April 21, 2025, 09:56:23 09:56
Author Topic: PIC12F1612 ZCD IN Proteus  (Read 8663 times)
« on: September 09, 2020, 11:03:52 23:03 »
Anybody succeeded simulating this in Proteus?
Flash50
-Given: 16
« Reply #1 on: September 12, 2020, 03:23:18 15:23 »
I have just tried, yes it is working in Proteus release8.10 sp3.
« Reply #2 on: September 12, 2020, 08:22:47 20:22 »
No it is not.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #3 on: September 13, 2020, 07:12:46 07:12 »
Saying just a yes is not a proof, share your test code, because it is really not working.
No it is not.
Maybe he didn't notice ZCD, he just tried the PIC itself
Flash50
-Given: 16
« Reply #4 on: September 13, 2020, 08:33:46 08:33 »
Sorry. I didn't notice ZCD.
-Given: 841
-Receive: 4367
« Reply #5 on: September 13, 2020, 09:16:18 09:16 »
My thoughts are as the model don't need patching, it's a Labcenter issue.
https://www.microchip.com/design-centers/8-bit/peripherals/intelligent-analog/zero-cross-detect
« Last Edit: September 13, 2020, 09:18:53 09:18 by pickit2 » Logged
« Reply #6 on: September 13, 2020, 09:32:30 09:32 »
Ahmad_k found that ZCDxCON value is not changing in Proteus.
HackAndCrack
-Given: 175
-Receive: 804
« Reply #7 on: September 13, 2020, 11:25:32 11:25 »
CM1CON0 and if needed CM2CON0 and ANSELx registers have to be configured as required to disable analog and comparator functions on ZCD pins. Maybe other features on those pins might also needs to be disabled.
« Reply #8 on: September 13, 2020, 11:41:54 11:41 »
Here is a quick project + Proteus.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1298
« Reply #9 on: September 13, 2020, 12:12:49 12:12 »
The pin used for ZCD must be configured as analog input.
The problem with PROTEUS is that ZCD1CON keeps its value to 0
« Last Edit: September 13, 2020, 12:15:15 12:15 by Ahmad_k » Logged
