December 24, 2024, 02:09:09 02:09
Author Topic: PWM circuit  (Read 4242 times)
« on: August 19, 2020, 07:00:12 19:00 »
Is this a suitable circuit for driving a 12V FAN using PWM output from a MCU?
Do I need a resistor from the gate to GND, if yes, what should be the value for it?
Do I still need a diode across C3?
Is this MOSFET good, any alternative can be suggested or keep it as is?
Edit: Max current 1.1A
« Last Edit: August 19, 2020, 08:49:13 20:49 by metal » Logged
optikon
-Given: 1110
-Receive: 2007
« Reply #1 on: August 19, 2020, 08:46:22 20:46 »
I would locate C3 from 12V to GND and not across your load.
You didnt say what current your fan draws...
« Last Edit: August 19, 2020, 08:50:31 20:50 by optikon » Logged
« Reply #2 on: August 19, 2020, 09:11:43 21:11 »
I edited first post
vern
-Receive: 42
« Reply #3 on: August 19, 2020, 09:22:38 21:22 »
I would add a Z-diode >24V from Drain to GND just to protect the transistor against spikes.
A resistor from Gate to GND is only necessary if the PWM output is floating before the MCU Pin is addressed, i.e. during power up.
This could overload the transistor because it could drift in a linear area, check the safe area region in the datasheet.
A voltage of 5V and a current of 200mA for example could destroy your transistor.
So just to be sure add a 47k resistor from FAN_PWM or Gate to GND to avoid any floating.
another thing:
If the PWM output is high before being addressed by the software the fan will be on full power.
If you want to stop that you need to add a capacitor, a resistor and a diode.
Cap 100nF in series between FAN_PWM and R4,
resistor 47k between Cap--R4 to GND
diode 1N4148 parallel to 47k resistor with anode to GND
« Last Edit: August 19, 2020, 09:27:16 21:27 by vern » Logged
« Reply #4 on: August 19, 2020, 10:04:28 22:04 »
this is how things should be. according to vern, zener is not required., also 100nF still I don't understand where is should be placed, also do I need a diode across the load?
Posted on: August 19, 2020, 11:35:01 23:35 - Automerged
this is ridiculous, I am looking at this white paper https://noctua.at/pub/media/wysiwyg/Noctua_PWM_specifications_white_paper.pdf, why bother with the MOSFET driver
optikon
-Given: 1110
-Receive: 2007
« Reply #5 on: August 19, 2020, 10:46:19 22:46 »
AC couple the drive? No that doesnt work. For high PWM duty cycles, a significant DC is present and needs to drive the gate. You cant AC couple it.
FTL
-Given: 170
-Receive: 33
« Reply #6 on: August 20, 2020, 12:05:58 00:05 »
PicKit2: I question your use of C1.
I don't see how it will keep the gate at ground to keep the FET off, unless it has higher leakage current than the FET gate.
Having C1 in parallel with the gate will significantly slow the switching speed of the FET. The gate is effectively a capacitor. It must be charged and discharged quickly to turn the FET on and off quickly (spend the least amount of time possible in the FET's linear region). Adding capacitance to the gate will slow that down, since the current (that is limited by R1), will take longer to change the gate voltage.
Having R1 at 10K will make for somewhat slow switching. Assuming a 5V signal from the MCU, that would limit peak charge and discharge current to 0.5ma. Metal's updated schematic shows R4 at 100R, which might be a bit small allowing currents of 50ma, which is probably a bit too much for an MCU pin.
In Metal's updated schematic, it would make more sense to me to have R? connected directly to the gate since its purpose is to keep the gate at ground with a high-impedance MCU pin. It does not really matter though as it is much larger than R4 so the result is that the gate is grounded through either 10,000 ohms or 10,100 ohms (the difference is probably smaller than the tolerance on R4). D? is extra safety for the MCU pins, but in most cases the MCU pins already have zeners to ground and Vcc in their static protection circuits (you shouldn't really count on them, but some designs do so successfully).
Another design consideration I have not seen mentioned yet is: What is the PWM frequency? The important thing is to make sure the FET switching time is at least an order of magnitude less than the PWM period so it spends the majority of its time either on or off (low power dissipation states) vs in linear switch mode where the power distribution is high.
« Reply #7 on: August 20, 2020, 03:11:20 03:11 »
I would think the FET should have a protection diode on the die.
the FET is more voltage than current so you could go higher
the resister to ground is in the wrong place, I like a small cap gate to ground.
it keeps the fet off at start up. I have used this in the past from memory you just have
to make sure the gate voltage is held below max allowed for device.
You mean I should not exceed max Vgs?
it is 25KHz, this suits both, fans that have PWM input and those without it. I have actually removed the MOSFET fan driver circuitfrom the schemtic, till I have this discussion complete, I have not thought it was more serious than it looked.
