November 21, 2024, 09:41:18 09:41
Author Topic: I was warned to make posts of value before requesting stuff  (Read 4235 times)
Simun
-Given: 11
« on: April 21, 2020, 10:23:28 10:23 »
Dear Ahmad_K,
Here is my 600v4 MachineID:
690560-222573-216246-602311-438670
1200v5 Hardware id attached.
Thank you
Posted on: April 21, 2020, 07:09:36 07:09 - Automerged
I have neon play software to create pixel led effect. But it is showing only " ? ? ? ? " Marks. But in youtube it is in english versions.
Kindly help.
Thank you
Posted on: April 21, 2020, 09:51:06 09:51 - Automerged
EN25T80 is not 5V tolerant on its data line, maybe it is working but it will have hardware problem later on. Checking the datasheet of the memory the absolute maximum voltage is 4v
Can i make 3volt for flash memory ic power supply using zener and resistor?
Simun
-Given: 11
« Reply #1 on: April 21, 2020, 03:39:12 15:39 »
Because the NeonPlay version that you have is Chinese Language version.
How to get English version. Kindly help
ron
-Given: 12
« Reply #2 on: March 11, 2023, 04:29:08 04:29 »
Yes you can. It wont be exactly 3. But I do know we use 3.2 Zener Diodes in our circuits. The resistor value will depend on the input voltage.
But as you know these circuits are typically only used in low draw circuits like audio opamps.
