I’ve down loaded the first version but not tried it, I’ll down load the latest version and should be able to have a play with it the weekend, has the gaffer is off this week and not been able to get I to workshop to play, I keep telling her I wear the trousers in this relationship once she’s chosen the colour
It will be interesting to have a look and play around with it, proteus is good but sometimes it works slightly different in the real world I find, but most of the time it performs better in the real world than it does in proteus.
I’ll keep you posted might even build it up in real time,
is it still based around this one with the same values and similar wiring .
The only reason I ask I may be able to use the PCB’s I have spare and just hard wire the op-Amps into the Baird as I’ve not opened the file yet to have a look at it
