from your designs choose QCAD/CAM, otherwise choose QCAD Professional
Choose the version most suited to your operating system and run the installer.
Executables are already patched.
« Last Edit: September 15, 2023, 12:36:46 12:36 by zelea2 » Logged
zelea2
-Given: 8
-Receive: 183
« Reply #1 on: June 10, 2021, 05:46:39 17:46 »
New version 3.26.4
« Last Edit: November 30, 2021, 11:47:02 23:47 by zelea2 » Logged
zelea2
-Given: 8
-Receive: 183
« Reply #2 on: September 15, 2023, 12:33:13 12:33 »
Latest versions QCAD and QCAD/CAM v3.28.2 Windows/Linux
