April 04, 2025, 07:15:08 07:15
Author Topic: anonymize stp files made for Wakefield-Vette series 690 ?  (Read 4089 times)
sphinx
Online Online
-Given: 622
-Receive: 283
« on: December 01, 2020, 08:16:53 08:16 »
I am wodering if there is a way to anonymize stp 214 files for upload to 3dcontentcentral to share? Since i don't want to upload CATPart files because it is a binary format
and i do not know if there is any info in those files that could identify me.
« Last Edit: December 01, 2020, 08:58:16 08:58 by sphinx » Logged
token0
-Given: 55
-Receive: 97
« Reply #1 on: December 01, 2020, 09:20:32 09:20 »
Try to convert one of these binary files to some non-binary format and look inside with some text editor. Also check for NTFS Alternate streams of such file for hidden text metadata (use this tool http://hex.pp.ua/ntfs-stream-explorer-eng.php). It everything is good, then proceed with upload.
sphinx
Online Online
-Given: 622
-Receive: 283
« Reply #2 on: December 01, 2020, 10:27:50 10:27 »
I modified the following lines, i could not find more identifying markers.
FILE_DESCRIPTION(('',''),'2;1');
FILE_NAME('692-25.stp','2020-11-25T14:12:46+00:00',('none'),('none'),'','STEP AP214','none');
FILE_SCHEMA(('AUTOMOTIVE_DESIGN { 1 0 10303 214 1 1 1 1 }'));
first i did take away too much and file would not load in CATIA with above text now it does load.
token0
-Given: 55
-Receive: 97
« Reply #3 on: December 01, 2020, 10:57:41 10:57 »
This file looks 100% clean in my text editor. SW2020 opened it successfully, and integrity check is passed. No compromising data in NTFS Alternate streams is found. You're safe to upload. Wink
-Given: 841
-Receive: 4365
« Reply #4 on: December 01, 2020, 04:18:24 16:18 »
I don't follow what you are trying to share. the files can be downloaded direct and also via mouser.
https://th.mouser.com/datasheet/2/433/690_Series_Data_Sheet_Final-1548218.pdf
-Given: 231
-Receive: 990
« Reply #5 on: December 01, 2020, 04:56:06 16:56 »
It is a free 3D tool named freecad (google it) Maybe you can use it to kind of wash your files. Just an idea from the top of my head. I have no idea if it will work at all
sphinx
Online Online
-Given: 622
-Receive: 283
« Reply #6 on: December 01, 2020, 09:57:07 21:57 »
@pickit  i tried to get these as a 3s body from mouser but they just give me a simple cuboid. so i made extruted bodies in cad.
@ sideshow bob i dloaded freecad and it seems that when exporting to step file it changes the 3 lines of info, so it is a way wash the file. now that iknow
it is also very simple for me to edit the files with a text editor. but i now have a second way to clean/wash files.
Posted on: 2020-12-01, 22:00:31 - Automerged
here are the step files for the Wakefield-Vette series 690 coolers
