ashrafhafezg
-Given: 96
-Receive: 364
« on: November 21, 2007, 07:29:52 19:29 » |
designer
« Reply #2 on: November 23, 2007, 07:27:39 07:27 » |
blaba
« Reply #3 on: November 23, 2007, 07:47:54 07:47 » |
I have made HV programmer and it works pretty good
s_ch
« Reply #4 on: November 23, 2007, 10:34:37 10:34 » |
program Algoritm Builder have very nice programmer for Avr. (for moderator- this is not reclame Algorithm builder ) you may download demo version program. in description this program consider circuit programmer for all avr.
chyun3
-Given: 43
« Reply #5 on: November 25, 2007, 08:57:27 08:57 » |
Hello, here got one very simple AVR programmer http://electronics-diy.com/avr_programmer.phpIt use PONYPROG Do anyone know is it a High Voltage programmer??? I have accidentally lock my AVR controller...
microkid
-Given: 45
-Receive: 23
« Reply #6 on: November 25, 2007, 01:22:30 13:22 » |
No it is not a high voltage programmer Try AVR Doper. A simple easy to build high voltage parallel avr programmer. MicroKid
Never Never Never giveup
ficho
« Reply #7 on: November 25, 2007, 03:37:29 15:37 » |
I once locked ATMEGA8515 buy mistake and used up-48 to remove my mistake...it was somthing like enable/disable serial programming, you can lock mcu but dont disable serial programming
xp338
-Given: 249
-Receive: 47
« Reply #8 on: November 25, 2007, 05:42:45 17:42 » |
Martin
« Reply #9 on: December 04, 2007, 07:40:39 19:40 » |
On this website ( http://www.mikrocontroller-projekte.de/ ) you can found very interest AVR programer. Im tested it and work perfectly.
dandumit
-Given: 22
« Reply #10 on: December 06, 2007, 09:00:58 09:00 » |
A simple parallel mode programmer for parallel port and other good things could be found here : http://elm-chan.org/works/avrx/report_e.html
ashrafhafezg
-Given: 96
-Receive: 364
« Reply #11 on: December 07, 2007, 11:45:15 11:45 » |
firewalker
-Given: 19
-Receive: 88
« Reply #12 on: December 08, 2007, 12:31:41 12:31 » |
botanik5745
« Reply #13 on: December 10, 2007, 02:00:05 14:00 » |
Mega32
-Given: 207
-Receive: 37
« Reply #14 on: December 12, 2007, 09:12:11 21:12 » |
firewalker
-Given: 19
-Receive: 88
« Reply #15 on: January 01, 2008, 08:00:39 20:00 » |
I had build the following programmer. http://www.tuxgraphic.org/electronics/200510/article05101.shtmlRecently I saw that there is a new version. http://www.tuxgraphic.org/electronics/200705/article07052.shtmlSo I started to build it... Later I discovered that I had no FTDI chips left... I was bored sitting without doing something so I fused the following projects... http://www.tuxgraphic.org/electronics/200705/article07052.shtmland http://www.recursion.jp/avrcdc/The result was this circuit The combination above wont work unless we make some changes to the code running inside the Atmega8 / 88 . The code can be found here. After decompressing the file we are locating the file uart.c. We open it and locating the part bellow // baud=7=115.2K with an external 14.7456MHz crystal // baud=9=115.2K with an external 18.4320MHz crystal unsigned int baud=9; We are chancing the unsigned int baud=9; to unsigned int baud=119;. This change is necessary in order to change the uart of Atmega8 / 88 to 9600 bps witch is the maximum for the Attiny2313 part of the circuit. With the command make we are creating the main.hex which we are going to load at Atmega8 / 88. If we don't have any other programmer we can use avrdude and a very simple programmer to load the codes to the chips. The code for Attiny2313 can be found here. The existing cdc2313.hex file can be used as is for programming ATtiny2313. The programmer works fine under Linux and Windows with avrdude and Atmel AvrStudio 4 under Windows. For those that can't handle smd chips like FTxxx and doesn't want to order the pcb it is a good solution. The programmer is a bit slow because of the 9600 bps. All tests were made using ArchLinux with gcc-avr 4.1.2; avr-libc 1.4.5; binutils-avr 2.17; uisp 20050207 and avrdude 5.5. For the testing in Windows; I used Windows Xp Sp 2.
RedBull
-Given: 40
« Reply #18 on: November 07, 2009, 05:34:52 17:34 » |
Anyone please recommend a very simple programmer for AT89S52. Thanks
horre_8
« Reply #19 on: November 11, 2009, 12:58:55 12:58 » |
simple usb isp for avr?
RedBull
-Given: 40
« Reply #21 on: November 12, 2009, 04:23:21 16:23 » |
thanks wellnerson1... I had searched over the net for programmer but could only find one where we had to have 89C2051 or atmega8 chip programmed with the provided firmware somehow before burning into 89S52. I cant get that done so i'm searching for the simpler alternative.Any suggestion?
« Last Edit: November 12, 2009, 05:04:45 17:04 by RedBull »
Tahmeed
-Given: 21
« Reply #24 on: January 09, 2011, 06:24:22 18:24 » |
hello. can anybody suggest for a cheap, easy to make atmega32 USB programmer schematic pls?.......
