@Old_but_Alive
1. I think i have found a very elegant option for variable output voltages using XL4015. As far as voltages less than 1.25 are concerned, my atmega controller will sense the it and simply cutt-off the output once i reach this lower limit for output voltage.
2. So as given in the datasheet of XL4015, i am thinking of replacing R2 with either a digital pot from AD which i have used quite often or i can straight away replace it with the operator adjusting resistor. This will give me a voltage output from 1.25 upto 36V (as per datasheet)....
3. I assume that a fixed value inductor of 47uH will suffice for the entire range from 1.25 to 36 V ? right?
4. Do you foresee any problems with this approach?
This seems quite good an alternative....
-techNeo
Posted on: August 11, 2019, 03:43:12 03:43 - Automerged
I would use a LM2596 converter.
Yes it is also a good option specially with a current output of 3A but the minimum output voltage is a bit high i.e 4.5V . Compared to this product, the LT family (LT3085) offers a minimum voltage output of 1.2V with a current output of 0.5A. Since LT LDOs can be used in parallel, the overall current output can be increased manifold.
-techNeo
Posted on: August 11, 2019, 04:18:21 04:18 - Automerged
LM2596 buck converter modules are available for a few dollars (I agree with Pickit2). Maximum current about 3 Amps, minimum output regulated voltage will be over 1.25Vdc so you need a compromise solution, maybe using a potentiometer with switch (using the switch contacts in series with the 24Vdc input).
I think my first option is to go for XL4015 based module because of its easy availability. Then i will order LT comps from digikey and hopefully will get what i want..
-techNeo
