December 22, 2024, 09:08:27 21:08
Author Topic: mach3 5 axis breakout board  (Read 3032 times)
sfiga69
-Given: 200
-Receive: 159
« on: February 29, 2020, 09:01:45 21:01 »
does anyone have schematics for this breakout board?
-Given: 836
-Receive: 4330
« Reply #1 on: February 29, 2020, 09:47:01 21:47 »
Wiring only
sfiga69
-Given: 200
-Receive: 159
« Reply #2 on: March 01, 2020, 10:15:17 10:15 »
thanks pickit2 that's easy to find.
my problem with this card is that the enable pins don't match.
I expect the enable (P14) connection on the blocks to match the enable pin on the 5 JX connectors.
surprise ... the pin enable on JX of the X-Y axis are interconnected and be lost, the pin enable Z-A-B are interconnected and are lost. The two blocks are not connected to the enable (P14).
If I follow the tracks, they get lost under 74hc245 and I don't find any connection with EN.
The CK and CW connections on the JX correspond on the blocks.
I need the schematic to find out if it's a CS problem.
-Given: 836
-Receive: 4330
« Reply #3 on: March 01, 2020, 11:05:51 11:05 »
I think your problem is the Enable output pins on the 0.1 headers are independent,
but the screw connectors they are common.
I would think they are routed via the 74hc245. I think your tracing is off as they are tri-state output devices.
« Last Edit: March 01, 2020, 11:15:57 11:15 by pickit2 » Logged
sfiga69
-Given: 200
-Receive: 159
« Reply #4 on: March 01, 2020, 07:39:15 19:39 »
You are right.
pin 6 of the 245 A-B Axis
pin 7 of the 245 Z-A-B axis
pin 8 of 245 P14
pins 14-13-12 of 245 to pin 14 of the parallel port
have separated the enable
