November 23, 2024, 03:30:32 15:30
Author Topic: [REQ] Help for CAD Trail Software  (Read 7749 times)
bader357
-Given: 232
-Receive: 74
« on: June 27, 2020, 12:39:27 12:39 »
Hi all
I have a "CAD Trail Software" with an integrated NC controller for (Numerical Control) machines.
The name is "MegaNC 3D pro".
Unfortunately, it has a time limit of 14 days.
Does anyone have an idea to remove this limitation?
Thank you
« Last Edit: June 30, 2020, 08:58:27 08:58 by bader357 » Logged
-Given: 231
-Receive: 983
« Reply #1 on: June 27, 2020, 02:41:49 14:41 »
Can you use the timestopper software?
https://time-stopper.apponic.com/
bader357
-Given: 232
-Receive: 74
« Reply #2 on: June 28, 2020, 09:26:28 09:26 »
Yes, I try some different Timestopper Software like RunAsDate etc.
but without success.
Only I format my Drive "C" and reinstall Windows then
the Software start with 14 days again.
By the way, the Limit is not 30 day, she is 14 days.
-Given: 834
-Receive: 4321
« Reply #3 on: June 28, 2020, 12:47:20 12:47 »
why not use a usb drive to run your program from am image, that is replaced when needed.
If need speed then look into installing from a drive into memory.
or even a VM
« Last Edit: June 28, 2020, 12:49:49 12:49 by pickit2 » Logged
bader357
-Given: 232
-Receive: 74
« Reply #4 on: June 28, 2020, 03:12:53 15:12 »
Good idea.
I want to tray on a VM Ware.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #5 on: June 28, 2020, 08:13:26 20:13 »
Hi all
Thank you
As i told you before if this is a demo version we can't do anything, i need a full trial version not a trial demo.
bader357
-Given: 232
-Receive: 74
« Reply #6 on: June 29, 2020, 08:25:12 08:25 »
Sorry, a mistake from me, but yesterday I test this Software. All functions work, also save and load and
also I can control my NC-machine. It is a full trial version.
Software has only the time limitations.
h0nk
-Given: 226
-Receive: 231
« Reply #7 on: June 29, 2020, 06:38:19 18:38 »
Hello bader357,
You should upload the software to a Filehoster.
Removing time limits is mostly possible and a
not too complex task.
Simple example from the past:
A license deamon which gets the time via a System call.
Replace the code for the System call with a fixed time
return value.
Used Tools: Hexeditor.
Best Regards
bader357
-Given: 232
-Receive: 74
« Reply #8 on: June 30, 2020, 07:09:14 07:09 »
Hello bader357,
return value.
Best Regards
I Upload to a Filehoster.
But sorry, I canīt remove the limitation with Hexeditor or so one.
I am not fit in programming language.
« Last Edit: June 30, 2020, 09:53:17 09:53 by bader357 » Logged
-Given: 834
-Receive: 4321
« Reply #9 on: July 01, 2020, 02:06:10 02:06 »
Show your Info box like below
sadman
-Given: 1830
-Receive: 2890
Sow The Seeds of Love
« Reply #10 on: July 01, 2020, 12:58:08 12:58 »
do not download or install it is repack installer not original two time i give a try every time setup try to install it self two time.
« Last Edit: July 01, 2020, 01:05:02 13:05 by sadman » Logged
-Given: 834
-Receive: 4321
« Reply #11 on: July 01, 2020, 03:12:23 15:12 »
yes I seen that, A very poor install package, I have an older version in my old work place, if I remember right it was a simple rework of the licence file.
I did notice not all options for the complete programme is not there in the demo, but a licence file should fix that.
I sent a PM to an old workmate who maybe able to send me the files, from the workshop.
I asked for a link from site, but not heard back, they must be in lockdown.
Posted on: July 01, 2020, 04:06:06 16:06 - Automerged
Here is a link to the demo Licence
A plain text with days of demo & there is a check sum to fix.
-Given: 834
-Receive: 4321
« Reply #12 on: July 02, 2020, 01:15:09 13:15 »
The two fodders are Program and User folders, just look like a lazy install.
Posted on: July 02, 2020, 10:59:57 10:59 - Automerged
MegaCad Metal 3d http://www.sonsivri.to/forum/index.php?topic=68407.0
Try the fix in that link it should enable all the options of MegaNc
« Last Edit: July 02, 2020, 03:34:20 15:34 by pickit2 » Logged
... Copyright Đ 2003-2999 Sonsivri.to ...