You are right, this is why I found many threads by people complaining about the heat dissipation, although there should not be any real heat dissipation.. this will make selecting the MOSFET a bit tedious. apparently the MOSFET I chose is a fail.
« Last Edit: August 20, 2020, 03:27:13 03:27 by metal » Logged
sadman
-Given: 1840
-Receive: 2910
Sow The Seeds of Love
« Reply #8 on: August 20, 2020, 06:29:27 06:29 »
Dear Metal
have look here PWM based DC motor controller
http://picprojects.org.uk/projects/ppc/index.htm
PM3295
-Given: 360
-Receive: 155
« Reply #9 on: August 20, 2020, 07:37:55 07:37 »
At 25 kHz, you definitely need some sort of gate drive circuit to switch the gate fast enough to keep losses low. Below is an example. I could not find a spice model for the FET you used, but this one is close enough in specifications.
The dissipation is only 106 mW with a 50% duty cycle, with the drive frequency at 25 kHz.
Xwing
-Given: 591
-Receive: 1530
« Reply #10 on: August 20, 2020, 11:16:06 11:16 »
Hi metal, if you use a noctua fan, or similar with PWM input (four pin connector), you can directly apply the signal from the processor gpio as it does not have to supply current, it is only a control signal.
vern
-Receive: 42
« Reply #11 on: August 20, 2020, 01:08:45 13:08 »
PM3295,
the Mosfet has an input capacitance of 240pF, I don't think you need a driver with a standard MCU output at 25kHz.
240pF at lets say 2 mA drive current yields a RC constant of about 0.4us, which is fast enough.
Optikon,
of course it works. That's why the diode is necessary, it keeps the level referenced to Ground. And since it's a Mosfet you only need to drive the gate capacity, which in this case is only 240pF. No more drive current after that.
With the 47k from gate to GND and the 100nF coupling capacitor you get a time constant of about 4.7ms, which is plenty compared to the cycle you need to gap at 25kHz which is 40us max.
PM3295
-Given: 360
-Receive: 155
« Reply #12 on: August 20, 2020, 04:07:07 16:07 »
You can never work with the gate input capacitance value alone. The moment the device starts to turn on, other parameters like Coss and Crss come into play, which results in a much larger value of gate capacitance seen by the drive source. It is normal practice to look at the total gate charge Qg and determine what peak driving current will be needed to charge/discharge the gate in a certain time.
You can read more about this in the discussion in this link, so I don't have to type it here.
https://electronics.stackexchange.com/questions/83712/gate-capacitance-and-miller-capacitance-on-the-mosfet
"The Miller capacitance (reverse transfer capacitance) is usually the smallest but it can have a serious effect on performance".
« Last Edit: August 20, 2020, 04:26:08 16:26 by PM3295 » Logged
optikon
-Given: 1110
-Receive: 2007
« Reply #13 on: August 20, 2020, 05:45:44 17:45 »
Optikon,of course it works. That's why the diode is necessary, it keeps the level referenced to Ground. And since it's a Mosfet you only need to drive the gate capacity, which in this case is only 240pF. No more drive current after that.
An AC coupled gate with a driver duty cycle of 100% (Which is *DC*) doesnt work. So NO.
« Reply #14 on: August 21, 2020, 01:45:04 01:45 »
I worked yesterday on the PCB. I removed the PWM criver circuit for the moment, as I still don't know if the final design will have it or not, nevertheless I might want to add the PWM driver to support fans without PWM control input. may be experts have sth to say about DC/Short protect circuits.
vern
-Receive: 42
« Reply #15 on: August 21, 2020, 09:46:25 09:46 »
optikon,
you are right of course, but PWM for Fans is never 100%, it may be 1% or 99% duty cycle, but never 0% or 100%
Posted on: August 21, 2020, 09:38:26 09:38 - Automerged
PM3295,
you are right, but those values are neglible compared to Ciss.
Even if they double the switch  on / off timing it would still be less than 1us, which is totally ok with such a small drain current.
~5
« Reply #16 on: August 21, 2020, 02:40:27 14:40 »
I may be wrong but I'm also not convinced that C1 is necessary.
PM3295
-Given: 360
-Receive: 155
« Reply #17 on: August 21, 2020, 03:40:42 15:40 »
It may be small, but its effect can cause the total gate input capacitance to appear up to 4 x larger than published Ciss during switching, depending on the application. The effect also increases with applied drain voltage.
I always put a small driver in when driving MOSFETS at higher frequencies, because you never know when you will need a bigger fan and/or a stronger MOSFET. The two bjt's are a few pennies and takes very little board space. It is a pain to hack the board later on.
« Last Edit: August 21, 2020, 03:54:02 15:54 by PM3295 » Logged
« Reply #18 on: August 21, 2020, 07:27:19 19:27 »
I believe I will go your way then, thank you all
I will start another thread for the PCB thing
