December 23, 2024, 03:06:39 03:06
Author Topic: 100W (or more) Vac dummy load  (Read 7169 times)
M@X77
-Given: 46
« on: November 27, 2019, 05:03:31 17:03 »
Hi to everyone, I need to test some transformers, I would like to avoid to use a rheostat, but a dummy Vac load.
Someone did had the same question? Found a solution? I tried to search but I didn't get any results.
In google I found the attached schematic, but it don't convince myself.
It seems strange where the potentiometer get ref (r3 on load input), I think it need a voltage reference if I want costant current load.
thanks
Massimo
LabVIEWguru
-Given: 273
-Receive: 593
« Reply #1 on: November 28, 2019, 01:25:24 01:25 »
What about a 100 W incandescent lamp?
forter
-Given: 1061
-Receive: 28
« Reply #2 on: November 28, 2019, 06:12:03 06:12 »
Hi, M@X77!
 If done as shown in the diagram, it turns out that the conductivity will depend on the input voltage.
And this means non-linearity of resistance.
M@X77
-Given: 46
« Reply #3 on: November 28, 2019, 04:16:41 16:16 »
I would like a costant current load to do AC transfonformer experiance
@forter: it's my own thought, if so, just use a reference voltage, no?
kreutz
-Given: 995
-Receive: 125
« Reply #4 on: November 28, 2019, 04:34:20 16:34 »
I have used a water filled bucket and water heater heating elements in the past.
Checksum8
-Given: 124
-Receive: 102
« Reply #5 on: November 28, 2019, 04:41:07 16:41 »
Years ago, I did transformer testing using a dc constant current load with a 25 amp bridge rectifier between the two. I don't remember the details, like if a  electrolytic capacitor was needed on the load side?
forter
-Given: 1061
-Receive: 28
« Reply #6 on: November 29, 2019, 06:42:15 06:42 »
@M@X77 I think the idea of Checksum8 of ​​using a bridge rectifier is a very interesting solution. Only, of course, without any capacitor and of course R3 must be connect to a constant reference voltage
flyback
-Given: 73
-Receive: 39
« Reply #7 on: November 30, 2019, 11:26:04 11:26 »
I found this link. Seems that's more or less what you sought (an AC constant current load).
https://electronics.stackexchange.com/questions/218976/ac-constant-current-source-design/219747
bobcat1
-Given: 4307
-Receive: 96
« Reply #8 on: December 01, 2019, 07:57:29 07:57 »
Both circuit are simple to simulate in LTSpice or Pspice just to know whether they work or not - you don't have to use same components just choose close parameters.
All the best
Bobi
« Reply #9 on: December 01, 2019, 02:14:53 14:14 »
What exactly are you testing on these transformers...and why?
M@X77
-Given: 46
« Reply #10 on: December 02, 2019, 10:06:24 10:06 »
I need to test nominal current and check temperature, the problem was the current is different and I need flexibility.
I think to use a classic DC mosfet dummy load and put a Graetz Bridge without capacitor, the current tha flow in the circuit is equal, the mosfet "sees" DC pulse current but this I think is not a problem.
-Given: 231
-Receive: 987
« Reply #11 on: December 02, 2019, 12:49:55 12:49 »
By the way. You are aware that regarding current ratings. They are in AC. If you load your transformer with a typical setting with a rectifier and filter (inductor/capacitor) The DC current you should allow for. In some cases should be much lower than the transformer AC current rating.
Just in case this something new for you I leave this Google link for you
https://www.google.com/search?q=Design+Guide+for+Rectifier+Use
Checksum8
-Given: 124
-Receive: 102
« Reply #12 on: December 02, 2019, 05:28:55 17:28 »
I would use a clamp on AC current meter or current transformer to get actual readings from the transformer. Don't rely on some pulsed DC on the load side.
titi
-Given: 3828
-Receive: 834
« Reply #13 on: December 02, 2019, 05:59:05 17:59 »
In Elektor Labs there is an article about an Electronic load for DC and AC.
May be it can helps.
They use an DC Electronic Load behind a bridge rectifier for AC mode.
https://www.elektormagazine.fr/labs/electronic-load-for-dc-and-ac
The video https://www.youtube.com/watch?v=YXUa-xOSNLE&t=
In attachemnt all the files of the project.
Best regards.
« Last Edit: December 02, 2019, 06:01:16 18:01 by titi » Logged
M@X77
-Given: 46
« Reply #14 on: February 26, 2020, 11:42:29 11:42 »
Best regards.
Very interesting! thanks
I trying to do
« Last Edit: February 26, 2020, 11:48:17 11:48 by M@X77 » Logged
