November 21, 2024, 09:45:51 09:45
Author Topic: MPLABX v5.35 ISSUE  (Read 9360 times)
Manuel
-Given: 678
-Receive: 192
« on: March 31, 2020, 09:03:33 09:03 »
Facing an issue after installing MPLABX 5.35..
In the Project properties dialog box the CONF selection show an empty box, so cannot setup simulator-programmer-etc-etc...
Any Idea ?
The image show the issue.
take care
X!
koky
-Receive: 157
« Reply #1 on: March 31, 2020, 10:07:05 10:07 »
MY installation works
Manuel
-Given: 678
-Receive: 192
« Reply #2 on: March 31, 2020, 10:25:12 10:25 »
Dear Koky,
I can imagine it's working on your instalaltion .... it was not expected to be honest on my installation ...
I am always the lucky one.  Grin Grin Tongue Tongue
Hope to find a solution...
take care,
X!
koky
-Receive: 157
« Reply #3 on: March 31, 2020, 10:52:02 10:52 »
try manage configuration, in this menu you can select mcu , emulator and compiler
Wilksey
-Given: 161
-Receive: 2549
« Reply #4 on: March 31, 2020, 01:01:13 13:01 »
Did you overwrite an older version?
Some software I find needs a fresh install so I uninstall all other versions and reinstall, also try installing and running as administrator if you haven't already.
Manuel
-Given: 678
-Receive: 192
« Reply #5 on: March 31, 2020, 02:48:19 14:48 »
Solved,
I had to remove 5.35, manually delete :
C:\Users\xxxxx\AppData\Roaming\mplab_ide
and
C:\Users\xxxxx\AppData\Local\mplab_ide
then reinstall.
Well done so....
THE PROBLEM WAS IN THE PRESENCE OF THE MANUALLY REMOVED TREES....(INSIDE ODD ISSUES....PROBABLY)
but that is crazy , because I removed the previous version before install 5.35.
It may mean 5.25 do not remove properly....
maybe.
thank you
X!
Posted on: 31-03-2020, 08:12:30 - Automerged
Dark Theme for NETBEANs (MPLABX)
http://plugins.netbeans.org/plugin/62424/darcula-laf-for-netbeans#v9293
DOWNLOAD last version
Install in PLUGIN --> DOWNLOADED....
Nice view.
take care,
X!
Manuel
-Given: 678
-Receive: 192
« Reply #6 on: April 02, 2020, 08:11:11 08:11 »
I confirm a bug presence,
if you remove a DFP pack and and open a project with a DFP pack that you do not have....even if you reinstall the right DFP....you will be allowed to adjust setting in CONF of PRJ_PROPERTIES anymore...
have to follow the previous post...
Something is oddy anyhow , found same issue after installing plugins !
take care,
X!
« Last Edit: April 02, 2020, 10:09:10 10:09 by Manuel » Logged
Manuel
-Given: 678
-Receive: 192
« Reply #7 on: April 21, 2020, 09:42:11 09:42 »
Discovered the ISSUE (for me):
Installing the PLUGIN - Proteus VSM Viewer Tool - will disappear in Project Properties the possibility to see&set PACKS & Compiler Toolchain selection's list.
A Simple uninstall solve the issue.
take care,
X!
Diecore
-Given: 55
-Receive: 109
« Reply #8 on: June 14, 2020, 02:43:59 14:43 »
I don't know if you haven't noticed yet but MPLABX v5.40 is released... and its suppose it's less buggy than previous version...
Manuel
-Given: 678
-Receive: 192
« Reply #9 on: June 15, 2020, 09:24:26 09:24 »
YES YES, checked some week ago, but did not install Proteus VSM Viewer Tool since I do not play with it....
Thank you!
X!
koky
-Receive: 157
« Reply #10 on: June 15, 2020, 06:11:11 18:11 »
5.40 version is very problematic, is 64 bit, but is a BUG, i'm reinstalled 5.35 version
jartur
« Reply #11 on: September 06, 2020, 02:11:54 14:11 »
Hello, I have the same problem with the MPLABX v5.40, but I think this looks like java problems with the new version of the MPLABX, for now, I returned to use the MPLABX v5.35 and works good, but also the MPLABX v5.35 had some issues with the java version
saeed7701
-Given: 35
-Receive: 160
« Reply #12 on: January 07, 2021, 12:55:03 12:55 »
Hi, How is MPLAB X v5.45 , this version have a bug or not than v5.35 ? I want to install MPLAB X which version do you suggest ?
Manuel
-Given: 678
-Receive: 192
« Reply #13 on: January 07, 2021, 02:58:36 14:58 »
V5.45 is ok,
I can confirm the PLUGIN - Proteus VSM Viewer Tool is working in this version.
In case of issues, just uninstall the PLUGIN that are creating issues.
I had to modify this message.
take care,
X!
« Last Edit: January 08, 2021, 10:49:33 10:49 by Manuel » Logged
« Reply #14 on: January 08, 2021, 12:08:55 00:08 »
Actually it works for me on MPLAB X 5.45 and Proteus 8.11 SP1
