February 22, 2025, 05:34:11 17:34
Author Topic: Three servo tester with potentiometers  (Read 8235 times)
Deimos
-Receive: 14
Whatever...!!!
« on: November 22, 2007, 04:37:47 16:37 »
You can prove your servos with potentiometers, it shows in the lcd the current position of the servomotor.
Code in PBP for Pic micro:
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 5
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 4
Define ADC_BITS 8
Define ADC_CLOCK 3
Define ADC_SAMPLEUS 50
adval var byte
b0 var byte
b1 var byte
b2 var byte
b6 var byte
b7 var word
mover var word
TRISA = %11111111
ADCON1 = %00000010
pause 250
lcdout $FE,1,"SRV1 SRV2 SRV3"
start:
 lcdout $FE,$C0,dec3 b0,"  ",dec3 b1,"  ",dec3 b2
    PORTC = 0
    pulsout PORTC.0, b0
    pulsout PORTC.1, b1
    pulsout PORTC.2, b2
    b7 = b0 + b1 + b2
    b6 = b7/100
    b7 = 15 - b6
    pause b7
 Adcin 0, b0
 Adcin 1, b1
 Adcin 2, b2
    goto start
end
I think it is useful to study the positions of the servos to make a simple robot.
I hope that simple example will be useful.
Enjoy  Grin
« Last Edit: November 22, 2007, 05:44:51 17:44 by Deimos » Logged
Saludos desde Ecuador
Deimos
-Receive: 14
Whatever...!!!
« Reply #1 on: November 25, 2007, 03:22:53 03:22 »
Here's a video of this project, im usin three hitec HS-311 servos:
http://www.youtube.com/watch?v=DRM2oxue3Dc
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #2 on: November 25, 2007, 03:56:04 03:56 »
nice video !
would you show in detail how you made the opening/closing clamp ??
greetings
Deimos
-Receive: 14
Whatever...!!!
« Reply #3 on: November 27, 2007, 04:58:14 16:58 »
you can buy the grip here:
www.lynxmotion.com
here is an image:
robban
-Given: 34
-Receive: 38
Warrior
« Reply #4 on: November 27, 2007, 10:02:24 22:02 »
What kind of servos are You using? The normal servo signal is a 2 ms spike and 20 ms period...
Code Warrior
frasenci
Translator
-Given: 142
-Receive: 85
« Reply #5 on: November 28, 2007, 12:08:05 00:08 »
Good point robban.
Maybe , deimos forgot an important step in his/her code wich is the scaling of the value obtained from ADC , to fit standard pulse length used by RC servos like the one shown on foto.
For info , a standard RC servo like Hitec , Futaba will use :
Far left : pulse length  = 1000 ms
Center   :                  = 1500 ms
Far right :                  = 2000 ms
by all means , pulses must be fed into servo electronics at least every 20 ms ( 50 hz ) . Otherwise , servos willl shutter
my 10 cents
greetings
robban
-Given: 34
-Receive: 38
Warrior
« Reply #6 on: November 28, 2007, 12:46:20 00:46 »
That's correct Fracenci. Myself, I use a PWM(sort-of)-signal so I can gain full control from the RC-control:
' Program to move RC servo using potentiometer(Proton)
//for the 16f628 or whatever; the smaller the better and don't forget to use as low freq as possible for battery longevity
' Define ADIN parameters
      ADIN_RES = 10         ' Set number of bits in result
      ADIN_TAD = FRC         ' Set clock source (3=rc)
      ADIN_STIME = 100                   ' Set sampling time in uS
      Pos     Var     Word      ' Servo position
      Symbol Pin = PORTB.3      ' Alias servo pin
      Input TRISA         ' Set PORTA to all input
      TRISB = %11110000      ' Set PORTB.0-3 to output
      PORTB = 0         ' Set PORTB.0-3 low
           ADCON1 = %10000010                   ' Set PORTA analog and right justify result
' Main program loop
   loop:
   Pos = Adin 0         ' Store value of analog input in pos
        Servo Pin , 1500 + Pos                          ' start with center
        Delayms 20            ' Servo update rate
        Goto loop            ' Do it all forever
        End
« Last Edit: November 28, 2007, 12:50:21 00:50 by robban » Logged
Code Warrior
Deimos
-Receive: 14
Whatever...!!!
« Reply #7 on: December 05, 2007, 04:50:44 04:50 »
I'm using HS-311 servos.
