November 21, 2024, 10:00:03 10:00
Author Topic: J-Link (JLink) SOFTWARE  (Read 16948 times)
wild
-Given: 604
-Receive: 452
« on: November 09, 2019, 09:37:25 21:37 »
Attached you will find the latest release of Segger J-Link software/utilities (v6.54c) with patched DLLs to:
- remove check of cloned programmers
- remove nag screen when using EDU/ST/NXP/... J-Link programmers
Please take care that I was not able to test the patches: now I own only original Segger programmers!
Password as usual!
wild
-Given: 604
-Receive: 452
« Reply #1 on: November 28, 2019, 01:01:05 01:01 »
Attached you will find the latest release of Segger J-Link software/utilities (v6.56a) with patched DLLs to:
Password as usual!
wild
-Given: 604
-Receive: 452
« Reply #2 on: December 07, 2019, 06:43:23 18:43 »
Attached you will find the latest release of Segger J-Link software/utilities (v6.56b) with patched DLLs to:
Password as usual!
wild
-Given: 604
-Receive: 452
« Reply #3 on: January 18, 2020, 03:05:36 03:05 »
Attached you will find the latest release of Segger J-Link software/utilities (v6.60e) with patched DLLs to:
Password as usual!
Kombinator
-Given: 39
-Receive: 32
« Reply #4 on: February 08, 2022, 03:52:43 15:52 »
Hi wild
Any news (v6.60e) on how it works with Chinese J-Link V9
wild
-Given: 604
-Receive: 452
« Reply #5 on: February 09, 2022, 03:02:23 03:02 »
As I previously wrote,
Sorry, I can't help!
zelea2
-Given: 8
-Receive: 183
« Reply #6 on: February 09, 2022, 05:36:34 05:36 »
You don't need to patch the J-Link software. The V9 clones work fine with the latest V7.60g.
The only drawback is that you get a nagging screen after a timer expires telling you that
it's not a genuine device but apart from that it works fine.
The detection of V9 clones is based on two checks: first if your clone ID is in a list of
banned numbers and second if you have one of the depreciated features "GDBFull", "RDDI"
in your license.
The serial ID number and the licenses can be very easy programmed to what you want
using a STLinkV2 as explained here:
lyduck.vajn.icu/ep/archive/2019/05/Unbricking_a_SEGGER_J_Link_v9_debug_probe.html
bobcat1
-Given: 4273
-Receive: 94
« Reply #7 on: February 14, 2022, 07:19:05 19:19 »
Hi ,
Any one have ver JLINK 7.60g
thanks in advanced
Bobi
zelea2
-Given: 8
-Receive: 183
« Reply #8 on: February 18, 2022, 07:00:59 19:00 »
All versions (including older ones) are freely available on segger's site.
Kombinator
-Given: 39
-Receive: 32
« Reply #9 on: March 05, 2022, 12:48:10 00:48 »
J-Flash V6.60e- this version works well with the Chinese replica   J-LINK V9 ARM
tomywong
-Given: 101
-Receive: 213
« Reply #10 on: March 26, 2022, 05:29:26 17:29 »
I have J-LINK v9.4 clone.
Firmware: J-Link V9 compiled May 7 2021 16:26:12
Hardware version: V9.40
License(s): RDI, GDB, FlashDL, FlashBP, JFlash
It work fine until J-Flash v7.58b. (no need modify dll)
Begin from v7.58c, it say my J-LINK is clone.
« Last Edit: March 26, 2022, 06:53:09 18:53 by tomywong » Logged
tomywong
-Given: 101
-Receive: 213
« Reply #11 on: August 23, 2022, 04:25:16 16:25 »
From this post http://www.sonsivri.to/forum/index.php?topic=41726.msg203723#msg203723
Thx go to him.
I fixed J-Link v7.70A. Just download and replace fixed DLL. It work for my J-Link v9.4 clone. And should work for V8 (not tested)
fonak
-Given: 76
-Receive: 196
« Reply #12 on: August 24, 2022, 04:31:41 16:31 »
Patch works ok with Jlink v11 7.70a, but don't update firmware above v7.52.
Additionally, there is still an annoying message about the need to update the firmware.
If You do that  Keil shows error: " ***JLink Error: Could not transfer JTAG data: Emulator is out of memory.
Could not read hardware status!"
The only way to fix this is to go back to firmware v7.52
Keil error
"JLink info:
DLL: V7.70a, compiled Aug 10 2022 16:28:01
Firmware: J-Link V11 compiled Jul 22 2022 10:21:23
Hardware: V11.00
S/N :************
Feature(s) : GDB, RDI, FlashBP, FlashDL, JFlash
* JLink Info: Failed to attach to CPU. Trying connect under reset.
* JLink Info: STM32 (connect): Can not attach to CPU. Trying connect under reset.
STM32: Connecting to CPU via connect under reset failed.
Error: Flash Download failed  -  Target DLL has been cancelled"
fonak
-Given: 76
-Receive: 196
« Reply #13 on: August 01, 2023, 11:29:07 11:29 »
I found an interesting software called EDUReviver that can repair faulty JLinks.
Can someone convert it in such a way that it also supports clones?
Link below:
https://github.com/banxian/EDUReviver
h0nk
-Given: 226
-Receive: 231
« Reply #14 on: August 02, 2023, 04:47:53 04:47 »
Hello fonak
Link below:
The process of reviving a broken J-Link, requires the setting of
some jumpers inside the box. For v8 J-Links You will need also
AT91SAM-PROG V2.4, and of course a firmware file.
Without the proper jumper setting the reviving will not work.
For v8 J-Links the needed functionality already exists
and i see no need to convert the software.
Maybe someone can add some information for v9 and later J-Links.
Best Regards
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #15 on: August 04, 2023, 03:40:55 15:40 »
V9 is easy to revive as the original bootloader is floating on the internet, search for "Kevincoooool ks_diy_link" on github and you will find the bootloader there. Next you simply update it using latest version of jlink software, it will be like the original, no more patching.
wild
-Given: 604
-Receive: 452
« Reply #16 on: August 04, 2023, 08:37:21 20:37 »
@Ahmad_k: to your knowledge does the ks_diy_link interface still works with the latest versions of the j-link SW?
I need to make some cheap programmers for a particular project and I like the dimensions of ks_iy_link!
fonak
-Given: 76
-Receive: 196
« Reply #17 on: August 04, 2023, 11:04:34 23:04 »
Does anyone already have the new patch for new Jlink Software v7.90x64 and can share it?
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #18 on: August 05, 2023, 04:27:51 04:27 »
Yes I already said that in my last reply. You will have an original V9 as the bootloader is original. The only thing is to chose a correct format for the serial number
26xxxxxx EDU
5xxxxxxx BASIC
6xxxxxxx PLUS
80xxxxxx EDU Mini
For example a 9.4 Hardware with PLUS functionality must have a serial number like this:
694xxxxx
and when setting the feature set only : RDI, GDB, FlashDL, FlashBP, JFlash
« Last Edit: August 05, 2023, 04:34:08 04:34 by Ahmad_k » Logged
