February 18, 2025, 11:01:19 23:01
Author Topic: SketchUp Pro & SketchUpStudio (x64)  (Read 20823 times)
mars01
-Given: 699
-Receive: 1775
« on: October 23, 2017, 08:48:27 20:48 »
SketchUp Pro 2017 17.2.2555 (x64)
Mega, Zippy and Uploadfiles.io links
« Last Edit: July 24, 2024, 12:05:55 12:05 by pickit2 » Logged
mars01
-Given: 699
-Receive: 1775
« Reply #1 on: March 06, 2020, 07:33:00 19:33 »
SketchUp Pro 2020 20.0.362 x64
What's new: https://help.sketchup.com/en/current-release-notes
Features:
• create, document and make a presentation of the project using one single drawing.
• Draw, modify, measure, rotate, scale, and move geometric shapes.
• The location and annotation of many scaled images on one page
• Buildings, furniture, interiors, building structures and much more are designed in a matter of minutes.
• Export of 3D models to CAD and other 3D formats
• Export of 2D vector images
• Model shadows in real time for any area on Earth.
• Creating multi-page documents and presentations
• Creating customizable presentation elements and notation using 2D vector tools
• Creating rendering effects in the form of sketches and fog, signing models using 3D text, emblems and watermarks
• Matching existing models to background images
• Getting professional email support
• Use exact dimensions and indicate them using text.
• Set section planes for viewing and working inside models.
• Use prepared textures in models, such as brick, wood, tile, glass, or create new textures.
• Add pre-built components, such as trees, cars, doors and windows, as well as people, or create new components.
• Smooth surfaces.
• Simulate the location of the camera in space.
• Use organic modeling (using the Sandbox).
• Import two-dimensional images (.jpg, .png, .tif, .tga, .bmp) and three-dimensional models (.3ds, .dem, .ddf, .dwg, .dxf, .skp).
• Exporting 2D images of models - JPEG (.jpg), png, tif, tga, bmp
• Placing SketchUp models on Google Earth is performed using the Place Model command. Exporting a Google Earth file directly to the KMZ format.
• Model sharing in the 3D model service.
• You can print part of the model displayed in the drawing area of ​​SketchUp.
• Print and export bitmaps at the selected resolution.
• Export animations and passes to MOV or AVI files.
• Export to 2D formats: PDF, EPS, Epix (.epx), AutoCAD (dwg, dxf)
• Export of 3D models to formats: 3DS, AutoCAD (dwg, dxf), fbx, obj, xsi, vrml
Attached MEGA, Zippyshare, Filedropper links with a RuTracker torrent.
LE: Added in the attached file a MEGA link with the actual software files and fix.
« Last Edit: March 06, 2020, 07:36:45 19:36 by mars01 » Logged
