April 28, 2025, 01:58:45 01:58
Author Topic: Embedded Pascal for the 805x  (Read 4346 times)
zetd
-Receive: 32
« on: November 23, 2007, 02:28:13 02:28 »
The Embedded pascal MKII compiler contains a device definition system allowing you to setup the compiler for any 8051 derivative processor such as those available from Dallas, Philips and others. The only requirement is a binary compatible processor core !
Embedded Pascal for the 805x is a one-stop solution for your 8051,8052 and related designes. Briefly, Embedded Pascal for the 805x provides these features:
    * Design your application using any mixture of Assembler and/or Pascal source code.
    * Fully integrated IDE running under Windows 95,98 and NT.
    * Full 32 bit implementation. No DOS code.
    * State-of-the-art, optimizing code generator.
    * Use for small applications with only limited, internal memory or...
    * Use for large applications with external memory.
    * External memory XData and Code joined or seperate.
    * Compiler generates Assembler source code.
    * Multi-module projects. Pascal units or C style modules.
    * Unique, multipass optimizing linker.
    * Borland Delphi compatible, extended Pascal language.
    * Bit, Boolean, Byte, Shortint, Integer, Word, Triplet, Longint, Single (Real) Char and String data types.
    * Multi-dimensional arrays, records and constant sets.
    * Full set of string manipulation functions (copy, insert, delete, etc...)
    * Unique register tracking feature for easy implementation of high-level interrupt routines.
    * Full library source. Yes, all of it !
    * The fastest Windows based 8052 simulator available.
    * New ! Compact and fast full feature floating point library including source code !
    * Many more features. Download and try...
    http://users.iafrica.com/r/ra/rainier/
    any body have crack for it ?
Dreams really do come true, when home robots do the dirty work for me. everythink is free, no war, no poison on my earth, everyone share thinks but not with my pretty girls,powered by science and humanity not by "dazzle think" - welcome to the planet of earth -
encosat
« Reply #1 on: January 20, 2008, 12:57:19 12:57 »
I don't have any crack for it but maybe for dutch readers here is a book title:
Pascal voor de 8051-familie
Author: O'Niel A.V. Som
